Old 11-29-2011, 10:46 PM   #6976
TryHard's Avatar
Originally Posted by Matthijs View Post
I used this threaded spacer: http://www.ebay.nl/itm/290569896247, 'any hinge pins spacer' won't work as you have no thread to mount the ball connector and the servo horn. Would be a nice option for Exotek to sell these threaded spacer in 6mm as I couldn't find one at the big hobbyshops.
why? I'm using a Tamiya ball nut and long screw... which clamps the (4mm) of spacers I use together.. don't need to use threaded spacers.
Old 11-29-2011, 10:51 PM   #6977
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Shameless121 View Post
Pretty sure those are the tamiya spacers from there spacer kit they sell I want to say the 5.5 or 5mm But depending on your servo is going to depend on spacer length you may have to join two together to get a proper level turnbuckles.
Good point
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-29-2011, 11:19 PM   #6978
Matthijs's Avatar
Originally Posted by MikeR View Post
The spacers shown in the pics have no thread! I'm not making this info up, indeed 2- 3mm hinge spacers will work. Push a long m3 screw through the servo horn hole, through the spacers and thread it into the Tamiya threaded balls...
that's also a solution, but I was building my F104x1 kit and had no extra threaded balls and was trying to find a solution for the 'stock' ballconnectors Tamiya F104 Pro!
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 11-29-2011, 11:24 PM   #6979
Odin544's Avatar
Trader Rating: 93 (100%+)
Here is how I have mine.
Fluorine coated ball nut, 2x 3mm yeah racing spacers, screw.
Odin544 is offline   Reply With Quote
Old 11-30-2011, 12:49 AM   #6980
tudor_47's Avatar
This solution is the one I probalby use...
For the knuckle a low profile ball connector is used...to get more room for the turnbuckles under the top arms
what is the Tamiya (?) part number for it(the ball connector)?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-01-2011, 03:16 AM   #6981
tony q's Avatar
I need any suggestion for on ESC that is good for racing but affordable for my F104 X1. I will be running 21.5 motor.
tony q is offline   Reply With Quote
Old 12-01-2011, 08:24 AM   #6982
rcdave1's Avatar
I run the speed passion citrix, very smooth throttle, not to big, and affordable! I think TQ and stormer has the combos for under 100 bucks! Not sure how much just the spedo is.
Dave Banks
rcdave1 is offline   Reply With Quote
Old 12-01-2011, 01:29 PM   #6983
Odin544's Avatar
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
Old 12-01-2011, 03:58 PM   #6984
mattwoodcraft's Avatar
this is a great combo for sure i would suggest trying to just get the speedy and purchase a one cell 17.5 Speed Passion motor extremely smooth and is a heap lighter, advance the timing all the way and its spot on.
mattwoodcraft is offline   Reply With Quote
Old 12-01-2011, 04:40 PM   #6985
Misiek's Avatar
Is there any advantage, other than more blue of Aluminum Pivot (54169)
How about heavy pivot?
*Carpet racing, foams (The Track @ Harbor Hobbies)
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 12-01-2011, 09:13 PM   #6986
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
The aluminum piece is pretty bullet proof.
I have run the heavy pivot post both with foam on carpet, and rubber on carpet, as well as outdoors with rubber. I think for foam on carpet, I would go aluminum, same with rubber on carpet.
Outdoors I would run the heavy one. My car worked really well out at the Tamiya track using the heavy pivot.
Was dialed at the Toledo track as well.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 12-01-2011, 11:20 PM   #6987
Dasmopar's Avatar
Send a message via AIM to Dasmopar
What roll out are most guys using for rubber tire on carpet?
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 12-01-2011, 11:47 PM   #6988
Anyone care to speculate as to what the next versions of the kit will be?
E.g. we had the Ferrari and McLaren and retro ones like the Ferrari 643 - F104W
And I just noticed this is on Tamiya USA
RC F104W GP Edition (w/Body) - F104W-GP http://www.tamiyausa.com/product/ite...oduct-id=84262
as well as
RC Tyrrell P34 1977 Monaco GP
http://www.tamiyausa.com/product/ite...oduct-id=84263
What do people think they will release next?
fritzzz is offline   Reply With Quote
Old 12-02-2011, 06:28 AM   #6989
lightfoot's Avatar
Default UF1 Series
UF1 Winter Series
2nd Race will be this Saturday...
Doors open at 10AM....
Qualifying at 12...
http://uf1series.com/
Love and Peace...
lightfoot is offline   Reply With Quote
Old 12-02-2011, 07:13 AM   #6990
NiMo's Avatar
as well as
This is the list for the next batch of Tamiya releases (not all F1):
RC-Kits:
56033 German Tiger I Heavy Tank Full Operation Set (w/4ch Radio)
58004 FMC XR311 Combat Support Vehicle (re-release)
58507 Middle Class Shaft-Drive Buggy (TOMíS)
58510 Ferrari 599XX (TT-01E)
58512 1/12 Volkswagen Type 2 (T1) Wheelie
58513 Toyota Celica LB Turbo Gr.5 (TT-01E)
58516 BMW 318i STW (TT-01E)
58517 Super Shot
58522 Sand Rover Street (DT02/380)
84262 F104WGP (w/Body)
84263 Tyrrell P34 1977 Monaco Grand Prix
84264 Nissan R91CP (1992 Daytona Winner)
84265 Hotshot (2007) Metallic Special
84266 Toyota GT-One TS020 (F103RS w/Sponge Tyres)
84270 Avante (2011) Black Special
I am wondering if the Tyrrell P34 1977 version will be a lexan shell (like the 1976 version) instead of the current plastic shell ?
Also note Nissan RC91P and Toyota TS020, both were previous pan car style chassis.
NiMo is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
