Tamiya F104 Pro!
#736
F125
I was looking @ the results of the F1 series in Japan and the winner of the race and the constructors cup was the Tech Racing F125. It has a similar battery layout to the 104 but mounts the electronics on the wider lower chassis plate which leads me to think that the layout has potential. The 104 has some abilities that we need to exploit (turn exit on power stability) and some weaknesses that need to be overcome (off power steering, twitchiness). What the 103 didn't have was this forum to fast track it's competitiveness. Anyway, the 104 just looks so much better with it's sculpted sidepods especially with the upper winglets removed
#738
There is definitely potential in the F104. If we were able to run the F103 tyre combo, it would be a massive help.
I don't have a F103 but I reckon it is probably some 15-20mm wider and the rear tyres alone would be 8-10mm wider... LINK
i completely agree... some one needs to manufacture rubber tyres for the 104
#739
#740
Ive been using F103 tyres and rims on my 104, I started with Zen 25s on the back which made a huge difference to the handling, hardly spins. I was running kit foams on the front which gave a few problems with turn in. so i turned the dual rates back up and that made a huge difference, easily keeps up if not leaves the F103s behind through the infield. As a trial i put Zen 38s on the front, bit too much grip in the front now so has been spinning alot. Im still new to this F1 buzz so as far as t-bar and shock settings are concerned im not sure where to start, I might try 40s on the front to see what that does.
I had to put a spacer in between the arms to get the pin to clear the F103s smaller front rim and run 850 bearings so they will fit the F104s uprights. Check out the angle of the top arm when you put the spacer in
#742
Yeh pics would be great!
#744
Hey guys
i have taken some photos and will upload them soon, stay tuned
#745
#746
Thanks for the pics junn! Do you mind doing one more - from above showing the whole car. Just want to see the widths of front vs rear. Thanks!
#747
IF you add the spacer you'll probably have to put a softer spring on as it preloads the existing spring so youll end up with a hard setup on the front
Dont overtighten the wheel nuts as the 850s wont like it. Its way more stable with the F103 rear wheels
My next tuning option is to try the TRG rubbers as thats what everyone uses in our club, apparently theyre the tyres to use, I can keep up with an F103 running TRGs with Zen 25s on my F104
Dont give up on this car boys, keep up the good work.Sooner or later we'll run rings around the F103 and F109
#748
#749
Looks like about a 2mm spacer that you've added?
Good to know that we can now fit fron F103 wheels
#750
Nah its a 1mm spacer.
Well i was stoked but thought that surely someone would have figured this out by now, thats why i hadnt posted it, ive been running my car like this for about 4 weeks now.
I almost bought F103 uprights
I definately need to learn how to adjust the rear end though, theres so much adjustment between the FRP plate and the shock, and the slip in the diff
You guys have any luck with diffusers? what about those 3racing FRP t-bars?
