Like Tree5Likes
Old 08-14-2009, 12:00 PM   #616
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Everything's checked, below half throttle the cars track perfectly straight, but as soon you get up to full speed it gets uncontrollable sometimes, if you release the throttle it almost turn around... As soon as you get to a corner the handling is spot on, rear is so planted its unbelievable..
Its exactly the same symptoms as a crap servo but these aren't, ive tried with another BLS351 and a Sanwa/Airtronics ERG-VZ but still the same..
Specs atm:
Sanwa M11 running 2.4
InoLab D660 Digital servo (6.8kg, 0.08s)
LRP Sphere Comp ESC
Team Laje 17.5T, Geared 29/93
Alu motor mount is the only chassie hopup so far.
Basically stock setup but we've tried EVERYTHING, with/without center shock and without damper disc is two of the most extreme stuff we've tried but it's the same.. We also glued the bearings into the front wheels to minimize slop (yes, they still spin as before)..
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 08-14-2009, 06:25 PM   #617
bretthitman's Avatar
Default servo
hi i am looking to buy a new servo for this car what servos have people got for this car thanks brett
bretthitman is offline   Reply With Quote
Old 08-14-2009, 08:22 PM   #618
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Specs atm:
LRP Sphere Comp ESC
Did you build the chassis on a flat surface?
Sound like a tweak issue, and since there are no tweak screws to adjust, it could be that the chassis has a slight tweak to it. Also check your front spring lengths as that can cause a drift as well
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 08-14-2009, 10:52 PM   #619
lightfoot's Avatar
Originally Posted by cheROK1212 View Post
btw, why have i not seen folks pushin idea of 21.5s to phase out cans (and thus can wars)? seem logical especially in consideration to VTA as well.
Hell yeah, and lets start speedo wars instead
v200=KERS!!!
I love this idea... I will be happy to never see another silver can again...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 08-15-2009, 12:19 AM   #620
RonF's Avatar
Excuse my ignorance, but with all the different brushless systems out there, what/how would a standard for stock be teched? Tamiya has a motor or two, there are 17.5 and 21.5 that i see claim stock (same as 27T brush) etc. How would/is this teched?
I raced last in 1995, and im familiar with brushless in my planes but not on the new car technology.
So, I like the advantages of brushless, but keeping the cost down and class even in F1 with silver/black can motors i can see works.
RonF is online now   Reply With Quote
Old 08-15-2009, 02:28 AM   #621
Tweak and steering setup is the first thing i check when this sort of stuff happens with any car.. I just checked it with my scales to be sure, tweak is spot on..
The direction its taking off i completely random, sometimes its right and sometimes left, you could say its like the servos do not center even though theyre brand spanking new and works fine in my other cars which are a hell of a lot faster and heavier..
My friend has a theory that involves too little grip/downforce in the front, since the cars rear ends are so planted in lower speeds.
Old 08-15-2009, 05:33 AM   #622
s13evo's Avatar
servo saver!
s13evo is offline   Reply With Quote
Old 08-15-2009, 06:08 AM   #623
E-clip's Avatar
Trader Rating: 39 (100%+)
Hello Just wondering what weight oil should I put in the shock for an outdoor asphalt track ??
And to get more rear end traction do I free up the Fiction plates by using a lighter diff grease ???
E-clip is offline   Reply With Quote
Old 08-15-2009, 08:42 AM   #624
InZane's Avatar
Mounted the electronics today. Now everything is almost complete. I'm still waiting for blue aluminum body postsand o-rings for the Lipos. First tests will be Thursday next week if weather is OK.
InZane is offline   Reply With Quote
Old 08-15-2009, 10:37 AM   #625
RossoTorro's Avatar
Originally Posted by croz View Post
We are going to try the Hobby wing 13T, 35amp esc compo as a spec system for F1 here in London, Ont. We'll let you know how it goes.
We run them as spec for our F1 class here, and they work great.
A little faster than Sport tuned, but it's cheaper still. No need to change motor ever again. We have run them for a year now without fans on ESC. They had to be removed due to upper deck on the F103. Free batteries, hop-ups and tires.
All F103's run Zen tires, 38 shore fron and 35 shore rears. The Tamiya's for F104 is not as good as them. We have a medium short high traction carpet track.
RossoTorro is offline   Reply With Quote
Old 08-15-2009, 11:55 AM   #626
Originally Posted by s13evo View Post
servo saver!
Which one? I've tried the stock one, epoxied stock one, 2 types of Kimbrough savers and just a solid servo arm paired with the Sanwa ERG-VZ (14kg 0.10 sec) and it still weaves.
Im starting to think our lipo packs is the reason, the cars loose around 200 grams so thats why theyre so strange to run. Ill get some lead and mount anywhere i find space.
Old 08-15-2009, 12:42 PM   #627
tjompa's Avatar
Sparx questions is very important to get solved soon cause i am dealing with the exact same issues. No tweak, no bad savers and so on, the material is flawless but it has to be the missing weight of a nimh battery pack that causes this instability in "high" speeds. If somebody has some more ideas please drop them here.
tjompa is offline   Reply With Quote
Old 08-15-2009, 12:50 PM   #628
cheROK1212's Avatar
I don't know what position you have the rear wing at but try it in it's most upright position. What you may be getting is hella' rear downforce causing you to lose some of your steering.
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 08-15-2009, 01:25 PM   #629
tjompa's Avatar
I have maximal downforce on the wing and it doesnt work eiter, so does sparx.
But i cant call theese wings a wing cause the downforce that they delivers are close to zero.
Old 08-15-2009, 01:32 PM   #630
RC MARKET's Avatar
nice !
RC MARKET is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
