Like Tree4Likes
Old 01-27-2012, 08:28 AM   #7501
nrtv20's Avatar
What is everyone’s opinion on running different battery sizes?
Light battery better in corners?
Light battery loose tendencies?
Push with heavy battery?
More grip with heavy?
I have been running a 5000mah battery and I can’t seem to get the car to turn in very hard; I am running a F104 Pro. I use Shimizu 575/577 combo; kit t-plate; 2 deg camber; Soft center spring (only one I have); silver fronts (soft) heavy lube on friction disc. Mainly the rear end of the car is stiff and the front is soft.
Only suggestions I can come up with is heavier center spring and/or split upper deck.
I’m running on low grip carpet. Thoughts?
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-27-2012, 08:52 AM   #7502
idbdoug's Avatar
Trader Rating: 33 (100%+)
Maybe PS-0574 F3 Soft fronts. 3racing 1.3 t-bar or tamiya high traction t-bar also try.
Is the front ride slightly lower than rear??
idbdoug
idbdoug is offline   Reply With Quote
Old 01-27-2012, 09:12 AM   #7503
TryHard's Avatar
Has anyone run the long X1 top deck, with the revised flex arrangement?
I picked one up the other week, and had it sitting on my desk. Currently, I've been running my X1 on high grip asphlat, using a carbon bottom deck, and standard (split) top deck, with only the two forward screws in posts
(I put all the chassis posts in, but only screw in the top of the front two... really don't like the idea of having it diagonal, something fundamentally not right with that idea, IMO)
I also don't use the batery clip, so it's pretty flexible up front, with just the carbon deck... I'm wondering if the long deck would allow the car to be a little less aggressive, such that I could run softer front springs...
Anyone got any thoughts on that?
Cheers
Ed
Old 01-27-2012, 10:13 AM   #7504
Trader Rating: 70 (100%+)
I just switched to the x1 long top deck this past weekend. We had a 100+ entries for a Sweep Challenge Race.
High grip ozite carpet on a raised sub floor. lots of foam cars laying down more traction (1/12 stock and boosted, wgt).
I usually run the stock X1 bottom plate and the stock split top deck, all four post but this weekend my car felt indirect and was traction rolling with barely half the front tires sauced.
For this past weekend I ran the x1 long top deck and noticed some slight changes in the car.
Mainly for me, the switch made the car feel more direct and planted. Before the top deck my car always felt a little lofty/wander-y (not stuck down into the track) and definitely a bit rubbery in the turns.
I was able to add a wider area of traction compound to the front tires without traction rolling *Bonus* with the wider compound application, the car steered into the turns better with no fear of rolling or flipping.
For this day, it allowed me to drive the car harder.
Markus is offline   Reply With Quote
Old 01-27-2012, 10:34 AM   #7505
MikeR's Avatar
Trader Rating: 15 (100%+)
idbdoug
Yeah I agree with idbdoug, Change to softer fronts. 77's are VERY pushy. 74's have more bite and 71's have the most front bite.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-27-2012, 06:32 PM   #7506
ChadRacing's Avatar
Well...after i received the proper tires, I finally got to race my F104 X1. Thanks to everyone who helped me out on this thread with setup tips. Setup was good, with some over steer out of the corners. After a few mins into the main, I went airborne from another car pushing into my wheels. And SNAP!!! My car is damaged. Here are the resulting pics.
Tamiya F104 Pro!-f1-.jpg   Tamiya F104 Pro!-f1-b.jpg   Tamiya F104 Pro!-f1-c.jpg   Tamiya F104 Pro!-f1-d.jpg
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 01-27-2012, 06:37 PM   #7507
idbdoug's Avatar
What will these achieve in F104 Pro???
Tamiya Formula 3.5mm Offset Upright, F103/F104
I'm not sure what the stock is for Offset!!!!
idbdoug
Old 01-27-2012, 06:48 PM   #7508
idbdoug
Fit perfectly. Stock offset=0mm
prorace is offline   Reply With Quote
Old 01-27-2012, 07:55 PM   #7509
hanzo3's Avatar
Trader Rating: 55 (100%+)
Is that a metal motor mount that snapped? Yikes!
Chris • TRF419 • TA05V2 •
TQ RC Racing • Powered by teeth
hanzo3 is offline   Reply With Quote
Old 01-27-2012, 08:03 PM   #7510
ChadRacing's Avatar
No..its the stock one comes in the X1 kit. I am ordering the aluminum one ASAP.
Does anyone make a better lower plate and diffuser for the motor pod?
Team Durango DEX210
Old 01-27-2012, 08:09 PM   #7511
idbdoug's Avatar
Yeah they fit,,but what does Tamiya Formula 3.5mm Offset Upright achieve???? More steering,quicker steering,etc
thanks
idbdoug
Old 01-27-2012, 09:11 PM   #7512
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
thanks
idbdoug
usually a trailing arm is less twitchy. havent run the 104 offset hubs yet
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 01-27-2012, 10:12 PM   #7513
Howler's Avatar
You can check with D-Drive http://d-drivesportsenglish.com/
Howler is offline   Reply With Quote
Old 01-27-2012, 10:40 PM   #7514
I saw an exotek lower carbon plate broken last week so unless they start making unubtainium plates....
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
Old 01-27-2012, 10:52 PM   #7515
texastc's Avatar
great, my Exotek is the only thing I haven't broken.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and another Exotek F1Ultra on the way. And whatever is next
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom "you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
