Like Tree4Likes
Old 04-17-2012, 10:32 PM   #8101
Pro10noob's Avatar
Remeber that the 104WGP t-Bar won't fit the stock F104 chassis as it is different in shape.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-17-2012, 10:36 PM   #8102
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Doh, J-Pap posted this so hopefully he can confirm. If not, that bites.
"The t bar is definitely softer on the f104w gp than the high traction t bar from the x1. Since I dont need the bottom chassis/t-bar for the f1 ultra I think I may actually use it on the x1 instead. Should yield more traction. It is also 21 grams lighter than the frp bottom+t bar+carbon reinforced bottom plate"
Dan is offline   Reply With Quote
Old 04-18-2012, 01:00 AM   #8103
dfx
dfx's Avatar
It won't fit (without modification of the stock chassis). J-Pap has to use WGP chassis with WGP pod. Watch attached picture.
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 04-18-2012, 01:08 AM   #8104
TryHard's Avatar
WGP Pod is same as X1.. but your right on the chassis though. The WGP t-bar has a longer/bigger cut-out, hence why it feels softer than standard 104 bar. I am liking the one-piece bottom though (picked up the 3-racing version to use, and run the 1.3mm thick).
Regards
Ed
TryHard is online now   Reply With Quote
Old 04-18-2012, 01:42 AM   #8105
dfx
dfx's Avatar
Yes, sorry, I thought one piece T-bar...
Motor pod is the same instead of the rear alu piece, is it right? TryHard, how do You feel WGP car? Are You running wide configuration and is there big difference (compared to a narrow car)? Dou You have the front axle build in stock configuration and what tires do You run?
Tamiya TRF 416 WE
Old 04-18-2012, 02:25 AM   #8106
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by Pro10noob View Post
I am using Roche Silverback 4200MAH shorty lipo's
You have the choice with the shorties to run your electronics on the side as per stock or in front of the battery.
regards Roy
thanks to all...i have ended up getting some intellect 4400 short packs...i should have them tomorrow
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 04-18-2012, 09:46 AM   #8107
JayL's Avatar
What part for the F104 to use turnbuckles for the front upper suspension links?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-18-2012, 11:08 AM   #8108
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Marc R and Hiro's IIC race is pretty damn good.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 04-18-2012, 08:48 PM   #8109
TryHard's Avatar
I have to admit that I've only had the opportunity to run the car twice so far, and I've run it in wide config (with R-sector rear widening kit), using the SGP1 tyres. Was pretty good, although I think I would prefer narrowing done the front to 190mm to match the rear. Had to drive quite aggresivly to get the car to turn, and was a bit inconsistent as a result.
HiH
Ed
Old 04-18-2012, 09:25 PM   #8110
Sorry I assumed that was known. You can't fit the f104wgp t plate on a f104 chassis. You can fit a normal t plate to the f104wgp chassis. Ran the f104wgp chassis and t plate. Didn't notice an improvement but didn't seem any worse either
J-PaP is offline   Reply With Quote
Old 04-19-2012, 02:37 AM   #8111
blade072's Avatar
found out the intellect short packs only fit in the X1 without the electronics trays installed..im shattered.....oh well the round edged 3800's it is then
David Randall
Old 04-19-2012, 06:10 AM   #8112
That is incorrect. You just cut off the loop on the inside of the trays. They then just clip on and off. But if you are running a shorty lipo you shouldn't need the trays anyway as the esc will fit in front of the battery and the receiver depending what you have fits on top of the top deck.
Here is how mine is setup (using x1 bottom deck and t plate)
Old 04-19-2012, 06:12 AM   #8113
avs
avs's Avatar
like Tony Phalen suggested, you can grind the protruding portion of the tray so it snaps onto the post, which is plenty for the receiver, but if you want more security for the esc then servo tape the plate onto the battery.
but with a shorty you have room to place the esc on the chassis?
Tony Shimko
avs is offline   Reply With Quote
Old 04-19-2012, 06:30 AM   #8114
blade072's Avatar
thanks guys...i meant without modding the car....which i really dont want to do...but i still might the tray mods...never thought of that...but then again...i could put the receiver where you have put it
David Randall
Old 04-19-2012, 06:45 AM   #8115
blade072's Avatar
just did what you said jpap in regards to the trays...many thanks....works great
David Randall
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
