Like Tree5Likes
Old 08-05-2009, 12:37 PM   #571
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
[QUOTE=robk;6160719]This is called caster
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 08-05-2009, 04:58 PM   #572
F N CUDA's Avatar
Trader Rating: 31 (100%+)
F1 is alive and well in So. Cal!
Now the link is better, check it out and add input yo!
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-06-2009, 09:03 AM   #573
InZane's Avatar
Default Saddle pack Lipo
I think saddle pack lipos is the way to go - neater wiring and better protection for the electronics on the chassis plate. I'm not sure if it has any affects on the handling but I really don't like the asymmetric position of the posts for the upper plate . It makes the right side of the chassis softer than the left. When using saddle packs you can mount the posts parallel instead.
InZane is offline   Reply With Quote
Old 08-06-2009, 10:19 AM   #574
magerp's Avatar
Does anyone have any tips for reducing front tire wear? (except for not driveing the car. LOL) My front tires didn't last one day. My rear tires look brand new.
magerp is offline   Reply With Quote
Old 08-06-2009, 03:10 PM   #575
TfnG's Avatar
Trader Rating: 26 (100%+)
very good idea. i havent really done anything with mine but build it and let it sit. i had the same thoughts as you though...didnt like the position of the posts...for the same reasons u said.
GRAVECLOTHING.COM PROLEVELRC.COM
TfnG is offline   Reply With Quote
Old 08-06-2009, 04:28 PM   #576
veecee's Avatar
Trader Rating: 34 (100%+)
It will be interesting to see how that works. There are conflicting views on whether stick packs mounted sideways work better than lengthways. This would be a good compromise.
Nice work on angling back the servo. I decided to use the shorter kit servo saver and angling the servo a little. Zero bump steer!
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 08-06-2009, 05:34 PM   #577
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Will the body fit with the side pods on it in this configuration?
I wouldn't want to lose the look of the new body and its sculpted sides
akura2 is offline   Reply With Quote
Old 08-06-2009, 05:38 PM   #578
veecee's Avatar
It should. Looks narrower than a stock F104 with component trays, although the packs are further back in the chassis.
Old 08-06-2009, 07:37 PM   #579
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Default Saddle packs
This looks interesting, but how are the packs secured? Don't fancy using tape, since club rules require that LiPo cells are charged in a LiPo sack. Admittedly, it would help with my wiring, particularly the power cap on the GTB.
I'm happy with my 3800mAh NiMH stick pack configuration - the LiPo stick pack I tried didn't fit easily with the standard battery clip, because it fouled with the balance lead.
Has anyone tried one of the LiPo bricks with the side connectors?
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 08-06-2009, 07:39 PM   #580
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
perhaps that corally/IP Lipo 'stick-a-like' pack would be ideal?
R
UltegraSTI is offline   Reply With Quote
Old 08-06-2009, 11:18 PM   #581
alan1467's Avatar
How is the T Piece secured to the chassis? as it uses a resar post and a screw/nut?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 08-07-2009, 12:03 AM   #582
InZane's Avatar
I'm using the kit nuts (not the nylock ones) to secure the T-bar. The lipo pack slides nicely into place - there's a 0,5mm play between the nut and the pack.
I'll post some more pics whith the electronics mounted and wiring done - it will be super neat!
Old 08-07-2009, 08:40 AM   #583
TfnG's Avatar
how are you holding the battery in place?
Old 08-07-2009, 09:11 AM   #584
InZane's Avatar
I'm working on a Calandra like rubber o-ring mount. Shouldn't take more than 15 secs to make a battery change.
This is a pic of a a very much pre-prototype mount ( I know - I cant have a nut under the upper plate) - I will need some kind of stop in front of the lipo pack (not yet ready)..
Old 08-07-2009, 10:18 AM   #585
InZane's Avatar
There are a lot of nice new option parts for the F104 coming from 3Racing - the upper deck for Lipos is ace!
The all new 3Racing F1-09 looks extremely promising as well
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
