Like Tree5Likes
Old 03-24-2012, 10:56 PM   #7966
Trader Rating: 21 (100%+)
I don't have a WGP, but I've done the conversion from classic F103.
Off the top of my head, if you're starting with an F103 front, you need at least the following to convert to F104:
9808241- http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
51381 - http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
53599 - http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
54249 - http://www.tqrcracing.com/shop/produ...d=32mm&pg_no=1 Or anything comparable.
9808240 - http://www.tqrcracing.com/shop/produ...808240&pg_no=1 Or anything comparable.
53587 - http://www.tqrcracing.com/shop/produ...yword=&pg_no=4 Shims for front axles to remove slop. They didn't come with my F103, but from what I understand, the F104 kits come with one .3mm piece per side. Of course, you may use whatever substitute you may have laying around; I would guess WGP probably comes with this piece.
You can get the following options to bring it up to pro/x1 spec:
54160 - http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
54161 - http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
54202 - http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
I don't know what wheels the WGP comes with, but i'd assume you'd need a full set of 104 F/R wheels too. F103 fronts don't fit on the F104 front suspension. If you do switch to F104 front wheels, don't forget the bearings too since the OD is different from F103.
silencery is offline   Reply With Quote
Old 03-24-2012, 11:10 PM   #7967
blade072's Avatar
Trader Rating: 98 (100%+)
i have the f109 at the moment.......the kingpin balls look the same.....
so all i would need is the f parts and kingpins....and maybe the brace for the back of the servo holder...but not sure on the last one...
as for bearings..yeah i would need to get those for f104 spec wheels...or i could just leave as is and just use the f103 wheels
as i know they will fit on the f104wgp front
thanks
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-24-2012, 11:53 PM   #7968
No prob.
If you have the F109, you may be able to use the front kingpins? I know FGX/F104 kingpins are interchangeable.
Oh, oops, forgot about the servo holder. If you need the F104 servo holder (and I strongly believe you will), it comes on the F104 D parts tree: 51380. You can also use metal hop-ups as an alternative; tamiya/exotek/3racing all make aluminum options.
Old 03-24-2012, 11:59 PM   #7969
blade072's Avatar
Originally Posted by silencery View Post
No prob.
the f103/109 kingpins are the same size.....around 28mm so i would need to get those...thanks again for your help
David Randall
Old 03-25-2012, 02:03 AM   #7970
blade072's Avatar
just realised the w uses the same servo holders so i wont need to order those..
David Randall
Old 03-25-2012, 04:45 AM   #7971
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
does anyone know of a link to the F104GP manual??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-25-2012, 09:54 AM   #7972
Pro10noob's Avatar
Not sure if it is online yet
Perhaps some one can make a copy and put the link here?
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-25-2012, 07:34 PM   #7973
mtveten's Avatar
Trader Rating: 27 (100%+)
Originally Posted by blade072 View Post
to anyone out there who has the f104wgp....
have you changed the front end to the 104???
if so what parts and mods were needed or used.. (but it probably wont make much difference)
thanks
To convert to the standard narrow 104 front end you will need the f104 front arms parts tree TAM51381, f104 king pins TAM54160, turnbuckes TAM54249 (pair), 2 x ball studs TAM53968, (pack of 5), and2 x ball nuts TAM53640 (pack of 10)
Mark
mtveten is offline   Reply With Quote
Old 03-26-2012, 12:37 AM   #7974
cocojam's Avatar
Trader Rating: 47 (100%+)
Is there a carbon reinforced front upper arm available from Tamiya. I keep on bending the front plastic upper arms of my 104 everytime I bump or crash. Has anyone tried converting this or fabricating a reinforcement?
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 03-26-2012, 01:10 AM   #7975
blade072's Avatar
Mark
thanks mark...
have put both tamiya f104 front and rear wings on my f109 and see how it goes sunday....here hoping it goes crap...
David Randall
Old 03-26-2012, 01:20 AM   #7976
texastc's Avatar
I use small diameter cf rod and Shoe Goo. Then some heat shrink over it. Strengthens it well.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 03-26-2012, 01:22 AM   #7977
texastc's Avatar
thanks mark...
I like the F109 front wing, while I like the tamiya f60 rear.
Old 03-26-2012, 09:32 PM   #7978
cocojam's Avatar
Thanks. Will try doing that, especially the heat shrink which I never thought of.
Old 03-26-2012, 09:39 PM   #7979
hello
i make my car into 48p gear and ask of the gear spacer? should it measure the same width as the spur gear or is it fine to be wider than the gear? or to file the spacer down? i only have spur gear that is of very thin.
freakyfreakyflo is offline   Reply With Quote
Old 03-26-2012, 09:54 PM   #7980
texastc's Avatar
Originally Posted by freakyfreakyflo View Post
hello
Its fine to be wider than the gear.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
