Like Tree5Likes
Old 08-31-2011, 08:21 PM   #6181
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Originally Posted by RedBullRacing View Post
Hi F1 fans,
I have my new F104W almost ready to maiden, but would like some suggestions on adding ride height. I have Shimizu rubbers , on the kit foam rims , with which I only have 3mm ride height.
I was going to swap the rear axle holders for the tallest one (#1 I think), but I need to get the front up as well. Do I need to shave the steering block and and shim it down to raise the front up ??
Or do I just add preload shims to the front kingpin springs (making for less travel) ???
I will be running outdoors on dusty asphalt + bumps. I have a HW s/less 13t onboard + 2S stick pack lipo.
Just move the spacers around that are on top and bottom of the spindles/uprights.
Put them all on top of the spindles and the front end will have the highest ride height.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-31-2011, 08:28 PM   #6182
Hmm, there doesn't seem to be too much I can do other than :
Shave down the steering blocks or the whole front plastic suspension mount -where it bolts to the lower deck.
I thought there were shims, but there aren't any .
Wishing I had've bought a normal F104/ pro now , since the F103 front seems a bit more limited in adjustment.
Racing program on # pause #
RedBullRacing is offline   Reply With Quote
Old 08-31-2011, 08:53 PM   #6183
theatriks's Avatar
Originally Posted by robk View Post
*Xpress (#968-104) Metal Upper Arm Joint Set For Xpress Series
Rcmart carries the parts...also use titanium for the camber links, the aluminum parts bend easily.
can u use that setup in tcs racing
theatriks is offline   Reply With Quote
Old 08-31-2011, 09:16 PM   #6184
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Vicko View Post
Hey MikeR dosnt putting the spacer to shorten the king pins per-load the
spring?
Yes and it can help raise the front ride height nicely if you are running medium or soft springs. My car sits at 5mm at the front now- perfect for asphalt. Or you can just grind the inner wheel if you don't want to mess with the pins.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-31-2011, 09:26 PM   #6185
Also, does anyone run their rear rubber tyres without an insert ??
I have the F103 type on it.
Old 08-31-2011, 09:35 PM   #6186
F1Jet's Avatar
Originally Posted by Austin B View Post
I ended up running 93 x 30 for the mains at Tamiya. Ran super hot but no fade.
congrats on the win...good luck in Japan.
Can you comment on your tires and inserts? How about tire prep? Anything special for the dusty track?
F1Jet is offline   Reply With Quote
Old 08-31-2011, 09:40 PM   #6187
F N CUDA's Avatar
Sorry man, didn't notice you said 104W.
Yeh, you can shave down the spindles and add the amount removed to the opposite side using shims. I have done this on my 103. It works both ways, can lower or raise the front by a couple mm this way but that's about it.
Craig Hammon
Old 08-31-2011, 09:47 PM   #6188
TfnG's Avatar
Trader Rating: 26 (100%+)
hello, looking for some setup help. anybody have a good starting point for carpet? i just picked up an all stock f104 pro. we have a 90x35 carpet track opening in 2 weeks so it will be low on traction for a while id imagine. and we can run the W cars...so i plan on getting the 103 arms and running foams.
thanks for any help in advance !!
GRAVECLOTHING.COM PROLEVELRC.COM
TfnG is offline   Reply With Quote
Old 08-31-2011, 11:20 PM   #6189
Thanks, have swapped the rear axle spacers , so onto the blocks next. I definitely need to find a couple of mm for the front.
Cheers !
Old 08-31-2011, 11:36 PM   #6190
kneedeeppow's Avatar
Originally Posted by BP SHADOW View Post
Heres my latest creation , it has been a good day as I won best of show at the TCS Finals
now thats staight up pimpin nice work brad
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 08-31-2011, 11:38 PM   #6191
Luosi's Avatar
Which low profile servo would you guys recommend for the F104? Is the Futaba S9551 any good?
Luosi is offline   Reply With Quote
Old 08-31-2011, 11:50 PM   #6192
really want to get 1 of them!
Mike-Xray is offline   Reply With Quote
Old 09-01-2011, 12:09 AM   #6193
mattwoodcraft's Avatar
the savox 1251 fits nicley in the f104 pro to cheaper than the futaba aswell
mattwoodcraft is offline   Reply With Quote
Old 09-01-2011, 12:34 AM   #6194
Cheers !
Success - I went from 2.5-3.0mm front ride height , to 4.5mm front and 3.5 rear .
I also switched to the 3racing gold (hard) front springs. Does anyone else use these ??
Old 09-01-2011, 05:04 AM   #6195
Oortael's Avatar
I own a Sanwa SDX-801 and its very durable. I hit a wall at the end of our long straigth (bad track design imho) several times. The servo overturned twice. But I could fix it with just dissasambling the gears and get it alltogether again.
Oortael is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
