Like Tree4Likes
Old 08-24-2009, 09:47 PM   #706
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Alfie View Post
No chance at all, with the rain and wet track.
Alfie
i see.. but bro, you mentioned you had one run with the cutout winglet and it improves handling.
So i wanted to know if it adds/reduce downforce? and was it with the Tamiya wing or 3racing wing? coz before I left, i think it was the 3racing wing u had on your car.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-25-2009, 01:50 AM   #707
Originally Posted by youb View Post
What is the difference between the tyre A and B?
The B is more hard?
Tks for your answer.
up
youb is offline   Reply With Quote
Old 08-25-2009, 03:19 AM   #708
InZane's Avatar
up
B are harder than the kit/standard tires (A).
A - http://www.tamiyausa.com/product/ite...oduct-id=51385
B - http://www.tamiyausa.com/product/ite...oduct-id=54168
InZane is offline   Reply With Quote
Old 08-25-2009, 03:42 AM   #709
thank you for your answer
Old 08-25-2009, 05:05 AM   #710
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
In relation to the spoiler that enhances the handling, not a single car has a spoiler before the rear wheel.
The "uncut" winglet actually makes the car planted during the in-field, but on the extreme high speed straights, it will suffer. It's not so much of the downforce, but more of the channelling the aerodynamics from front to back undisturbed, and as and when the spoiler needs to do its part, it will have have do it. I'm not sure if this theory is right, and I'm not so much of a theory person. I'm trying to make it work for all. Also in reference, the F103's range of bodies were never with the winglets. Could be due to the replications of the real thing, or purely the cost-cutting factor of not producing replica of the real thing.... Whatever it is, I'm determined to make it work.
I was on the 3Racing when I went for my run.
Alfie
F103KŠ • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 08-25-2009, 05:09 AM   #711
Arahawak's Avatar
Alfie
I see.. thanks for input
Old 08-25-2009, 06:15 AM   #712
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by InZane View Post
They may be harder, but I'm finding that they grip better at our track, even in cooler conditions. Just finished an evening run at our club - ambient temperatures were about 15degC, but the car felt much better controlled on the set of B's that I had. When I tried the A's, it was quite unstable.
Surface is medium-grip outdoor asphalt. Haven't used any traction compound.
Over the weekend I tried a different circuit (Whalan Reserve) and the B's shone there as well. Much warmer day and a grippier higher speed circuit. Some photos can be found here.
Some of the push/understeer I'd been having seems to have been improved by loosening the diff slightly, so it runs quite smooth, with only minimal slip. The friction plate nut is set to around 8mm.
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 08-25-2009, 01:47 PM   #713
barneveld's Avatar
Does anybody know a webshop that has the F104 rims on stock and that ships to Europe? At many webshops they are out of stock...
Greetings,
Marcel.
barneveld is offline   Reply With Quote
Old 08-25-2009, 02:32 PM   #714
border r/c's Avatar
Alfie
hi Alfie,
can you tell me the ride height you use front and rear
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 08-25-2009, 04:55 PM   #715
Trader Rating: 16 (100%+)
Anyone know what 48p spurs of about 100t will fit. ie put the diff balls in the right place.
Cheers
BAMBAM cheapsk8 is offline   Reply With Quote
Old 08-25-2009, 05:03 PM   #716
Alfie's Avatar
The front and rear are on 4mm. The front is lowered because of the spring I used that's a little shorter than the Tamiya ones.
Hope it helps!
Alfie
Originally Posted by border r/c View Post
hi Alfie,
Old 08-25-2009, 05:05 PM   #717
Alfie's Avatar
I run somewhere around Kawada 75T 48p and it will require to put 8 diff balls.
Alfie
Cheers
Old 08-25-2009, 06:30 PM   #718
Alfie
Cheers
DO the kawada need a bush? or is there a bearing that will fit?
Old 08-25-2009, 08:34 PM   #719
Alfie's Avatar
The hole in the centre is good for 1/12 pan car's drive shaft but not the Tamiya ones. You will need a bushing.
Alternatively, you can go the cheaper way by reaming the hole big enough for the 1280 bearing to fit snugly into the centre. It will work just as well. However, do it with caution and don't over-enlarge the hole till the bearing is loosely fitted.
Alfie
Cheers
Old 08-25-2009, 09:06 PM   #720
veecee's Avatar
Trader Rating: 34 (100%+)
Greetings,
Marcel.
http://shopping.rcmodel.hk/product_i...ducts_id=15163
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
