Like Tree4Likes
Old 02-13-2012, 08:35 AM   #7696
theatriks's Avatar
Thanks for the info guys .....im not in the mood to change all that stuff so what im gonna do is just take everything out servo and everything ....and mount the servo per manual and just use the full front end from my f104W.....that way when my Rsector stuff comes in i can just directly put my f104 X1 front end back in with the servo mounted the way i like. I dont have the longer turnbuckles except for the flimsy steering links that come with the W kit so it just makes sense to do it this way.
theatriks is offline   Reply With Quote
Old 02-13-2012, 09:07 AM   #7697
wwddww34's Avatar
Trader Rating: 9 (91%+)
wwddww34 is offline   Reply With Quote
Old 02-13-2012, 09:36 AM   #7698
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Wait, you already have the F104W frontend? It is the same as the F103.
Just bolt it on, adjust the servo if needed afterward.
There are only 2 frontends, 103 and 104.
The 103 assembly is what turns the 104 into the "W"/wide car.
The 104W uses the same servo mounts as the 104.
Still need long turnbuckles.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-13-2012, 11:11 AM   #7699
theatriks's Avatar
Justs to see bolt it on, adjust the servo if needed afterward.
Ya sorry for the confusion basically my only problem was those turnbuckles ,,,,and i didnt want to go buy longer ones so thats why i was asking for pic to see if anybody made it work without buying longer turnbuckles. I should have explained myself better
Old 02-13-2012, 11:59 AM   #7700
gtfour93's Avatar
Trader Rating: 22 (100%+)
Just pick up one of these and your problem is solved.
gtfour93 is offline   Reply With Quote
Old 02-13-2012, 12:27 PM   #7701
ok, remember when we talk about wider axle... let's say I found one at home and I also found some 50mm rear tires... which means that I can't wait until next race... 206mm front and 215 mm rear axle... I have homemade reduction for 50mm tires (they use 4 screws) but we are gonna to buy a new part of the diff itself to use 4 screws tires... (one set to try it) so i should end with about 205 mm rear axle...
SquirrelCZE is offline   Reply With Quote
Old 02-13-2012, 12:47 PM   #7702
theatriks's Avatar
Ya thanks i probably will order those just to have but i race on sunday and i needed a solution by then .....and i know my LHS wouldnt have those.
Old 02-13-2012, 01:29 PM   #7703
F N CUDA's Avatar
I'll bet your hobby shop has 3mm threaded rod that you can cut to length and screw the ball cups on to.
Only downside is that you will need to pop one end off to make adjustments when necessary but I've done this and it aint all that terrible.
Gets you on the track right now.
Craig Hammon
Old 02-13-2012, 02:47 PM   #7704
mattwoodcraft's Avatar
To get a wider car for the time I have been using shims from my old corrally don't know if this is as good as converting but has assisted me in getting better stability on asphalt.
mattwoodcraft is offline   Reply With Quote
Old 02-13-2012, 02:48 PM   #7705
The 3 racing titanium turn buckles are very good also I got these on all my cars at the moment and not had any problems with them if your looking for longer ones
Old 02-13-2012, 04:14 PM   #7706
theatriks's Avatar
Well im gonna check ...good idea.....are the f104w steering links that bad to race with?
Old 02-13-2012, 06:28 PM   #7707
It doesn't even have to be 3mm...4-40 will work as well. Typically I use standard Lunsford turnbuckles and AE ball cups and just replace the ball studs with standard ones. Even some metric ones are close enough to use the AE ball cup.
Old 02-13-2012, 07:37 PM   #7708
F N CUDA's Avatar
If they have those lame s hooks on the servo saver end then yeh, that's pretty weak.
Craig Hammon
Old 02-14-2012, 03:57 AM   #7709
rays_tt's Avatar
Trader Rating: 26 (100%+)
Hi guys, in terms of rubber tyres would you recommend getting Ride or Shimizu's?
I'm after the best gripping rubber tyres.
Or is there something better than ride'/shimizu's I should be looking into?
Thanks in advance for the help & apologies if this has been answered before
www.melbRC.org
rays_tt is offline   Reply With Quote
Old 02-14-2012, 04:43 AM   #7710
dfx
dfx's Avatar
Originally Posted by SquirrelCZE View Post
...and I also found some 50mm rear tires... which means that I can't wait until next race...
Don't know Your local track rules, but in some other championchips is this illegal. The rules are usualy like only F1 tires allowed and max. width 45mm (F103 size)...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
