Old 01-23-2012, 03:01 AM   #7471
i just have a silver can motor with a futaba esc.
i bought it like this and i
have no idea about setup for these cars
mitchie is offline   Reply With Quote
Old 01-23-2012, 09:12 PM   #7472
hanzo3's Avatar
Trader Rating: 55 (100%+)
Is the Clamp wheel hub a recommended hopup? What does this do exactly?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 01-23-2012, 10:47 PM   #7473
texastc's Avatar
I like it, I have one on my Exotek F104R and my F109. I was having problems with the wheel flying off of the graphite axle, I don't know about anyone else, but I like it. It just secures the hub to the axle better and at 2 points instead of one. And it eliminates the axle spacer.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 01-23-2012, 10:53 PM   #7474
Odin544's Avatar
Trader Rating: 93 (100%+)
I'd run it on a carbon axle. But it's not necessary on a steel axle.
Odin544 is offline   Reply With Quote
Old 01-23-2012, 11:24 PM   #7475
If you buy the clamp wheel hub you cannot run the new counter weight as found on the F104X1, now available seperately as a hopup part too.
mr lee is offline   Reply With Quote
Old 01-24-2012, 12:18 AM   #7476
hanzo3's Avatar
What does the counter weight do? It goes on the left wheel?
Chris TRF419 TA05V2
Old 01-24-2012, 06:16 AM   #7477
mattwoodcraft's Avatar
It's ment to prevent to torque steer but I can not really tell the difference with it on or off personally. I was running 10 g on the back left diff user it pretty much done the same thing
mattwoodcraft is offline   Reply With Quote
Old 01-24-2012, 07:30 AM   #7478
Arahawak's Avatar
Trader Rating: 32 (100%+)
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 01-25-2012, 06:53 PM   #7479
MrChodes's Avatar
Instead of just a grub screw securing the hub to the axle, the clamp hub has grub screw and another screw - the clamp.
I really like the clamp hub as I really tighten down the diff side with loctite making it basically permanent. The clamp on the left makes it easy to get a tight secure fit of the hub with little risk of stripping screws.
So I can reliably disassemble from the left side.
Tamiya version is one piece - has no axle spacer. This means the clamp screw and the grub screw are far apart so I think clamps very securely.
Other brands have the axle spacer like tamiya std hub so you may be able to use the counter balancer.
Serpent S100. Ducati FM1-e bike.
MrChodes is offline   Reply With Quote
Old 01-26-2012, 07:24 AM   #7480
idbdoug's Avatar
Trader Rating: 33 (100%+)
Has anybody used this:::Tamiya F-104 1800 mAh Micro LiPo Battery Conversion Kit::::::It's being sold on ebay at the following link::
http://www.ebay.com/itm/320753738072...84.m1423.l2649
idbdoug
idbdoug is offline   Reply With Quote
Old 01-26-2012, 07:53 AM   #7481
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
idbdoug
ive never even seen that before, but i like it!
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 01-26-2012, 08:03 AM   #7482
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
That conversion looks pretty cool. Like how it allows you to clean up the electronics wiring too.
Dan is offline   Reply With Quote
Old 01-26-2012, 09:16 AM   #7483
rcdave1's Avatar
Trader Rating: 14 (100%+)
I run the 1800mah battery but I didn't use the conversion, just taped the battery in across the chassis. I run it forward as my rec and speedo are behind my battery, really let's you clean up your wiring!
Dave Banks
rcdave1 is offline   Reply With Quote
Old 01-26-2012, 09:21 AM   #7484
Dan
Dan's Avatar
What motor are you running and how much run time do you get?
Old 01-26-2012, 02:35 PM   #7485
I have been using a 17.5 and getting 25m run time easy motor warm only
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
