Like Tree5Likes
Old 11-10-2011, 07:51 PM   #6811
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by BP SHADOW View Post
Glad they finally got there, sorry to keep you waiting
Car looks great!!!!
Didn't take you long to get them on did it?
No worries, yeah it took about an hour. Got to do my race tires next.
T-Sal
gashuffer is offline   Reply With Quote
Old 11-10-2011, 07:53 PM   #6812
gashuffer's Avatar
Originally Posted by gsxr0311 View Post
nice body. i love this paint job, but one time i had a black rc car and i couldn't see it as well, so i am on the fence about painting my car the same way,
Thanks. Yeah if all else fails I have a back up that I will race with. This one's for the shelf more than likely.
T-Sal
Old 11-11-2011, 01:09 AM   #6813
Dasmopar's Avatar
Send a message via AIM to Dasmopar
I have run mostly black bodies out doors and the real issue is the other people not seeing your car more than you not seeing it. I parked my car once and the marshal never saw it. it just blends in with the track surface. Now I put a orange nose on my bodies.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 11-11-2011, 03:15 AM   #6814
TryHard's Avatar
Quick one for the 104 faithful... I need a bit more on power steering, what should I look to change, and what will the effects on other things will be?
I'm thinking harder centre spring, thicker shock oil, or raising the position of the shock. Currently on red spring, losi 25wt, and stock x1 position (3mm shim).
| THard.co.uk | Xray | MuchMore |
Old 11-11-2011, 08:48 AM   #6815
superspeed's Avatar
that paint job is hard to see on a track but it sure looks cool.
superspeed is offline   Reply With Quote
Old 11-11-2011, 09:00 AM   #6816
lightfoot's Avatar
I'm the last guy to ask about set up because I never change mine But at the Big Speedtech race at Tamiya the back end of my 104 was slipping out on me and I really had to feather the throttle out of corners... Mike Rydwell gave me a tip that worked really well and I was able to get on the power sooner and the car felt more planted... I added droop to the front end and weight to the rear end... This in effect gave me more "on power steering"
Love and Peace...
lightfoot is offline   Reply With Quote
Old 11-11-2011, 10:12 AM   #6817
gashuffer's Avatar
Also you can try addiing more preload on the shock. Adding more rake will give you some more on power steering.
T-Sal
Old 11-11-2011, 10:35 AM   #6818
F N CUDA's Avatar
Trader Rating: 31 (100%+)
For a while there, guys were messing with the angle of the upper arm by adding shims to the inside rear ballstuds or removing the spacers under the camber plate in the front to get some caster and camber changes that promote more steering but, is the rear locked in enough to warrant more aggressive steering?
Baby steps I guess.
RobK has posted lots of different front end variables on his http://rcf1blog.blogspot.com/2011/02...front-end.html
This link takes you into the middle of his blog, you can navigate from there and see/learn lots of cool stuff. In case you haven't been there yet, that is.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-11-2011, 11:41 AM   #6819
Which body is that? Never seen it before.
Old 11-11-2011, 01:01 PM   #6820
texastc's Avatar
OK, be gentle here, noob question. How do you add droop to the front? I'm having that issue right now on my F109. Rear sliding out.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 11-11-2011, 01:21 PM   #6821
lightfoot's Avatar
No worries... Not like I really knew that well either There are spacers on the front king pin that you can add or remove to adjust the ride height... You want to remove maybe a 1mm spacer so that your ride height remains the same but when you pick up the front of your car the tires droop down and lift off the ground after the body is raised... I hope that makes sense...
Love and Peace...
Old 11-11-2011, 11:12 PM   #6822
spring71's Avatar
New F104 Carbon Reinforced Gear Case is arrived at TQ. Click Here
Ultimate F1 Series is up tomorrow.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 11-12-2011, 12:56 AM   #6823
Dasmopar's Avatar
protoform 909 its a 1/8th scale body with tons of down force.
Lon Burling II
Old 11-12-2011, 08:35 AM   #6824
TryHard's Avatar
Baby steps I guess.
Thanks Cuda.
Actually been aware of Rob's site for a while, even running his front end setup on my X1.. Works well, as I can full goop the tyres and go from their
It's actually where I picked up on the rear shock angle change,as I've seen him mention it in a few posts. Biggest problem is I can't get to it when not at work (bloody china firewall is doing my goat this evening!!), hence asking away.
But thanks for all the answers, off to the track tomorrow, so will give them a try along with a few other things (moving the steering sevo forward).
Cheers
Ed
Old 11-12-2011, 10:17 AM   #6825
Darn...was hoping it was a 1/12th
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
