Old 08-31-2011, 08:07 AM   #6166
Vyger's Avatar
Originally Posted by rccartips View Post
Hi Vyger,
I bought this item, but could not see any gold spring, just silvers and black. Is the gold spring medium (in between soft silver and hard black?)
Thanks.
Yes, the gold is the medium spring. The silvers are soft (super thin wire), then gold is medium (a little thicker wire), and black is the hard (the thickest wire).
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 08-31-2011, 08:18 AM   #6167
Originally Posted by Pro10noob View Post
Softer T-bat generates more rear grip and bit less steering.
By rolling you mean the rear want's to pass the front?
If so see above.
With the F104 it acts a bit like a roll bar.
regards Roy
Thanks Roy,
Sorry that I did not make it clear, rolling I mean the car rolling left and right
Also can I assume that the middle shock govern the weight transfer of front and back?
The reason I ask is that my 104 keep on over steer even i use the soft rear and hard front rubber tires, and been reading this great thread that having a soft T bar helps this problems, but just want to know what is actually going on
Regards
Leo
Warbird is offline   Reply With Quote
Old 08-31-2011, 11:47 AM   #6168
Hey all!
Any good carpet setups for f104 using rubber tires?
My dad will be racing his at the IIC race in Vegas! We don't run rubber normally so just looking for a decent starting point so the car doesn't do donuts.
Thanks!
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 08-31-2011, 12:21 PM   #6169
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by TheZoof View Post
Hey all!
Thanks!
I wouldn't plan on it doin donuts, more like traction rollin especially after the groove gets sauced up.
When I ran at TQ here in So Cal, had to stiffen it up, grease on the damper plates and upright pins and stiffer T plate tightened up.
Also lowered the ride height a bunch.
Others will probably have a super dialed carpet setup to chime in with but that was my limited experience on rubber with the 104.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-31-2011, 12:38 PM   #6170
Oortael's Avatar
Hi,
Is it possible to mount Shimizu rubber tires on Tamiya chrome rims for rubber? RcMart says they fit only on the foam rims.
Greets
Stefan
Oortael is offline   Reply With Quote
Old 08-31-2011, 12:41 PM   #6171
Will a hpi f10 body fit the f104?
Associatedkid is offline   Reply With Quote
Old 08-31-2011, 12:59 PM   #6172
robk's Avatar
Trader Rating: 22 (100%+)
Hey all!
Thanks!
#1- remove center screw from Tbar, use a shock rebound foam glued to the top of the t bar to maintain ride height
#2 Glue sidewalls of front tires
#3 start with 60,000 wt oil on front kingpins...go up or down from there depending on feel
I would start with the soft tbar, the green one with no cut out. Without the center screw, that's pretty soft. The black stock one may be good as traction comes up- at least it was good with foam. I would still run the red mini spring or red spring from the black set. 30 wt/3 hole. Slam the car as much as possible. Drop the camber plate (no spacers, directly on lower arms) so you can get the exact camber gain you want with shimming. Same with upper arms, you can raise or lower the upper arm with spacers on the kingpins.
If you have time, you can also try an upper arm setup like this:
Old 08-31-2011, 01:23 PM   #6173
What are the red couplers from? I'd like to do my suspension like that as well, not so much for adjust ability but for durability as the upper arms bend all the time. Part # would be helpful
Old 08-31-2011, 01:27 PM   #6174
F N CUDA's Avatar
Originally Posted by Oortael View Post
Hi,
Greets
Stefan
Someone here has done it with lots of careful trimming of the ribs to make them resemble the foam type rims.
Just easier to get the foam type rims and save the headaches.
Craig Hammon
Old 08-31-2011, 01:40 PM   #6175
robk's Avatar
*Xpress (#968-104) Metal Upper Arm Joint Set For Xpress Series
Rcmart carries the parts...also use titanium for the camber links, the aluminum parts bend easily.
Old 08-31-2011, 01:53 PM   #6176
can you mount rubbers on F103 foam rims?
kb525 is offline   Reply With Quote
Old 08-31-2011, 01:56 PM   #6177
Thanks Rob!
Old 08-31-2011, 04:52 PM   #6178
Oortael's Avatar
Thanks. I sat in fornt of a pair of soft rear tires and these nice chrome rims and wondered how they should fit togehter.
After I've got frustratet enough I decided to order me some foam rims now
Old 08-31-2011, 05:19 PM   #6179
British Menace's Avatar
Yes it is easily done. I find it a little easier and the tires turn out truer then ones mounted on foam rims. Although with practice they would turn out the same. You just need to sand down the outer rib on the wheel. The inner rib then provides good support for the inner bead of the tire.
their procedure also gives you the addeed bonus of naturally providing about 1/2 degree of- camber. Nice for the rear tires where you don't have any camber adj
BM
Hi,
Greets
Stefan
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-31-2011, 08:16 PM   #6180
Hi F1 fans,
I have my new F104W almost ready to maiden, but would like some suggestions on adding ride height. I have Shimizu rubbers , on the kit foam rims , with which I only have 3mm ride height.
I was going to swap the rear axle holders for the tallest one (#1 I think), but I need to get the front up as well. Do I need to shave the steering block and and shim it down to raise the front up ??
Or do I just add preload shims to the front kingpin springs (making for less travel) ???
I will be running outdoors on dusty asphalt + bumps. I have a HW s/less 13t onboard + 2S stick pack lipo.
Racing program on # pause #
RedBullRacing is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
