Like Tree4Likes
Old 01-07-2012, 10:27 PM   #7291
ChadRacing's Avatar
Can someone help me out with my issue. I ran my F104 X1 tonight for the first time. the front end of the car is planted but as i roll into the throttle the rear tends to wash out. What can I do to fix this issue. My setup is below:
Ride height: 4mm
tires: Tamiya front soft, tamiya rear soft( I sauce entire rear and front 1/4 inside edge)
Front springs: kit mediums
Center shock: 40wt oil, kit soft spring
Roll dampener: kit grease
Camber block: 1.5
Toe 0.5 deg toe out
Motor: 21.5
ESC: tekin set to blinky
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 01-07-2012, 10:32 PM   #7292
racer x 1's Avatar
Trader Rating: 27 (100%+)
Ride height: 4mm
Camber block: 1.5
Toe 0.5 deg toe out
Motor: 21.5
id try softening the oil in the center damper.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-07-2012, 11:23 PM   #7293
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
Ride height: 4mm
Camber block: 1.5
Toe 0.5 deg toe out
Motor: 21.5
it sounds like youre on asphalt? maybe add some weight to the rear pod and add some negative throttle expo(curve) to soften the punch a little?
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 01-08-2012, 12:32 AM   #7294
Odin544's Avatar
Trader Rating: 93 (100%+)
Get rid of the tamiya tires and get pit shimizu.
Odin544 is offline   Reply With Quote
Old 01-08-2012, 03:25 AM   #7295
If you are using tamiya rubber tires you are better of with the hard type in front and the soft ones at the rear, you could also use the hard spring in front (steering) and use a soft grease in the side damper.
addicted2blue is offline   Reply With Quote
Old 01-08-2012, 07:45 AM   #7296
TryHard's Avatar
Finally managed to make it to a Shanghai GP race this weekend, and having tried for a few weekend to get my Rabbit/FGX fast, I gave up and switched back to my 104X1... and well, it proved the right thing to do.
Qualifed 6th on the grid, out of a field of about 45drivers, so happy with that, especially given that I was starting out in the lowest qualifying group, and the track did increase in traction during the day.
For the 30min final, I tried to predicate the track change (given I had about 4hours between qualifying and the final!!).. and got it wrong wrong wrong, and simply gave the car too much steering. By the end of the race, managed to adapt my dirivng and could turn some fast laps, but the consistency was blown out the window, and just a small error would bite back...
Stuck it out and finished 8th though. Dissapointed, but at the same time, hadn't run a 30min final before, so had no idea even I'd make it too the end with battery/motor setup. Made it, but tight on cell voltage...
But more positive was made some quick alterations after racing, namely putting the black spring on the front to stop it pitching hard when on the brakes... and straight away improved the car further, with the consistenty back too... so quite simply, can't wait for the next round
Had great fun too... and everyone there seemed happy and entertained!
Old 01-08-2012, 09:34 AM   #7297
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Ride height: 4mm
Camber block: 1.5
Toe 0.5 deg toe out
Motor: 21.5
Which tires? Rubber or foams?
You listed front soft and rear soft.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-08-2012, 11:09 AM   #7298
cementsurfer86's Avatar
Just kind of curious if anyone can help me on this, but we are heading to the TCS race at Tamiya in a couple weeks and was wondering if anyone has some gearing advice for the Tamiya USA track? It's my buddy's car and he will most likely be using a silver can.
Thanks in advance!!!
-Jesse
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 01-08-2012, 11:19 AM   #7299
ChadRacing's Avatar
I am running rubber tires. The track I am running on is a medium bite carpet. 90x45
I would like to use pit's but I just don't have any at the moment.
I do have all the compounds of rubber from Tamiya for the front and only the soft for the rear
Team Durango DEX210
Old 01-08-2012, 11:39 AM   #7300
over gear's Avatar
Trader Rating: 15 (100%+)
Tryhard. What kind of surface do u race on?
over gear is offline   Reply With Quote
Old 01-08-2012, 01:56 PM   #7301
nrtv20's Avatar
Ride height: 4mm
Camber block: 1.5
Toe 0.5 deg toe out
Motor: 21.5
What T-bar? Kit? 'High bite' soft? Softer T-bar should yeild more rear traction.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-08-2012, 02:59 PM   #7302
ChadRacing's Avatar
The t-plate is the high bite that comes in the kit for the f104 X1
Team Durango DEX210
Old 01-08-2012, 03:19 PM   #7303
ChadRacing, seems like too much front grip. Not sure but I've never seen a Tamiya soft front rubber tire, only hard (optional) and kit (medium).
How's your diff? Smooth, soft feel without slipping?
Try adding 60grms on each side of the battery (in between the rear pod and the radio trays).
Hope that helps.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-08-2012, 03:31 PM   #7304
Pro10noob's Avatar
@ChadRacing....
Try what i did with the T-bar(see pic and if allowed)
It will give more rear end grip.
Don't use the front soft tires as this will ad the rotating of the rear when putting on the power.
Use the hardest front springs(i believe the black one).
This all will give you more rear end grip and less front.
Also when you have it, run the shorty lipo's as this will put the weight balance to the rear and will generate more rear end traction.
Also and this is what i like, is put the car in the front about a MM closer to the ground then the rear.
So in your case 4MM front and 5MM rear
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-08-2012, 03:39 PM   #7305
ChadRacing's Avatar
Yeah I am running a cfc shorty pack with my esc and receiver mounted in front of the battery
Team Durango DEX210
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
