Like Tree5Likes
Old 08-02-2009, 08:03 PM   #556
Trader Rating: 87 (100%+)
Default f104
hey guys, I have brand new f104 for sale! here is the link.
FS: Tamiya F104 with hop ups!! GTB and 10.5t
Thanks.
bluecusion is offline   Reply With Quote
Old 08-03-2009, 12:40 AM   #557
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by prime View Post
as of the time of this post, Vellrip have 1 in stock for $195US, link is;
http://www.vellrip.com/store/product_details.asp?p=1920
hope this helps someone out.
Gone...
good price...
$195 is dealer cost... they must make it up in the $48 shipping
akura2 is offline   Reply With Quote
Old 08-03-2009, 12:52 AM   #558
Originally Posted by fox88gt View Post
I have heard through the grapevine that the F104 body will fit on the old F201chassis. Anyone know if there is any truth to that? I'd really like to update the looks of my f201 to '08 spec (to go along with my shelf-queen F2001 body). Sadly no one races F1 in my area...not that the F201 would be competitive with the F103RM's and new F104 anyway, I'm just an F1 fanatic.
negative, the f104 body is too short. I have my f201 sitting next to my f104. Even if you don't use the side pontoons (i.e. leave it ugly ) you'll have a hard time fitting the battery under there.
Apart from the 4wd part, I think the F201 is more 'F1' with all the bits (including an easy to break gearbox!! )
torg is offline   Reply With Quote
Old 08-03-2009, 12:59 AM   #559
Originally Posted by akura2 View Post
Gone...
good price...
ultimatehobbies has them in stock, not sure if they ship outside the US, I'm spoiled, I jump in my car and I'm there in 10 mins
Old 08-03-2009, 01:44 AM   #560
akura2's Avatar
same here... been trying to decide how to sneak one into the house... I was going to go to Ultimate today, but the wife had me on lock doing housework with her....
Old 08-03-2009, 10:46 AM   #561
fox88gt's Avatar
Thanks for the info! I figured someone out there had an F201 laying around. I also think the F201 is very 'F1'ish. I did one time take the front drive shaft out of mine to try it as a 2WD and wow, between the rubber tires and 17t modified in mine i'm surprised the rear tires didnt start graining from all the wheelspin! I just had to try it though....
fox88gt is offline   Reply With Quote
Old 08-03-2009, 11:02 AM   #562
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by gtypecanare View Post
Here is my F104 as it is so far, I'm planning on using the Orion 2400 and 3200, as well as the Reedy 3400. All these batteries fit really well without any major modification, just a slight trimming down of the battery holder.
Some aero tweaks
How do you get the wires on the Orion's to fit? The chassis gets in the way where I can't get the plugs to fit.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 08-03-2009, 11:44 AM   #563
Vyger's Avatar
Nice lookin ride Gtype! I can't wait to see that car when it's done. It's a runner right?
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 08-03-2009, 01:14 PM   #564
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
The guys the Tamiya track make the red wire long, plug it into the battery before sliding it under the upper deck, the red wire remains on top of the battery and takes up the space between the battery and the upper deck. Plug the black wire in before sliding the battery in. You must wire the 4mm plugs at a 90 degree (make sure that you lay the wire on a 90 degree to the 4mm plug when soldering)
hope that makes sense
ALL TAMIYA 4 WHEEL DRIVE ALL THE TIME
TRF-416X, SP CIRTIX, LRP X-12 17.5, FUTABA 9550
SRBMOJO is offline   Reply With Quote
Old 08-03-2009, 01:28 PM   #565
blade329's Avatar
Thanks for the info. I'll have to solder some new 4mm plugs.
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
Old 08-03-2009, 02:02 PM   #566
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Hey guys. Just got my F104 from my shop. They ordered it for me a week ago and it finally came in.
Any tips on building it? I've built an F103RM, F103R and a F103GT so it shouldnt be anything new to me.
The only part that looks a little tricky is the body. How did you go about cutting out the body? Did you cut or leave the side pods on?
SerpentCT4S is offline   Reply With Quote
Old 08-04-2009, 09:20 AM   #567
Hey, Ive started building my kit.
I ran into a small problem while putting on the top arms, steering blocks and pins. My upper and lower arms arent lining up with each other. Therefore, when I put the pin through the steering block, the pin isnt straight, its leaning towards the back of the car. I know it shouldnt be like this, no other F1 I built has had this problem. When I put the pins and springs on the front and put the clips top and bottom of the pin, the whole assembly is leaning towards the back of the car. There is also no movement in the pins and spring because its not even. The pins should be upright, correct? Any idea whats wrong?
Old 08-04-2009, 09:34 AM   #568
blade329's Avatar
I just built mine last week. I think it's supposed to be that way. Just make sure those little ball things are firmly pressed into the arms. I also noticed that the distance of the ball cups on the turnbuckles is totally off (21mm).
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
Old 08-04-2009, 01:09 PM   #569
robk's Avatar
Trader Rating: 22 (100%+)
This is called caster
As was posted before, make sure the balls are free in the arms. Make sure the pins move smoothly in the balls/arms without the steering blocks.
robk is online now   Reply With Quote
Old 08-04-2009, 02:00 PM   #570
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Hey you F N F1 racers, check out this new thread from 240Z!
Gonna get a direct connection to the F1 scene in So Cal by coordinating track times so we can overwhelm chosen tracks on given days!
He calls it an F1 Swarm!
I like it, join in, show up and let's race.
The tracks will love us and you know more will join in!
F1 is alive and well in So. Cal!
Craig Hammon
F N CUDA is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
