Like Tree4Likes
Old 08-15-2009, 06:08 PM   #631
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by RC MARKET View Post
nice !
Very!!
akura2 is offline   Reply With Quote
Old 08-15-2009, 07:53 PM   #632
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by tjompa View Post
Sparx questions is very important to get solved soon cause i am dealing with the exact same issues. No tweak, no bad savers and so on, the material is flawless but it has to be the missing weight of a nimh battery pack that causes this instability in "high" speeds. If somebody has some more ideas please drop them here.
The car is too stiff front to back by design
Old 08-15-2009, 08:45 PM   #633
RonF's Avatar
I have maximal downforce on the wing and it doesnt work eiter, so does sparx.
But i cant call theese wings a wing cause the downforce that they delivers are close to zero.
type in downforce in search in the thread 1/10 scale F1's. The japanese article there shows the actual downforce and drag these cars make with different wings, bodies etc.
RonF is offline   Reply With Quote
Old 08-15-2009, 08:51 PM   #634
geeunit1014's Avatar
Anybody have some setup tips for this bad boy? Im runnning the box stock setup, silvercan motor on a parking lot track that is med-hi bite, and this thing plowwwwwssss like a dump truck. Does anyone else run softer front springs, or does anyone make some softer front tires? I just dont have any corner speed in the twisties compared to a 103.
Inzane, your nosecone is on upside down I did the same thing when I built the car, and had to look for a minute to figure out why the front body post didnt reach.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-16-2009, 12:01 AM   #635
lightfoot's Avatar
Hey guys , for those of you attending or planning to attend the Ultimate F1 Series Race day, please check out the website :
http://www.charleslightfoot.com/UF1SD.html
Race location has been moved to the TAMIYA track...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 08-16-2009, 02:11 AM   #636
InZane's Avatar
Thanx geeunit1014 - I'm sure this will make today's body mounting a lot easier
Here are some closer pics of the wiring.
I built a "channel" for the ESC wires (sensor cable & ABC-wires) with two 0.5mm carbon plates and two servo posts. I also drilled a 12mm hole in the pivot post and dremeled away some plastic on the motor mount/friction plate stay.
The channel seen from above
The wires run through the pivot pod and the friction plate stay
Pic of the 45 angled servo.
Last edited by InZane; 08-16-2009 at 03:00 AM. Reason: last sentence - found out how to make a degree symbol :D
InZane is offline   Reply With Quote
Old 08-16-2009, 07:56 AM   #637
robk's Avatar
If you can find them, I'd mount rear donuts on the front and cut them down on a truer. The stock fronts are harder than the rears, and they seem to blow out traction additive pretty easy. Most of the time my car steers well, but them starts pushing as the additive goes away.
Old 08-16-2009, 08:50 AM   #638
alan1467's Avatar
i tend to agree, my car is very stable around corners and at low speed but as soon as you get faster it's very unstable and almost undrivable on the straights. Anyone got an ideas on how to cure it???
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 08-16-2009, 10:52 AM   #639
Thanks, I think that should work well. My car killed my fronts yesterday, because they were sliding so much, but the rears had almost no wear. Whos got donuts in stock??
For the people with the undriveable cars, you may want to put some negative steering exponential in your radio. If you have a fast servo, with no expo the car is hyper-responsive to wheel inputs. The expo will soften the curve around center, and should help you out.
Mike Gee
Old 08-16-2009, 12:00 PM   #640
cheROK1212's Avatar
That's the thing. If you have maximum downforce, it is @ it's max on the straight and may be slightly lifting you front tires enough to cause a slight loss of steering @ high speeds, @ lower speeds the downforce evens out which may be why you feel hooked up in the infield. Also don't underestimate the aero effects on these cars, because of their light weight and high speeds the wings are a little more effective than you may believe. Some are more effective than others but they all generate a good amount of downforce.
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 08-16-2009, 12:06 PM   #641
tjompa's Avatar
Thanks for your answers.
I am mostly into 235mm pancars so i just laughed at this wing but maybe it works, just needs to replace it cause it was not of a good quality.
tjompa is offline   Reply With Quote
Old 08-16-2009, 12:13 PM   #642
RC MARKET's Avatar
nice again !
RC MARKET is offline   Reply With Quote
Old 08-16-2009, 02:25 PM   #643
dsyed1's Avatar
Mounted the electronics today. Now everything is almost complete. I'm still waiting for blue aluminum body postsand o-rings for the Lipos. First tests will be Thursday next week if weather is OK.
very cool!
dsyed1 is offline   Reply With Quote
Old 08-16-2009, 02:26 PM   #644
dsyed1's Avatar
any one tried mounting a fan or heat sink on the motor?
also wondering if there was any news on possible rubber tires for the f104....
Old 08-16-2009, 09:47 PM   #645
Trader Rating: 19 (100%+)
I'm having the same issues as a few ppl above, where at low speed the car is sweet but when I hit full throttle the car just spins and if i brake the car spins again. Has anyone got a setup that will get rid of this? Is it a weight issue as I am running li-po with the Hobbywing 35 amp speedy and 3000kv motor, but may move onto a 17.5 brushless setup? Can different tyres help, solve this? Or could it be a diff issue?
For those who have tried different compound tyres whats the best combo so far? And is it worth while to use tyre compound on the front and rears?
bee200sx is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
