Like Tree4Likes
Old 11-07-2011, 01:07 PM   #6781
Trader Rating: 71 (100%+)
I have had success also using the shorty packs ( I use the promatch). It is a snug fit left/right and you won't be able to use the electronics trays (NBD) I just removed the top deck, drop the pack in, reinstalled the top deck and added a small blob of shoe goo in front of the pack. it's not going anywhere.
I just double side taped my receiver and speedo to the battery in their original locations.
Markus is offline   Reply With Quote
Old 11-07-2011, 01:29 PM   #6782
F N CUDA's Avatar
Trader Rating: 31 (100%+)
I was able to keep the wings/trays on, just trimmed the loops for the posts to an almost closed "C" shape.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-08-2011, 03:52 AM   #6783
mattwoodcraft's Avatar
what grease is been used in the X1 slide bar i was thinking wheel bearing grease depending on how tacky you wanted it ? at the moment all i had was diff lube grease it feels very easy to pivot
mattwoodcraft is offline   Reply With Quote
Old 11-08-2011, 04:08 AM   #6784
TryHard's Avatar
Ive tried a few things, ball diff greese, 2000wt diff oil, all the tamiya damper greeses, aw geese, and corally blue tube lube. Best I've settled on so far is the soft tamiya damper greese (the green one). Seems to give good steering, whilst also a stable rear end.
Having said that, I see David Jun suggests using 10K diff oil, worth giving it a try for sure. Its on my list to do...
HiH
Ed
Old 11-08-2011, 04:13 AM   #6785
TryHard's Avatar
Cuda, do you still mount the trays with the o-ring on top?
If you take the o-ring out, and shave down the upper loop, and cut the lower one, you can fit the trays on the posts with a full loop. Is a bit pack height dependent obviously, but is also a bit more secure as well... I have had the trays pop off when I did it your way before.
Raising the tray also gives a bit more room underneath for more lead if your so inclined
HiH
Ed
Old 11-08-2011, 05:36 AM   #6786
Trader Rating: 19 (100%+)
I tried Castrol auto grease, didnt quite like it, tried tamiya diff grease still wasnt quite as nimble as i like my car... currently i use 5000wt associated diff oil and i think it's best so far for bayswater... Might try 3000wt diff oil next.
You racing sunday? I got my FGX to try out, but i'll be racing the f104 well.
LordAnubis is offline   Reply With Quote
Old 11-08-2011, 08:56 AM   #6787
F N CUDA's Avatar
As far as damper grease/oil goes, I've run from 5000 diff oil to completely dry.
What I progressed to for my win at Tamiya last weekend (blowing his own horn)was a drop of 2000 on the opening of the tube, worked it a few times then wiped off the damper post leaving oil only in the grooves.
This resulted in max rear traction for our conditions, sprayed asphalt and warm comfy weather.
Thicker = looser
Thinner = grippier
Dry = just a bit too floppy side to side but could be the ticket in terrible conditions, no grip surfaces.
Electronics trays, I've only modified the original set which I actually broke the loops that I cut to the C shape so I shoe goo'd them closed again around the post which tightened up the fit and keeps them on. I run no O rings on top now.
Craig Hammon
Old 11-08-2011, 09:08 AM   #6788
http://rsector.com/index_eproduct_vi...?products_id=2
Good idea for both regular lipo and short lipo
ME-student is offline   Reply With Quote
Old 11-08-2011, 09:15 AM   #6789
F N CUDA's Avatar
That is a nice setup, especially if you have your battery in and out often.
Craig Hammon
Old 11-09-2011, 04:00 AM   #6790
cool diff oil i have i actually thought it would be quiet messy using oil how ften do you need to clean and re apply ?
no not this sunday i will be back next week for the nationals
Old 11-09-2011, 05:15 AM   #6791
Hi just sharing. F104s with Tamiya 14T sensorless motor and LiFe pack. Track was bumpy, jumping 4 wheels off the surface. Several broken steel rear axles.
+ YouTube Video
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-09-2011, 07:34 AM   #6792
racer x 1's Avatar
Trader Rating: 27 (100%+)
can you guys post a few pictures of how your cars are wired and also how your running the shorty losi packs? im looking for ideas. thanks
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-09-2011, 11:02 AM   #6793
Misiek's Avatar
Does anyone know Tamiya part number for front uprights?
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 11-09-2011, 11:07 AM   #6794
Pro10noob's Avatar
Havent got a manual?
It is all in there or you could download one so you have all the part numbers for future ordering.
Check link http://www.tamiya.com/english/rc/manuals.htm
You can find it there.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-09-2011, 11:15 AM   #6795
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
How about this
http://www.tamiyausa.com/product/ite...oduct-id=54154
I have them in stock if you need them
Also have some stock white ones I will let go of cheap
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
