Like Tree4Likes
Old 02-22-2012, 04:17 AM   #7726
dfx
dfx's Avatar
Originally Posted by BrandonC View Post
1. What diameter foam tire seems to work best for short carpet tracks?
2. What is the weight that seems to work best for you?
3. Is there any things that are super important when setting this up for carpet?
Hey Brandon,
1. 58 (F) and 61 (R) mm diameter works fine for me at the moment
2. Short lipo, low profile servo and SP 1 cell motor are making a good package for me. The car is lighter than with regular equipment...
3. This is up to drivers feeling but rear ride height 6mm, front ride height 4mm, Tamiya A rears and Tamiya B fronts, carbon lower deck and X1 upgrade with all 4 posts, not too much of a camber, dif not too tight, traction compound for rears and maybe 1/3 of fronts for the morning runs and it makes my car predictable and with enough steering.
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 02-22-2012, 05:06 PM   #7727
robk's Avatar
Trader Rating: 22 (100%+)
Hey guys! My names Brandon and I'm new to this forum and F1 style racing.
I've been running my f1pro on carpet for a few weeks now and its slowly getting dialed in, but i still cant seem to keep it from traction rolling without being to tail happy in the corners, so I have a few questions for people running on carpet.
3. Is there any things that are super important when setting this up for carpet?(sound like a stupid question)<<<noob
Any help is greatly appreciated!
Brandon C
Brandon were you at Winthrop harbor last night?
Old 02-23-2012, 11:18 AM   #7728
Thumbs up The Track
Yep that was me traction rolling Thanks again for the front uprights! It helped a lot. I owe you one...well 2 haha
I ended up just signing up on here so i got about 500pgs to read to catch up but I also found your blog which I find extreamly helpful. I'll be heading back there saturday to give a bunch of your settings a go.
Your car is insanely planted and you make it look easy every time I've seen you race.
You got any advice for that track?
BrandonC is offline   Reply With Quote
Old 02-23-2012, 05:23 PM   #7729
BCZero's Avatar
Hey all,
Has anyone noticed any aero difference by using the body without the side pods installed? Im currently weighing up pros and cons...
so far:
Pro: Easier to cut out , stronger?, lighter
Cons: Looks arent as sleek, side pods only glued/taped (fragile?)
anyone else had a play with one way and the other got any feedback?
Thanks in advance!!
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 02-23-2012, 07:04 PM   #7730
I)arkness's Avatar
Originally Posted by BCZero View Post
Hey all,
so far:
Thanks in advance!!
i would think that there would be very little aerodynamic affects if you are running say a 540 silver can, although if using a 21.5t faster then it may benefit.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 02-23-2012, 07:12 PM   #7731
BCZero's Avatar
Thats what im hoping ta
Old 02-23-2012, 08:09 PM   #7732
Taylorm's Avatar
use drywall mesh and shoo goo on the inside to secure the pods and they will be anything but fragile...
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 02-23-2012, 11:18 PM   #7733
robk's Avatar
This:
https://docs.google.com/file/d/0B4jX...jU2/edit?pli=1
If you're back next Tuesday we can go over your car.
Old 02-24-2012, 12:48 AM   #7734
Thumbs up
Thats what I've been working on copying fOr the past few days buy I don't have a way to turn down my tires so I'm lowering it as much as I can but what lube u run on ur diff?
I'll b there all satuday maybe Sunday and Tuesday for sure.
BrandonC
Old 02-24-2012, 01:03 AM   #7735
Hey all,
Hell I can't tell any handling difference when the rear wing breaks off...I doubt the body will make any difference other than looking much better.
Old 02-24-2012, 01:46 AM   #7736
the tamiya rubber tire.the option tire is hard,what does that make the kit tire? is there difference between them good or bad?
freakyfreakyflo is offline   Reply With Quote
Old 02-24-2012, 09:23 AM   #7737
F N CUDA's Avatar
Trader Rating: 30 (100%+)
We have always referred to the 104 kit tires as medium compound, there's a tiny N on the sidewall.
The Option front is a hard compound and the Option rear is a soft compound, these both have a tiny W on the sidewall.
The hot setup is kit/medium fronts with Option/soft rears.
If you run the Option/hard fronts you will most likely lose all of your steering everywhere and if you combine them with the kit/medium rears you will most likely lose grip everywhere, even on hi bite tracks.
Some will argue but that is my experience on these combos.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-24-2012, 10:21 AM   #7738
robk's Avatar
BrandonC
Use Associated silicone diff lube = red lettering on the tube. Eric has this on the wall.
Old 02-24-2012, 10:37 AM   #7739
nrtv20's Avatar
I donít think the wings down force effect has as much effect as their effect on the weight balance. But I agree; I donít think the aero will change much with the body add-ons.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 02-24-2012, 07:45 PM   #7740
nrtv20's Avatar
Well when I first started racing F1 this year I did it with a used car; well here is my first attempt at painting up a new body. I wanted it to look like the '96 Jordan car but I wanted more color so I used the F60 stickers for the wings; I also will use the optional 'fin' that comes in the body kit and it will also be red.
Here it is! I love it so dont hate on it too much
PS. I still have to sticker it up and put on the driver helmet.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
