Tamiya F104 Pro!
#5386
Hi guys, I'm having trouble with the plastic diff in my F104. Like normal I took the wheel off, put it back on and went to set it up again, however something has changed and it no longer functions like normal, the two rear wheels lock together straight away, and I can't do anything about it. I've tried everything, cleaning it, re-greasing it, re-assembling it, but I can't solve it....any ideas???
And yes, I will be getting a pro shortly...
#5387
You have 2 ways to go- X1 or buy a F60 or McLaren kit and put a couple things on it, like the split top deck, heavy pivot, shock, and maybe pro diff. The pro black or pro are great, but I'm starting to think that the split deck, heavy pivot, and FRP lower are a big advantage. So you're paying for stuff that may not do you a lot of good.
#5388
#5389
#5390
#5392
I shoegooed 25g lead under each of the side pods for the electronics. works like the heavy pivot but more like a f103 with the weight transfer
#5394
#5395
YYes .... I have my new F104Pro Black Special Edition on order. :-)
Now the fun will begin.......
Getting a" WolfPack" Lips battery for her. Does everyone run them? Couldn't find any other Lips that fits??
Getting son Pit and Tamika tires too........
BM
BM
#5396
Anyone using the 3racing one piece t-plate/rear pod plate? I just put on the 1.3 one without the center pivot screw and it seems like there is a lot more compliance in the rear suspension than the soft Tamiya t-plate. Hopefully I'll get to try it out Sunday after work and see how it does.
#5397
I've put these washers in just like it shows in the manual, but its still no go. Is it possible these things can wear out? because I am convinced they are the problem...
#5398
