Old 08-25-2011, 10:43 AM   #6091
monkee's Avatar
Trader Rating: 15 (100%+)
Sorry for what may be a dumb question..
I bought a used f104pro and i need to replace the front body mount post thing.
i see the part in the instruction manual but i cannot find the part number.
any help would be appreciated
thanks
monkee is offline   Reply With Quote
Old 08-25-2011, 12:01 PM   #6092
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
thanks
The post will be on a plastic parts tree, it doesn't have it's own part #
you would be better off upgrading to the aluminum part
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 08-25-2011, 06:04 PM   #6093
Vyger's Avatar
BP, those look SAAWEEEET! I can't wait to get my paws on those.
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 08-25-2011, 07:58 PM   #6094
is there anyone using the 'Heavy Weight Pivot Post ' ???
does it help for rubber tires ???
Marco926 is offline   Reply With Quote
Old 08-25-2011, 09:52 PM   #6095
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
yes, i'm using it - makes the car much heavier, which helps for rubber tires and asphalt....i did notice a difference in the car's handling with it
i'm also using the TRG heavy rear shaft so i gots lots of extra weight to the rear of my car
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-25-2011, 10:02 PM   #6096
i'm using the rear steel shaft from tamiya, already better a lot, so it will be even better if i use the heavy pivot post, but will it be too heavy for using both ???
Old 08-26-2011, 04:50 AM   #6097
k_bojar's Avatar
i'm sure there will be a point where too much weight will screw with the performance of the car, but you aren't going to be near that point yet. the weight you're adding, to this point, is doing nothing but adding rear traction so-to-speak...
If you look at Robk's site - http://rcf1blog.blogspot.com/ - you can see one of his 104 setup wihere he's using rubber tires AND a buch of weight in addition to the heavy pivot plate and steel axel..
alot of RC cars function better the heavier they get - VTA's are an example of that - and F1's aren't any different...mine, with the heavy pivot post and TRG axel, is significantly heavier then the stock 104, but IMO handles uber better since the rear is planted way better
Old 08-26-2011, 05:11 AM   #6098
k_bojar's Avatar
thanks
you're right its not in the manual - probably part of the body kit supplements
you can always check out other places online to find the part numbers - i usually use towerhobbie or speedtechrc
blue aluminum ones - http://www.speedtechrc.com/store/ebp...id=770&id=9263
there's a plastic one on part 50655
and here's the 2 piece aluminum ones - http://www.ebay.com/itm/53120-TAMIYA...item2eb5b8ae55 - 2 pieces as in you get 2 front posts
Old 08-26-2011, 05:15 AM   #6099
mattwoodcraft's Avatar
alos use the the split top deck that tamiya release for the 104 that combind with the heavy pivot post steel rear axle its great with rubber very consistant
mattwoodcraft is offline   Reply With Quote
Old 08-26-2011, 11:00 AM   #6100
E-clip's Avatar
Trader Rating: 39 (100%+)
Default Looking at buying a F104
Hello
Which is the better kit the Pro or the X1 version ??
and does the X1 come with the rubber tires ?
thanks Guys
E-clip is offline   Reply With Quote
Old 08-26-2011, 02:02 PM   #6101
monkee's Avatar
thank you !!
what are most people running in these?
13.5 or 17.5 if brushless?
25t pinion?
Old 08-26-2011, 04:12 PM   #6102
k_bojar's Avatar
thank you !!
25t pinion?
actually its more like silver can or 21.5
and i'm running standard 64p spur - 88t with like a 34/35t pinion
Old 08-26-2011, 10:53 PM   #6103
BP SHADOW's Avatar
Originally Posted by E-clip View Post
Hello
thanks Guys
The X1 doesn't come with wheels tires or a body.
I just got done testing mine for the Tamiya Nats, and the car is awesome.
It is on the pricey side, but is really good, hooked up pretty much right out of the box
http://f1rclab.com
Old 08-26-2011, 11:16 PM   #6104
WaWa's Avatar
Trader Rating: 19 (100%+)
BP, be sure to keep us posted on the NATS.... we're expecting photos of your car!!
Best of Luck!!!
WaWa
WaWa is offline   Reply With Quote
Old 08-27-2011, 04:53 AM   #6105
ubik77es's Avatar
Hi guys,
I'm from Spain and being riding a F104-F60 a year ago. Since I tryed it i loved. It were my first RC. Step by step I upgraded it like a F104PRO and seems next year we would have F1 regional championship. Still using Tamiya tyres but thinking on trying Shimizu ones because here we have low grip and think Shimizu rear ones would give a point
By now thats my car. Hope you enjoy
ubik77es is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
