Like Tree1Likes
Old 02-07-2012, 09:22 AM   #7621
Matthijs's Avatar
Originally Posted by Pro10noob View Post
Looks great
Why not mount the elctronics the old way so you get even more weight to the rear?
This will give you more traction at the rear and the wires would be a lot shorter.
regards Roy
the cirtix speedo with fan is a bit big for the f60 body. On the side it wil touch the body. Traction at the rear is already very good with this model. Last sunday some other drivers tried my car indoor with shimuzu rubber and like it, very balanced. Also, I think ETS rules require the esc mounted this way, why else would they use a shorty lipo. It states in their rules that you must use this lipo so you can mount the receiver up front. This also give me more room to stick some lead on different places ;-) Once the outdoor track is open the real testing begins..
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 02-07-2012, 10:02 AM   #7622
Pro10noob's Avatar
I believe you can mount the electronics the way you want it.
In front of the battery, behind the battery or on the side.
As long as you use the shorty lipo and the cooling fan on the ESC.
Without fan you can't run the event from what i have heard.
If the F60 body has not enough room at the side to place the esc at the side this would be the best way i think.
Your car should be well balanced with the pitszu's as they are great tires.
The downside is, you have to run Ride tires at the ETS and that is a whole different ballgame.
Front and rear you have to use the same hardness of the tires.
Only thing you can do if allowed is use hard inserts at the front and soft at the rear.
Perhaps you can mount the battery like the F103?
This will free up even more room to place the electronics to the rear.
regards Roy
Ps mooi auto Matthijs
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-07-2012, 09:44 PM   #7623
Trader Rating: 15 (100%+)
anybody build an f60 or mclaren body and not use their mirrors have any for sale? pm if you do please
fatboysracing is offline   Reply With Quote
Old 02-07-2012, 10:15 PM   #7624
TryHard's Avatar
regards Roy
The Rides aren't the same hardness F-R... they may both say H1 on them, but believe me the rears are much stickier than the fronts. I know as we have to use the same tyres for TITC, and they really aren't too bad, but the wheels to warp after some hits.
Ed
Old 02-08-2012, 01:12 AM   #7625
Pro10noob's Avatar
Thanks for clearing that up
regards Roy
Ed
l===/o\===l
Old 02-08-2012, 09:45 AM   #7626
Oortael's Avatar
Here is my F104Pro. The cabling was inspired by this thread :-)
Oortael is offline   Reply With Quote
Old 02-09-2012, 11:37 AM   #7627
Hello
we are using Kinetic ESC and Kinetic Spec ESC on ours f104gts and f104s... but, while Kinetic are both OK (2 cars) there are problems with the Spec's ones which are in F1... (2 cars) one is not functionable anymore and another one do not report temperature correctly....
our Novak's representative in Czech Republic said that Novak wouldn't use PC controlled ESC anymore, which is pitty....
so I'm asking, which ESC we should use in F1 cars? What we need:
A. 21.5T motors, and i would prefer to use Novak's Ballistic motors....
B. Timing, Boost esc... in my country limits are only set to: "21.5" motors so in result F1 can have loss only 1 second on round compared to 2WD Open.... so timing stuff is usefull
C. PC programming... In most of time I can set my ESC to track much faster that others, which is ... handy
I also added some photos of my F1 to this post...
EDIT: the photos are not from F1 used to ride! i am just rebuilding it, just now I am missing "side post?" (not sure of right word) so I used screw to attach what i need...
P.S: if you have any suggestions how to improve my F1... I am ready for it, but Exotek stuff is more or less banned for me, I am in the middle of Europe and do not know about a single Exotek seller here...
SquirrelCZE is offline   Reply With Quote
Old 02-09-2012, 02:17 PM   #7628
Trader Rating: 37 (100%+)
Is the F104 Pro the most current Tamiya F1 car?
It seems out of stock or discontinued everywhere. Just looking to get into F1 stuff :P
Nexus is offline   Reply With Quote
Old 02-09-2012, 02:24 PM   #7629
Does anyone know of a place that may have a 104x1 in stock anywhere? I can't seem to find one at all. Are they all gone? Wanted to build one up for the Nats.
DJG24 is offline   Reply With Quote
Old 02-09-2012, 02:52 PM   #7630
mattwoodcraft's Avatar
they have stopped making them now unless your lucky enough to find one still in stock
mattwoodcraft is offline   Reply With Quote
Old 02-09-2012, 02:54 PM   #7631
Csaari77's Avatar
Trader Rating: 34 (100%+)
I've seen a few on Fleabay but that's it!
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 02-09-2012, 05:56 PM   #7632
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
Originally Posted by SquirrelCZE View Post
Hello
ive run the tekin rs and the rspro and both have been great! fully programmable. as far as exotek, bpshadow can probably get you the stuff. he takes care of f1paintlab.com
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 02-09-2012, 07:03 PM   #7633
TryHard's Avatar
regards Roy
Couple of other things to point out about the Ride's;
1) the wheels are a bit, umm, flexiable, and do tend to warp after a few hits... so try not to whack stuff!
2) Because the wheels are a smaller internal diameter than tamiyas (sidewall of the rubber is bigger), front ride-height is resticed to about 6mm minimum! Any lower than that, and the bottom of the kingpin will start to rub on the inside of the wheel.. so unless you lower the front 12th scale style (shims under the suspension mounts.. now there's an idea!), you simply can't get the front end any lower
HiH
Ed
Old 02-09-2012, 09:30 PM   #7634
Can a regular F104 kit be made into a "X" by purchasing the parts?
Couldn't find a listing of parts specific to the X upgrade.
Old 02-09-2012, 09:59 PM   #7635
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Here's where and what I used for my conversion.
Tell em 'cuda sent ya.
http://www.speedtechrc.com/store/ebp...d=774&id=12084
http://www.speedtechrc.com/store/ebp...d=774&id=12083
Craig Hammon
F N CUDA is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
