Like Tree5Likes
Old 06-02-2011, 11:56 PM   #5326
unknownmember's Avatar
I'm guessing this maybe rather absurd but I was thinkin of hotting up one of these for pure straight line speed. Will the tranny allow me to do so? Thinkin of a 3 - 3.5T 2S. Now you might be askin why not just get a pan car? Coz I'd like it to be as scaled looks as possible yet still have the ridiculous speed. This is not first attempt at squeezing out top speed with an RC car though. Tried it with my TCX without any mods, significant setup or proper gearing and it managed about 100KPH. Though I did mounted a front spoiler like the Scion time attack car but not as high tho, just in line with the hood. And a front splitter which I'm not sure if it made any difference but I do know the front spoiler did a lot It bottom out the front of the chassis lol and yes I did jacked up the front end after I mounted the spoiler.
unknownmember is offline   Reply With Quote
Old 06-03-2011, 12:00 AM   #5327
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by F N CUDA View Post
Then I'll just say never gonna happen for me, my 103 is bolted and strapped and my 104 is just screwed down tight.
pHHT- for 4 minutes
See you Sunday buddy!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-03-2011, 12:11 AM   #5328
F N CUDA's Avatar
Trader Rating: 31 (100%+)
If I can get 4 minutes I'm on to something good.
So it's NOT gonna rain?
Could get ugly.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 06-03-2011, 04:25 AM   #5329
kneedeeppow's Avatar
it rains in cali???,noooooooooo
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 06-03-2011, 07:51 AM   #5330
probably would get better stability out of an F201, tamiya's 4wd F1 car.
i may be new to this forum but my opinion (for what its worth) is that making an F104 super fast is very similar to what i say to micro forum members when they make a Mini-Z super fast...a neat acheivement but not very useful.
I wonder what rocket scientists say to their co-workers when one of them doesn't get it?
cowboySiR is offline   Reply With Quote
Old 06-03-2011, 10:07 AM   #5331
Having run an Xmods at over 10 volts, I agree. But it was still fun as heck eve though it burned the motor after runing.
That said I am thinking of runing an f104 with a 3cell lipo for fun.
kb525 is offline   Reply With Quote
Old 06-03-2011, 11:14 AM   #5332
The tranny in the F104 will handle it easy...there is no tranny...it only has 2 gears and is direct drive. The problem is going to be like any other pan car...traction.
The F201 would be easier to drive given that it is 4wd...however the tranny will not take that much power without melting down.
Old 06-04-2011, 04:42 PM   #5333
Send a message via AIM to Deznuts05
Hello I'm trying to find the bearing sizes for this kit.
I've read the manual cover to cover and it doesn't state their size. I figure they are metric but as per size I have no clue.
Any help would be appreciated.
Front Wheels
Rear Axles
Diff
Thank you,
Rudy Diaz
"Power is nothing without control" Ryuken
Deznuts05 is offline   Reply With Quote
Old 06-04-2011, 04:55 PM   #5334
Pro10noob's Avatar
Behind the part number it says for example 1060
This means that the bearing is 10mm outside and 6mm inside diameter
Tamiya uses the size in 2 pairs of numbers
850 means 8 outside 5 inside and so on.
1280 are the diff bearings(12 outside 8 inside)
1060 are the rear axle bearings(10 outside 6 inside)
1050 are the front wheel bearings(10 outside and 5 inside)
regards Roy
Front Wheels
Rear Axles
Diff
Thank you,
Rudy Diaz
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-04-2011, 08:19 PM   #5335
CR0SS's Avatar
regards Roy
The only measurement I had issues finding was the width. I did a google search for the part number and some Ebay auctions had pictures of the bearings in packaging. The packaging had a small diagram with all the bearing dimensions.
I cannot find the sheet of paper where I wrote all the sizes down. If I find it I will post them up.
You know the guy that beat you at the last race? It was not because of his car, or motor, or battery, it is because he was a better driver. Now go practice so you can beat him.
Visit my Youtube channel for HD R/C videos. http://www.youtube.com/user/DHCross1
CR0SS is offline   Reply With Quote
Old 06-04-2011, 09:46 PM   #5336
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default Bearing dimensions
I've used www.avidrc.com search box to find the exact dimensions of bearings.
For example, type in 5x8 for an 850 bearing, and the width is 2.5, etc.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 06-05-2011, 02:09 AM   #5337
mattwoodcraft's Avatar
i have been thinking of getting some bearings what are the thoughts on ceramic bearings. Is any one using these at all
mattwoodcraft is offline   Reply With Quote
Old 06-05-2011, 04:34 AM   #5338
Andrew Barr's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Andrew Barr View Post
For those who have tried the Spice Foam tyres and rims, do they come with the double sided tape similar to the Tamiya sponge tyres or will I have to glue them.
If gluing is required, what is the best glue to use, contact glue or CA? I have never had to glue foam/sponge tyres before.
Thanks.
Anyone???
Giant MTB
Andrew Barr is offline   Reply With Quote
Old 06-05-2011, 05:52 AM   #5339
Mr P!nk's Avatar
Anyone???
Sorry I can't answer your first question, but as far as glueing goes I use contact cement for glueing counter tops. Just brush a coat of it onto the wheel, and a coat on the inside of the foam and let them dry for about 15 minutes. Then dunk both in some laquer thinner and they'll slide right together. Use some paper towel and laquer thinner to clean off any of the glue that gets on the side walls.
Its actually a pretty easy task once you do it a few times.
Have you ever wondered how much deeper the oceans would be without sponges?!
Mr P!nk is offline   Reply With Quote
Old 06-05-2011, 06:49 AM   #5340
CR0SS's Avatar
I just put ceramic bearings in the front wheels. I also have a set for the rear axle I have not put in yet. I will let you know how they work out.
Out having some fun yesterday.
+ YouTube Video
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
