Old 08-20-2009, 09:43 AM   #676
alan1467's Avatar
I'm running the Tamiya 12T brushless with 7.4V lipo and in a straight line it's very unstable but great around the corners
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 08-20-2009, 09:46 AM   #677
JayL's Avatar
Originally Posted by SRBMOJO View Post
Everyone seems to be having trouble with the car running a straight line under hard acceleration. What motors are you guys running? I know a couple have mentioned 5.5 turn brushless. I will be running a 17.5 brushless at the Tamiya USA track. Anyone having these problems with 17.5 or silver/black can motors?
Steve
I have run 17.5 and silver can, no straight issues, high grip asphalt 120'+ straight.
JayL is offline   Reply With Quote
Old 08-20-2009, 03:39 PM   #678
Its a lot of people that are having straight issues,including me. I think its a weight problem with the car, Its designed for brushed and ni-mh batt. And using BL and lipo the car gets to lite
-Do u want to share ur setup, lipo,motor,car setup,tires.?
jim_ed is offline   Reply With Quote
Old 08-20-2009, 07:16 PM   #679
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
I don't know how those guys on 5.5 can actually make this car tamed. I'm on a motor that's equivalent, if not faster, than a 23T. It's already a handful for me. Previously I was on 7.5 and it was never been able to run properly.
Alfie
Steve
F103KŠ • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 08-20-2009, 07:20 PM   #680
Alfie's Avatar
If you are running with the stock silver can, it will definitely be good all around. Tamiya cannot possibly package something that has handling issues before going out of their factories.
Perhaps you should try something faster, since you have got your F104 dialled.
I'll be trying more tires this weekend to give more feedbacks about this car.
Alfie
Originally Posted by Arahawak View Post
I'm alittle skeptical about all this areo thing on the F1. Provided you making a certain speed for all that to work.
How much difference does it make?
I haben got any issues with stock setups.. but myabe i was on a slow motor.
Old 08-20-2009, 07:23 PM   #681
Alfie's Avatar
Yeah, I'm experiencing the same thing. Especially when I need to correct my racing line before entering the corner after the straight, the slightest twitch in the steering creates havoc.
Alfie
Alan
Old 08-20-2009, 07:32 PM   #682
Arahawak's Avatar
Trader Rating: 32 (100%+)
Alfie
The fastest i went was with the Black Can offered by BK. It was good.
was it a 23T?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-20-2009, 08:17 PM   #683
How's the difference between 17.5 and silver can (or even the hobby wing unsensored 13T)? in terms of gearing, acceleration, ease of driving?
stocker is offline   Reply With Quote
Old 08-21-2009, 12:31 AM   #684
alan1467's Avatar
Alfie
Yes that's waht my F104 is like any movement how ever small in a straight line at speed and it's a high speed crash, otherwise the car is great.
tried diffeerent toe in/out , camber , servo tyres and nothing help
Running Tamiya 12T brushless (23T eq) and lipo so may try adding some weight but not sure that will help but could be wrong.
Is everyone else that is have this problem running lipo? or std nimh?
Need some help as I'm getting very disappointed with a great car
Tamiya TRF - Tekin
Old 08-21-2009, 03:27 AM   #685
Alfie's Avatar
It's equalled to 23T. But of course, we cannot rebuild the motor like the 23T ones.
Alfie
was it a 23T?
Old 08-21-2009, 04:51 AM   #686
killingtime's Avatar
Ok, let me ask a different way.
What is everyone using to true the tires? Which arbor? Where did you get it?
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 08-21-2009, 09:04 AM   #687
Arahawak's Avatar
The guys i ran with were on lipos and their cars looks quite dialled. I was running Nimhs.
I followed the instructions and built the car, with alu mount and the FRP T-bar. no other mods were done. Only extra was the lay-down servo which reduces bump steer.
No such issues about the car being sensitive on the straights. In fact when i had no issues with the diff, i could gun out of the corners. and it stayed. and i was on a 23t motor.
maybe a re-built is in order.. just to check if any thing went wrong?
Old 08-21-2009, 09:36 AM   #688
InZane's Avatar
Default Track test no.1
I'm soooo pleased with the car after my first tests!
This chassis has great potential - believe me! There are some problems with the stiff up&down/back&forth T-bar movement, uneven chassis flex and less preferred weight distribution (if you ask me - that's why I opted for saddle pack lipos). But these things can be sorted out.
I had no problems with the high speed stability or push in tight corners. I'd say that i haven't had a car handling this well the first time ever before.
As for the T-bar flex I dremeled small slits on both sides of the pivot screw to make it softer back&forh without affecting the side to side stiffness. Hard springs at the front and teflon tape and low friction damper disc with 70 damper oil between (very free), kit oil&spring with no pre load on the shock, kit tires with Garnier 50+ SPF sun protection.
Total weight is 1090 grams - 40/60 Front/Rear.
InZane is offline   Reply With Quote
Old 08-21-2009, 09:41 AM   #689
What is the difference between the tyre A and B?
The B is more hard?
Tks for your answer.
youb is offline   Reply With Quote
Old 08-21-2009, 10:16 AM   #690
JayL's Avatar
I have been running the reedy 3400 lipo that looks like a stick pack. I also used a full sixe with metal heat sink servo to add some weight to the front of the cars, and I mount the amb on the servo
The car is faster with the 17.5, mostly on the straight.
The things that really dialed the car in for me are:
1. diff adjustment, very very small adjustment's. I start with alittle slip and tighten until it feels right, if the car whip's around coming on throttle corner exit you went too tight
2. the middle dampner post, tighten the nut until the rear end thinks its a drift car then lossen, in very small amounts, unitl the car feels balanced
3. the center shock, tighten the collar until you can feel the fronts working mid corner
4. smaller front tires with alittle rake, front lower than rear, in the car.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
