Old 01-15-2012, 04:36 AM   #7381
TryHard's Avatar
Originally Posted by texastc View Post
Looks like I had it all wrong. I checked out some video's. And seems I totally misunderstood something. Must have gone by memory. lol
Still, don't know for sure this was causing the C clips to fall off.
The only reason I could see fro the clips coming off would be on the bottom, if the clip touches the wheel (like it does with the Ride rims that have a smaller diameter). I've been running that front end setup for a long time, certainly prefer it to the stock version.
HiH
Ed
Old 01-15-2012, 02:38 PM   #7382
texastc's Avatar
You may be right. I have added some spacers above the steering block and on top of the arm. There was some play in the kingpin. Quite possible they were rubbing the wheels. I lost 2 bottom and 2 top C clips yesterday. But it just started happening last week. Must have inadvertently took some spacers off and not replaced them during a change. Makes sense.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 01-15-2012, 03:03 PM   #7383
Kingpin play is what you use to adjust front droop. Having no play could result in having no droop depending on what spring you have up front. E-clips/C-clips popping off is just something that happens...especially those funky ones Tamiya uses on the bottom to hold the spring on. Those ones wear out quickly if you take them off a lot to do spring changes. On the F103 I use to swap those out with the same kind they use on the top of the kingpin as that held tighter...but they are harder to change springs with.
Old 01-15-2012, 04:00 PM   #7384
liteweight's Avatar
Default starting gears for carpet
Guys im new with F-1 , I need a starting FDR or Spur and Pinion for carpet, Im running 21.5 brushless no boost on 70 x 40 track size?
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 01-15-2012, 05:19 PM   #7385
texastc's Avatar
I'm running between a 30/96 and 35/96 depending on the mood.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 01-15-2012, 05:36 PM   #7386
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I'm at 38/93 with 30* timing on carpet and run about 150* after 10+ minutes on my Novak Ballistic.
I saw that Hideo dude from Japan/Futaba ran 40/88 and preferred 0 timing when he had visited us at TQ carpet track. Oh yeh, he kicked our asses too.
Don't be afraid to gear big but check temps, it's the law.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-15-2012, 05:37 PM   #7387
liteweight's Avatar
Thanks Texastc
"MRH" Carpet racing
"Xray T3 2012"
Old 01-15-2012, 06:12 PM   #7388
texastc's Avatar
Thanks Texastc
Thank Cuda, and go with what he says. He s got way more experience in this than I do. I just post a lot.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 01-15-2012, 07:33 PM   #7389
nrtv20's Avatar
same.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-15-2012, 08:16 PM   #7390
F N CUDA's Avatar
Thanks texdude but I'm just tellin what I like, now go post again cuz your last one was #666!
Craig Hammon
Old 01-15-2012, 08:39 PM   #7391
texastc's Avatar
Muwahahahahahahaha!
I got a question too. I have the counter weight. I haven't run it yet, because I also run the clamp on left hub and a steel axle. I like the feel of the steel axle.
Does the steel axle have the same effect as the counter weight or will the counter weight just add even more rotating mass to the back end?
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 01-15-2012, 09:00 PM   #7392
F N CUDA's Avatar
Muwahahahahahahaha!
The counterweight uses bearings to help it keep from becoming extra rotating mass.
I'm running the steel axle and the counterweight. Can I tell?
I'm not telling you. cuz I can't tell
Craig Hammon
Old 01-15-2012, 09:26 PM   #7393
TryHard's Avatar
Actually, I can jump in on this... as I broke my carbon axle last meeting, and switched to the steel.
Was the only change I made, but it made the car feel it had more rear traction... I likey!
Old 01-15-2012, 09:42 PM   #7394
texastc's Avatar
I went back to steel axle last weekend right before the main. I had used it before in my F109 but not in a narrow. I immediately felt the difference, back end felt planted and very good in the infield. Ill try the counter weight when someone lends me a regular wheel stopper. I have 2 of the clamps.
back on the subject of the front end. Whats the benefits of running with and with out the caster plate spacers?
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 01-16-2012, 03:29 AM   #7395
JamesHealey's Avatar
The only thing i noticed changing back to the steel axle was the drop in punch out of the corner, sort of a lack of spin up/torque delivery.
Which I guess makes the car easier to drive and less likely to spin out which can be seen as traction? I still prefer the carbon axle as it's got that awesome ability to snap the rear end out with a quick blast of the throttle if needed, where as he steel wouldn't do that for me in the same controlled manor.
The only time i've ever needed to flick the end out though was if i'd entered a corner too hard and needed to get the car to rotate quick and controlled.. opposite lock power slides for the win!
driver preference for sure. I've also not managed to snap my carbon axle yet.. but i've managed to bend every single steel one within a few days.
Durability is king really, if you've got no rear axle you're not going racing.
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
