Like Tree1Likes
Old 02-01-2012, 11:10 AM   #7576
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by theatriks View Post
Is it worth it to put the f103 front end on the x1 ...does it make that much of a difference?
If you want a wide F1 it's the way to go
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-01-2012, 11:52 AM   #7577
dfx
dfx's Avatar
Originally Posted by BP SHADOW View Post
Yup, 3X42 for the 103 frontend
Thanks BP.
Different size of wheels plus 2cm of width should be good for cornering or stability on straights...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 02-01-2012, 12:01 PM   #7578
theatriks's Avatar
so what your saying is it will make the front end same width as the rear ?
theatriks is offline   Reply With Quote
Old 02-01-2012, 12:03 PM   #7579
theatriks's Avatar
Originally Posted by dfx View Post
Thanks BP.
ok so i cant run f104 pits on the f103 front end ..arg time to place another order lol
Old 02-01-2012, 01:04 PM   #7580
NiMo's Avatar
Front end should be ok.
Rears are different offset so you'd need F103 sized rears
NiMo is offline   Reply With Quote
Old 02-01-2012, 01:08 PM   #7581
theatriks's Avatar
ok so i can run the pit 571s on the f103 front end but need the f103 pits for my x1s rear end
Old 02-02-2012, 03:21 AM   #7582
dfx
dfx's Avatar
You have to make front end and rear end the same by using F103 frond end and F103 wheels (the easiest way)... F104 wheels do have bigger diameter so it is better to use all 4 wheels with F103 size. Please correct me if I'm wrong...
Tamiya TRF 416 WE
Old 02-02-2012, 03:53 AM   #7583
mattwoodcraft's Avatar
looks like i to will be placing a order and will try the 103 front end with the wheels. sounds like a good idea
mattwoodcraft is offline   Reply With Quote
Old 02-02-2012, 05:36 AM   #7584
Trader Rating: 19 (100%+)
I got a f103 front end if you want, only have foam tyres though, no rubber tyres.
If you're running the states at PRECC, slap the 103 front end on, get some f103 soft xceed rear foams and f103 medium xceed fronts and you will kick ass.
LordAnubis is offline   Reply With Quote
Old 02-02-2012, 07:40 AM   #7585
theatriks's Avatar
For those of you using the f103 front end are u swaping in the f103 servo mount and steering links too ?
Old 02-02-2012, 08:22 AM   #7586
lightfoot's Avatar
Default UF1 Series
6th race of the 2012 UF1 Winter series will be this Saturday February 4th at TQ raceway in Chino California...
Doors open at 10 AM and qualifying starts at noon....
http://uf1series.com/index.html
Love and Peace...
lightfoot is offline   Reply With Quote
Old 02-02-2012, 09:31 AM   #7587
Pro10noob's Avatar
Running the F104 servomount and long topdeck here.
Works perfect.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-02-2012, 11:25 AM   #7588
F N CUDA's Avatar
You can use the 104 servo mounts with the 103 front end no problem, you cannot use the 103 servo mounts with the 104 front end since the 104 front end needs the extra support for the rear of that assembly.
So as mentioned above you only need the 103 front end, longer tie rods, and your choice of 103 wheels and tires.
I'm curious as to why you want to change to the wider car when the narrow car has proven to be very, very competitive when it comes to racing on rubber tires since the Pit Shimizu combo is kicking serious ass now.
If you are however racing on foams I understand completely since the premount 103 tires and other similar combos will most likely destroy the combos available for the 104 sized tires and rims.
Craig Hammon
Old 02-02-2012, 01:05 PM   #7589
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
Default WTB F104
Sorry to post here but I got a tip from a reliable source that I might find what I'm looking for here. I'm looking for a F104 roller to build into a F1R for the upcoming Carpet Nats. Thanks! *fingers crossed*
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 02-02-2012, 06:29 PM   #7590
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i got a complete rear-end off a 104Pro, graphite axel, aluminum diff, aluminum motor plates, spur gear adapter, damper plater (just plate and parts, not shock)
shoot me a PM if interested
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
