Like Tree1Likes
Old 12-08-2011, 08:29 PM   #7066
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by arix View Post
Wanted to ask if a hard case lipo with the following dimensions will fit on a F104X1?
Dimensions: 137.5mm x 25.5mm x 46.5mm (5.4" x 1" x 1.8")
This is the pack: http://www.venom-group.com/Store/LiP...rdcse-ROAR-UNI
It will not drop right in, but you can make it fit. You dont need to buy any other chassis to do it either.
Go read this and you will see how to do it.
http://www.tamiyausa.com/articles/fe...article-id=551
Odin544 is offline   Reply With Quote
Old 12-09-2011, 07:39 AM   #7067
Rick Vessell's Avatar
Originally Posted by al dente View Post
by loosening the side roll, i would assume that you are talking about the dampening tube. i have run with it off. i have also narrowed the t plate trying to free it up that way as well. i have tried loosening the center screw, i will try that some more. and i will lengthen the shock as well
rubber.
thanks guys
Sweet! Mario in an F1 ride.
Rick Vessell is offline   Reply With Quote
Old 12-09-2011, 10:02 AM   #7068
So today I decided to proceed and buy the motor + esc for the f104x1 I will be building soon, the rules at the track is 13T brushless, doesnt matter what esc or motor, the guys at the track all have the Hobbywing 13 brushless esc + motor but I was thinking that there should be another solution out there.
I noticed that the motor (hobbywing 13T) has very big cooling fins and the actual size of the can is not as big as a standard sized motor which concerns me about the performance, any other options out there for around $100 ?
Maybe a 13.5T with higher kv rating from hobbywing as well?
Here is the one they are using:
http://www.hobbypartz.com/ezrun-35a-...tem-combo.html
I was thinking maybe buying the hobbwing 60A ESC: http://www.hobbypartz.com/ezrun-60a-...-1-10-car.html
And this Hobbywing full size 540 13.3T 3300kv motor: http://www.hobbypartz.com/ezrun135t.html
Is the 60A ESC worth it for the extra performance? or is the power draw to much? My friend has the 35A ESC and a 5000mah lipo which gives him 40min of runtime.
arix is offline   Reply With Quote
Old 12-09-2011, 10:03 AM   #7069
spring71's Avatar
Smile
F1Paitlabs Decals are available at TQ RC RACING Click Here
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 12-09-2011, 10:21 AM   #7070
nrtv20's Avatar
Originally Posted by spring71 View Post
F1Paitlabs Decals are available at TQ RC RACING [URL="http://www.tqrcracing.com/shop/product_list.asp?s_cate_id=1307&s_sort=3"]Click Here
FYI, Thanks.
Awesome! Also, check over the labels; it is entered as Pait instead of Paint
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 12-10-2011, 06:26 PM   #7071
Tron's Avatar
Trader Rating: 16 (100%+)
Can anyone confirm the part number for the roll damper piston itself? Turns out when you break T bar the roll damper piston is susceptible to breaking as well. Thanks in advance
Available someday soon I suppose:
Originally Posted by TPhalen View Post
I couldn't find it separately, but there is this one: http://www.tamiyausa.com/product/ite...oduct-id=54342
Until then superglue I guess :/
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 12-12-2011, 02:09 AM   #7072
dfx
dfx's Avatar
Oil damper could be a nice upgrade I think. My roll damper piston is also getting loose from a set srcew (looks not broken).
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 12-13-2011, 03:23 PM   #7073
Default A or B
Tamiya foam rears for med to high grip carpet. Usually run b front A rears, anyone have luck with B's all around?
likeakid is offline   Reply With Quote
Old 12-13-2011, 04:51 PM   #7074
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
When we have to run foams all I run is the B's
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 12-14-2011, 01:14 AM   #7075
Default Foam tires
I bought a f104 pro a coupla months ago.......and was just wondering what type of foam tires come with the kit. What are the fronts? What are the rears?
What are the shore count also? Anybody know?
slydewinder is offline   Reply With Quote
Old 12-14-2011, 02:58 AM   #7076
Hi Guys,
Just got myself a F104x1 and ready into F1.
However, I have purchased Tamiya rubber tires and tamiya foam rims..
I searched around and know that Pitz tires can be glue on foam rims, but wondering are those tamiya rubber tires also able to glue on foam rims? Or do I have to purchase those tamiya mesh rims.
Many Thanks
Zenkins
DanDan is offline   Reply With Quote
Old 12-14-2011, 03:09 AM   #7077
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
If you bought the Tamiya rubber for the F104 (part numbers 54199, 54198, 51400, 51399), you'll need the mesh rims (51398 or 54201 for the bling shiny ones).
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 12-14-2011, 09:17 AM   #7078
JamesHealey's Avatar
How do you guys like your F104 to handle?
Understeering and predictable or Oversteering and a bit of a handfull
How do you attack corners? do you take the "perfect line" and keep it all in control? or do you like the rear to steer the car a touch?
I actually change my driving style for foams vs rubber which I think is probably a bit odd, but I like understeer with rubber and to get it to really take smooth lines and the ideal line. Where as with foams I like the back end to be a bit looser and to be able to get the car to rotate in the rear and slide a touch.
JamesHealey is offline   Reply With Quote
Old 12-14-2011, 11:08 AM   #7079
hey guys, I just put on the aluminum diff housing on my F104w, but now the axle is too short to mount the tire.
Is there another part I need to make this work?
TIA,
Ron
syrss is offline   Reply With Quote
Old 12-14-2011, 11:16 AM   #7080
nvm, just found it, needs carbon shaft
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
