Like Tree4Likes
Old 03-01-2012, 04:19 PM   #7786
Howler's Avatar
Originally Posted by J-PaP View Post
Anybody tried running their x1 without the roll damper?
I snapped mine first race yesterday and ran the next race without it before it was rained out for the night. Car actually really ran well without it.
Quite rediculous that you have to buy a whole upper deck assembly to replace the roll damper as it is the 3rd time I've heard of someone snapping theirs.
I've got a friend of mine who is currently working on milling an aluminum piece for the inner core of the damper. If it works out, I'll post a pic. I'm sure that it won't be as much as tamiya wants for it.
Howler is offline   Reply With Quote
Old 03-01-2012, 05:49 PM   #7787
TryHard's Avatar
Originally Posted by rays_tt View Post
Hi guys, I just finished building my f104 pro and was having troubles getting my batteries to fit.
I have 2 types as show in the pictures below.
The IP battery doesnt even slot in at all and the yeah racing fits however I cant fit the small battery secure piece as theres not enough room up top, any suggestions or am I not using the correct type of batts?
cheers
The square case you won't be able to slot in, you'll have to remove the top deck, and then put the pack into the car. Will also need to mod the wings as well (remove the lower C-loop).
HiH
Ed
Old 03-01-2012, 06:22 PM   #7788
ioyasm's Avatar
Originally Posted by dman18t View Post
I'm in Canada, and our TCS races are rubber only carpet or asphalt, that's why I was asking if anyone would like to add to David Jun's guide with thier own experience with Tamiya rubber.
Any tricks or tips would be appreciated.
if your on carpet crazy glue very outside edge of front tire then just put tire compound on inner half and full rears try that if rolling do less on front tires i run the option hard front and soft rears
ioyasm is offline   Reply With Quote
Old 03-01-2012, 06:25 PM   #7789
durtbag's Avatar
cheers
I had to file down the battery retainer clip thingie to make the rounded style batteries fit. See pic.
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 03-01-2012, 08:26 PM   #7790
R-Sector's Avatar
cheers
This may helphttp://rsector.com/index_eproduct_vi...?products_id=2
R-Sector is offline   Reply With Quote
Old 03-01-2012, 08:38 PM   #7791
rays_tt's Avatar
Trader Rating: 26 (100%+)
thx durtbag, TryHard & R-Sector for the tips
This one shouldn't have any issues fitting without modifications should it? as its dimensions are almost identical to a stick pack?
www.melbRC.org
rays_tt is offline   Reply With Quote
Old 03-01-2012, 10:21 PM   #7792
Pro10noob's Avatar
That the IP is to big i can understand, but the 3200MAH one won't fit??
I drove the F104 with the Zippy Flightmax 4000MAH hardcase in it without any problems and those are square.
Not like the 3200MAH your trying to fit.
regards Roy
cheers
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-02-2012, 12:31 AM   #7793
cheers
I run that exact IP battery in my F104pro. Fits well...
If your running the factory plastic part at the back of the main chassis you need to file a small back on the inside of both sides to make it fit. If Your running the alloy one (I am) no filing is needed.
The 2 side bits that pivot (the plastic bits that you mount the ESC and receiver on) need to be filed on the inside to allow the battery to fit between them, no biggy though.
If your running the factory plastic battery holder, stop thing you need to file some off to fit it properly, although again with the alloy one you don't need to.
If your running a split top deck running the wire out the top is fine, no issues. If your running the factory top deck you just need to file a small amount off each side just enough to allow the wires to fit nicely.
Using that battery is good as I found with the side exit wire batteries foul on the body and you have to stretch it on, to exiting ones are much better!
Hope this all makes sense!
FST4RD is offline   Reply With Quote
Old 03-02-2012, 11:20 AM   #7794
Can't wait to race my F104 pro again I'm hooked. Need to work on my setup a little bit and I can gear it up a lot more. So awesome to drive with the new tekin rs an tekin redline motor!
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 03-02-2012, 10:36 PM   #7795
i have been told that the 104 and x1 have been discountinue? is this true and do tamiya have new cars to come out?
freakyfreakyflo is offline   Reply With Quote
Old 03-02-2012, 10:41 PM   #7796
Taman's Avatar
Trader Rating: 64 (100%+)
I've heard that they have both been discontinued. Tamiya have just released the 84262 F104W GP Edition (w/Body & F103 front end). You can still buy the F104 and F104X on Ebay/ Banzai Hobby etc.
In ref to the F104X roll damper - apparently the 54342 RM-01 Aluminum Roll Damper Set fits ($11.10 + postage from Stellamodels.net)
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 03-03-2012, 06:57 AM   #7797
rays_tt's Avatar
thx for the tips guys, managed to get my 3200 to fit nicely
www.melbRC.org
Old 03-04-2012, 10:05 AM   #7798
Quick report from our local race:
-plastic Diff is completely useless.... *pick your favorite metal* do much better work
- wider front axle is perfect thing! Without it a lost a round or two per ride (+-40 rounds)
- need to improve something .... first rider got 44 rounds.. (republic champion), second one was his daughter (junior republic champion) with 43, and after that there were me and another five riders in same round - 41, and when someone crashed, I have only chance to catch up others - they will crash too, almost no chance to catch up someone "naturally" after crash
but on the other hand, it was fun!
SquirrelCZE is offline   Reply With Quote
Old 03-04-2012, 08:22 PM   #7799
ChadRacing's Avatar
does any company make and t-plates out of spring steel? Im tired of breaking normal t-plates. I just dont have the option of getting the F1R yet
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 03-04-2012, 09:42 PM   #7800
TryHard's Avatar
If your breaking the high-traction t-bar (with the cut-out) I can strongly recomend switching it out for a 3racing 1.3mm T-bar... doesn't have a cut-out, and is just as flexible.
I found the cut-out on the tamiya t-bars to be a real weak point, just isn't enough material. On the other t-bars, it's the screw holes elongating that kill them..
HiH
Ed
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
