Like Tree4Likes
Old 10-11-2011, 02:48 AM   #6511
Pro10noob's Avatar
Go for the rubber shielded ceramic bearing.
Clean them with alcohol or break cleaner and then oil them with a light oil like LRP bearing oil.
Smooth as butter and last forever.
I have on my F103 still the original front wheel bearings from Tamiya and this car is over 15 years old
regards Roy
Originally Posted by freakyfreakyflo View Post
many thanks roy. i buy packs from rcmart but only seem to use the front wheel bearings. i now have many diff and rear bearing and no front
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-11-2011, 02:49 AM   #6512
mattwoodcraft's Avatar
i see they have made the X1 conversion kit available to by for the F104 pro does anyone know where they are in stock i not having luck finding it
mattwoodcraft is offline   Reply With Quote
Old 10-11-2011, 04:07 AM   #6513
MrChodes's Avatar
could someone tell me the exact sizing of the 104 front wheel bearings and any place to get some.
thanks
RCMart have individual sizes (in packs of 10):
http://www.rcmart.com/catalog/advanc...sort=1a&page=8
*Yeah Racing (#YB6013B/S10) Blue Ball Bearing (5x10x4mm) 10pcs
*Yeah Racing (#YB6013CB) Blue Telfon Ceramic Ball Bearing (5x10x4mm) 10pcs
Serpent S100. Ducati FM1-e bike.
MrChodes is offline   Reply With Quote
Old 10-11-2011, 06:44 AM   #6514
theatriks's Avatar
So does anyone know if u can get the damper roll for the split deck seperately or is tamiya just the biggest scammimg rc company out there!! The reason i say that is because at the beginning of the summer tamiya released a split deck only now i see u can get the split deck and damper roll as a set but how about for all the people that bought the split deck before now there gonna force us to buy another split deck just to get the damper roll if this is the case im probably gonna stop buying tamiya (scammers) kits......let me know if someones seen the damper seperately and i will apologize to tamiya but if there isnt its the last scam they pull on me ....crooks!!
theatriks is offline   Reply With Quote
Old 10-11-2011, 08:13 AM   #6515
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i believe the roll damper itself won't be available separately until later this year - its listed as an option, but not available for sale yet
and (i could be wrong) i don't think you need to by the X1-based split deck to use the damper set...so just calm down
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-11-2011, 08:37 AM   #6516
NiMo's Avatar
I believe they call it "The Tamiya Sunami Relief Fund"
NiMo is offline   Reply With Quote
Old 10-11-2011, 08:52 AM   #6517
Im after a speedway pal brawn body if any 1 know where i can get 1?
Could u please send a link! and for the wings thanks
Bigtomo71 is offline   Reply With Quote
Old 10-11-2011, 09:58 AM   #6518
F N CUDA's Avatar
Trader Rating: 31 (100%+)
I thought the X1 split upper deck was different from the hop up split deck.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 10-11-2011, 10:32 AM   #6519
robk's Avatar
Trader Rating: 22 (100%+)
It is. The optional carbon split deck has no way to mount the damper tube.
There's probably a way to get a damper tube on there if you're willing to do some shade tree engineering. It just won't be TCS legal.
Old 10-11-2011, 10:43 AM   #6520
MikeR's Avatar
Trader Rating: 15 (100%+)
Lol why all the drama? If you don't like it then don't buy. It's not like the split deck you have all of a sudden doesn't work. It worked fine for one of the local guys here who podiumed at Vegas last week.
Here's a speed secret- most guys running the 104 t-plate chassis aren't using any lube any way for the side dampener or the stock pucks
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-11-2011, 02:23 PM   #6521
I bought mine from RainbowTen, the full name of the body is
Speed Way Pal PF001 F104 F1 body type-br
http://www.rainbowten.co.jp/english/index.html
They no longer have it in stock, I presume it has been discontinued as it isn't available anywhere. You could try contacting them to see if they can order it for you.
Probably better going for the Chevron F110 body as it's pretty near with the Brawns distinctive sidepods, but has ridges on the top of the nose.
The wings are the 3Racing wing set for F104, a pity 3Racing never made them in white. Add the 3racing F104 wheel cover set and the Brawn sticker set available from Rainbowten to complete it.
terry.sc is offline   Reply With Quote
Old 10-11-2011, 04:23 PM   #6522
just ordered my split top deck with damper really looking forward to trying this out when i receive it
Old 10-11-2011, 04:25 PM   #6523
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Matt, I will be stocking the conversion kit as soon as it becomes available, should be in the next few weeks.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 10-11-2011, 04:34 PM   #6524
BP SHADOW's Avatar
So TAMIYA are a bunch o crooks because they develop new products?
That makes a ton of sense. If they didn't bring out the X1 you'd be bitching that they keep Selling the same tired product. if you run on carpet you may not even want or need that new setup, initial testing is showing that you need to free up the rear end of the car to get it to work. The X1 was awesome at the TCS Nats, but guess what? An X1 didnt take the title, it was a damper disc car. I may run y pro chassis with the split carbon deck on carpet, at least for TCS , for club racing I will be running my Exotek.
http://f1rclab.com
Old 10-11-2011, 05:34 PM   #6525
theatriks's Avatar
And yes im sure im not the only one who has that opinion on tamiya
But some guys are rite if u dont like it dont buy it ....and i wouldnt its just the only class of f1 im allowed racing at my local club races are the crook tamiyas...id much rather race the hpi
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
