Like Tree4Likes
Old 04-28-2012, 02:52 PM   #8176
texastc's Avatar
I saw on Tamiya's site last night that there is a F104W -Lotus 102B coming out. No other details besides the MSRP of 275. Maybe just a release with another body.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and another Exotek F1Ultra on the way. And whatever is next
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom "you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 04-28-2012, 03:48 PM   #8177
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Are the 104W bodies the same as the 103s? Can I use the wings and bodies that I already have for my 103 cars?
Haven't tried anything yet
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 04-28-2012, 03:53 PM   #8178
Pro10noob's Avatar
The wings you can use.
The bodies have there holes for the bodyposts at a different place and i bellieve the F104 bodies are a bit longer and a bit narrower.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-28-2012, 04:10 PM   #8179
C&B RC's Avatar
Hard to tell what it has from the copy
http://translate.google.com/translat...26prmd%3Dimvns
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 04-28-2012, 05:22 PM   #8180
texastc's Avatar
You may have to drill new holes, but should work. I use _F103, F104, and F104w on my F1R. Not exactly the same but close enough for govt work, plus a lot more room underneath.
Old 04-29-2012, 03:33 AM   #8181
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by J-PaP View Post
What I found was there was as much grip in the rear as using a full sized heavier battery but the steering response greatly improved.
These were my times when all I did was switch from a full sized lipo to the shorty lipo.
21.480 with full sized battery
20.876 with shorty lipo
You might want to weigh your packs. I have heard that the shorty packs in some instances are heavier than the full size lipos
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 04-29-2012, 05:15 AM   #8182
I had in the past. I have 4 different packs. This is how each performed on the 2 tracks I race at.
6800 70c - 320g - 2nd fastest lap time on the larger track I race at - causes understeer
5800 60c - 280g - 2nd fastest lap time on the smaller track I race at. decent turn in.
4200 40c - 220g - slowest of all batteries but better initial turn in than the above 2 packs
4400 50c shorty - 220g - fastest on both tracks. Similar straight line performance to the 6800 70c with the turn in of the 4200 40c.
The shorty for me is equal lightest but it is definitely heavier than the packs others I know use. I have seen some other guys using full sized lipos weighing 180 grams.
The benefit seems to be mostly that I can minimise the weight on the front tyres which gives me better front grip and maximise the weight over the rear giving me the most rear grip.
J-PaP is offline   Reply With Quote
Old 04-29-2012, 12:13 PM   #8183
Hi, I am going to change the gearing on my pro, will the RW racing spurs work? -any ideas what size ceramic balls I need for that spur? -3mm?
Will use the HW justock esc and HW 21.5t motor and thinking I need 2.5 to 3 gearing if I have understood right what I have read here.
If RW wont work, what gears would fit the f104 well? -I have the spur gear adapter allready.
-Pate
fastvee is offline   Reply With Quote
Old 04-29-2012, 07:53 PM   #8184
texastc's Avatar
Ok F104 pros, I need some help. I keep having the lower ball on the front arm pop out. I have changed balls, and even changed lower arms, still pops out. Any ideas? I'm sure its something simple. But Im not catching it.
Old 04-29-2012, 09:19 PM   #8185
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
stop hitting things
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 04-29-2012, 09:33 PM   #8186
What wheels are you using?
What spacers are you using on the kingpins?
Any slop above the upright?
Bumpy track?
Ride height at the front?
Old 04-29-2012, 09:49 PM   #8187
texastc's Avatar
Originally Posted by mkennedy View Post
stop hitting things
me???? naw, its got to be something else
Bumpy track?
foam wheels, pit tires
2mm under 4mm above
no slop
carpet pretty smooth
4mm ish
Old 04-29-2012, 11:46 PM   #8188
Just finished cleaning my F104GT for asphalt season...
http://img33.imageshack.us/img33/3364/p1080901z.jpg
and result of my experiment? even with "traditional" dumper I was still able to race with cars like Corally 10SL and Xray X10... around 3-5 position, first two have corally/xray too, but still better hands than I have , after 1/2 of the race, when they catch me, I figured out that we our cars are same... I also noticed that I was little bit faster than the two riders in front of me, but I wasn't able to get in front of them... they were just too good and don't left me space to overtake them... so in final I was around 3 position in question of speed, but I screwed up the qualification and wasn't able to overtake the 3 and 4, so I ended on 5 position
anyway, F104GT is perfect car! , but I just want to ask question, is there a way to have 50mm rear tires on F104 with width under 200mm? and... is there a way to actually adjust the width to 235mm? (local GT category is limited to 235mm ...)
SquirrelCZE is offline   Reply With Quote
Old 04-30-2012, 12:51 AM   #8189
There are some hub wheels pro10 tires adaptors for F103/f014, just look for them in the forum. In Germany they use these adaptors to run F103/f104 based cars in the WGT/pro10s (200 mm) category.
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 04-30-2012, 01:07 AM   #8190
PDR
PDR's Avatar
Grabbed the R-Sector widening kit for my F104 to have a bit of a play. All worked well, except the diff-side axle is a little loose and causes the rear wheel to wobble. In part, this is because the wheel sits on less of the hub part which is anchored to the main axle.
Any suggestions on the best way to stabilise it?
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
