Like Tree5Likes
Old 12-30-2011, 08:00 AM   #7231
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by BP SHADOW View Post
Where do I find out more about this chassis?
http://www.sy-brand.com/new1012.html
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 12-30-2011, 08:05 AM   #7232
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by dg8one View Post
anybody have a complete part list for F104 PRO?
thanks
Nelly - Are you switching back from the EXO to the F104 Pro setup? In either case, I'll bring everything I have including the manual on Monday. I know I have everything minus the rear pod plate to get you converted back. I've got some Carbon Reinforced types coming in shortly.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 12-30-2011, 10:52 AM   #7233
Originally Posted by Csaari77 View Post
What's a good place to start on gearing and timing with the TP?
Im running a 3.6 fdr with 20 degrees timing.
Little John is offline   Reply With Quote
Old 12-30-2011, 04:29 PM   #7234
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
Originally Posted by spring71 View Post
RSector High Capacity Lipo Conversion for F104/W/PRO/X1 is available at TQ.
Click Here
FYI, Thanks.
The deck is nice! +1!!
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 12-30-2011, 05:35 PM   #7235
dg8one's Avatar
thanks
ill see you mon
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 12-30-2011, 05:40 PM   #7236
durtbag's Avatar
Originally Posted by freakyfreakyflo View Post
hello again
the kit t bar for 104pro,does it have a part number? i used mine on our carpark track and it liked it with rubber wheel
Tamiya Part#58431
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 12-30-2011, 08:27 PM   #7237
ChadRacing's Avatar
I just finished building my X1 and I am trying to figure out what gearing I need for a 21.5 that is setup for blinky mode. I also plan on running on 64p gears. Can someone recommend a starting gear set or FDR. I will also be running rubber tires on carpet.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 12-30-2011, 08:38 PM   #7238
texastc's Avatar
Someone mentioned between a 3.5 and 4.4 FDR.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 12-31-2011, 09:55 AM   #7239
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I was running 3.72 with an X12 21.5 and it felt a bit sluggish out of the corners, going to drop down a tooth or two
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 12-31-2011, 11:15 PM   #7240
Odin544's Avatar
Trader Rating: 93 (100%+)
I'm running 93/33 (2.81) and have the fastest car on the track locally. Plenty of low end and temp about 140 after 6 minutes. Ran a 10 minute race tonight and temped at 170. No fan or anything. This is on a 100x40 track.
Odin544 is offline   Reply With Quote
Old 01-03-2012, 02:40 AM   #7241
rcdave1's Avatar
Trader Rating: 14 (100%+)
Looking for the part number for the F104 pro body set. Was this body set available without purchasing the whole kit? Any help would be appreciated.
Dave Banks
rcdave1 is offline   Reply With Quote
Old 01-03-2012, 03:17 AM   #7242
51377 should be it.
J-PaP is offline   Reply With Quote
Old 01-03-2012, 06:07 AM   #7243
nrtv20's Avatar
Im 90% sure I am running a 96/34 with Pit's and I was pretty quick, temping around 120ish.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-03-2012, 06:54 AM   #7244
I finished building my X1 a couple of days ago and today finally had the chance to mount the electronics and noticed that with the added weight the front end is pretty low... I would like to have at least 1-2mm more of front clearance since my track has a couple of soft elevation in which the chassis may rub.
Is there a way to properly list the car a bit?
Oscar.
arix is offline   Reply With Quote
Old 01-03-2012, 07:18 AM   #7245
Csaari77's Avatar
Trader Rating: 34 (100%+)
You can move the spacers on the kingpins to give yourself more front ride height. To raise it up, put more the spacers above the axel.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
