Old 01-26-2012, 09:21 PM   #7486
Anybody had any issues with the Carbon reinforced gear case? I ran my f104 x1 few days ago and due to my incompetence setting the brake force up went sideways into a barrier. Was my first and only hit and the undertray of the gearcase (diffuser/where t bar mounts on to) snapped in half. I would have thought the weak point was the t bar?
Contemplating switching to the regular plastic for that part if the carbon reinforced one is going to break that easy.
J-PaP is offline   Reply With Quote
Old 01-26-2012, 09:30 PM   #7487
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Originally Posted by mattwoodcraft View Post
I have been using a 17.5 and getting 25m run time easy motor warm only
Was asking rcdave1.... wanted to see what he was getting on 1800mah batteries.
Dan is offline   Reply With Quote
Old 01-26-2012, 09:47 PM   #7488
texastc's Avatar
Same thing happened to my buddies pro with the stock plastic. First run too.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 01-26-2012, 10:13 PM   #7489
robk's Avatar
Trader Rating: 22 (100%+)
The carbon part is very brittle. I didn't break the actual part, but all the vanes snapped off the diffuser on mine when I raced the Tamiya USA track due to the curbs..
Old 01-26-2012, 10:23 PM   #7490
Trader Rating: 69 (100%+)
RobK is definately telling the truth, the carbon set is brittle. I've seen too many f1s broken into two pieces.
I run the aluminum motor mount set with the stock plastic under tray with no problems.
the plastic tray and aluminum motor mount worked well that way for 15 years on the 103.
Markus is offline   Reply With Quote
Old 01-26-2012, 11:00 PM   #7491
For the carbon reinforced set, I cracked the first one. For my second set, two of the fins went missing after a race.
If the second set cracks again, I'll switch back to the plastic one, never had problem like that.
eComet is offline   Reply With Quote
Old 01-26-2012, 11:24 PM   #7492
MikeR's Avatar
Trader Rating: 14 (100%+)
High grip track with foams and 21.5 I would get about 8min tops with the 1800. Low grip conditions may get a few more minutes but then can negate the benefits of a lightweight pack.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-27-2012, 01:48 AM   #7493
I went through 3 carbon bottom plates and one T-Bar on my first weekend. I'm going to try the regular plastic next.
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
Old 01-27-2012, 01:54 AM   #7494
The only part I have managed to break on my F104Pro is the rear wing! Broken a few, doesn't take much, small hit from behind, flip it upside down etc.
What other rear wings do people use? Are some better then others? Stronger then other?
FST4RD is offline   Reply With Quote
Old 01-27-2012, 04:35 AM   #7495
rcdave1's Avatar
I've never ran the battery till it dropped off. Our club races are 6 minutes so I very seldom practice any longer than that. I run a 21.5 ballistic geared at 93/29 and when I come off the track and charge my voltage is 7.6v with very little heat in the motor.
Dave Banks
rcdave1 is offline   Reply With Quote
Old 01-27-2012, 05:19 AM   #7496
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I have cracked the plastic one, but it had quite a bit of running on it. I have not run the carbon one yet, will probably keep it as a last resort spare
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 01-27-2012, 05:49 AM   #7497
Thanks for the responses. Well I have ordered both and will try the carbon one again first then if that breaks as well I have a normal plastic one anyway.
Surely won't break both in 1 meet.
Old 01-27-2012, 06:10 AM   #7498
mattwoodcraft's Avatar
I was thinking of getting the carbon bottom plate but now I think I will keep with the kit one I haven't needed to replace as yet have had some good crashes and hard hits I bought another stock one for spares
mattwoodcraft is offline   Reply With Quote
Old 01-27-2012, 06:24 AM   #7499
Taylorm's Avatar
.........i also broke 2 plates and one tbar my first race........
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 01-27-2012, 07:26 AM   #7500
Try TRG "Standard" wing (not the "advance").
It's super flexible and holds the abuse very well
prorace is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
