Like Tree1Likes
Old 03-19-2012, 12:59 PM   #7906
mtveten's Avatar
Trader Rating: 27 (100%+)
Originally Posted by blade072 View Post
im have an issue at the moment...i have a 3racing f109 which i tried for the first time yesterday....just did donuts...anyway im thinking of either getting an f104 pro or a sakura fgx.....hmmmm we run on asphalt and then i see the f104x1.....and then theres the f104 black special......we will be running on rubber tires....
the reason i really want to go to tamiya is that i used to run them years ago....so you could say im used to them....
back to my issue.....would the pro be just as good as say the x1 and black special...apart from all the bling bits and other mods???....thanks in advance
the only difference between the varus f104 kits is the tuning parts included. For rubber tires the x1kit would be the best choice
mtveten is offline   Reply With Quote
Old 03-19-2012, 01:22 PM   #7907
Originally Posted by durtbag View Post
Are you running on rubber or foam? What size is the track? Roll out is more important. Just ran an event on rubber, big track 100x60 and was geared at 96/35 Roll out of 72mm. Had nice torque and top end.
I thought rollout was considered if you are running foams, gear ratio if rubber ( as tire diameter doesn't change like it does with foam). Running rubber.
J-PaP is offline   Reply With Quote
Old 03-19-2012, 01:34 PM   #7908
MikeR's Avatar
Trader Rating: 14 (100%+)
Re: F109- Tires tires tires and details details details. Just switching the chassis out will not solve the donuts problem.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-19-2012, 06:10 PM   #7909
ChadRacing's Avatar
Does anyone know where I can find the Black or Blue aluminum motor mounts? I have looked at several places and everyone is on order. I have been trying to find these parts for months.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 03-19-2012, 06:12 PM   #7910
Howler's Avatar
If you can't find them at any of the hobby shops (support them first), try ebay.
Howler is offline   Reply With Quote
Old 03-19-2012, 11:24 PM   #7911
blade072's Avatar
Trader Rating: 98 (100%+)
right here are the tires i was using
all pit shimizu for 103 chassis
0548-R3 rear
0543 F1-M front....
think i needed to go soft rear and hard front another words
the opposite to what i have done....i also have a set of soft fronts..
main shock had 60wt oil and standard kit in the dampening tube...
standard kit springs all round
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-20-2012, 06:42 AM   #7912
Csaari77's Avatar
Trader Rating: 34 (100%+)
MuchHobby in Canada has some motor mounts in blue.
http://www.muchhobby.com/shopping/pr...oducts_id=2818
It might be cheaper to hit up Fleabay though.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-20-2012, 07:16 AM   #7913
ChadRacing's Avatar
Thanks, but after seeing what shipping would be and the time for shipping, I went to Fleabay. I was able to find the limited edition black motor mounts NIP. Should be here by the weekend.
Team Durango DEX210
Old 03-20-2012, 09:18 AM   #7914
Trader Rating: 45 (100%+)
Anyone know what the stock parts numbers are the for F104W rubber tires and rims?
Apex is offline   Reply With Quote
Old 03-20-2012, 12:51 PM   #7915
Trader Rating: 69 (100%+)
My thoughts exactly
Nice TCS Win this past weekend.
Rear wheel A parts 19338097
Rear Inner Sponge (hard) 53255
Front Wheel F parts 19338096
Front Inner Sponge 19805597
The manual says Tire Bag (front x2 Rear x2) 19408053
Markus is offline   Reply With Quote
Old 03-20-2012, 12:54 PM   #7916
Trader Rating: 30 (97%+)
hi which is a better car to get for tarmac, and high grip carpet, f104 pro or f104 x1 thanks
zaraz is offline   Reply With Quote
Old 03-20-2012, 02:09 PM   #7917
Howler's Avatar
0548-R3 rear
0543 F1-M front....
Correct me if I'm wrong guys, but I think 60wt in the center shock is way too heavy. That may be a big part of your problem. Try 30 with the softest spring that you can put in.
Old 03-20-2012, 04:56 PM   #7918
Originally Posted by Markus View Post
My thoughts exactly
Thanks for the part numbers! As for TCS, I just wanted to get a clean run in the 3rd qualifier to get to 24 laps to at least be on pace and had no idea I was on a TQ run. In the main, I wasn't the fastest, but was able to get another pretty clean run to take the win.
Old 03-20-2012, 05:59 PM   #7919
Trader Rating: 1 (67%+)
What foam do you guys run in your Pit Shimizu tires? (571 and 572 tires)
supertech is offline   Reply With Quote
Old 03-20-2012, 06:39 PM   #7920
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
x1
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
