Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 05-11-2011, 02:11 PM
  #5161
squarehead's Avatar
Trader Rating: 75 (100%+)
Thumbs up
Originally Posted by robk
Rc4less also has mounted tires.
squarehead is offline
Old 05-11-2011, 05:33 PM
  #5162
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by kuanseng1981
Btw have any1 tried to mod the F104 to fit a normal Square Lipo pack rather than a rounded stick pack
no need to mod, just put the battery in unconventionally..
Arahawak is offline
Old 05-11-2011, 05:46 PM
  #5163
The F104 doesn't have rounded battery holders like the old F103 did so a normal flat sided LiPo should fit in it just fine. I say should because I haven't installed electronics in mine yet to find out.
InspGadgt is offline
Old 05-11-2011, 05:49 PM
  #5164
MantisWorx's Avatar
Trader Rating: 28 (97%+)
thanx ,just ordered a few sets from RC4less, hopefully they last longer than the Tamiya
MantisWorx is offline
Old 05-11-2011, 07:11 PM
  #5165
Hey Guys,
im ordering my f104 tomorrow but i'm having a hard time picking between the F104 Pro and F104 F60, i know the pro has ball bearings and so forth but what would be the best one to get.
Also there is alot of people running 32t motors to 21.5t and would running brushless compared to brushed make a difference in the leanring curve.
I currently have the HPI F10 with the exotech and yeah racing upgrades, but i havnt run it yet and was wondering how they would compare to each other as i had nothing but over steer issue with my 13t motor in the f1 car lol.
Sorry if im asking noobish questions but i want to make sure i get the right car for me with as much research and asking questions from experianced people.
pokiou is offline
Old 05-11-2011, 07:23 PM
  #5166
cheROK1212's Avatar
Originally Posted by pokiou
Hey Guys,
F60=rubber tire and more flexible chassis, asphalt car (rubber tires take time to tune but last)
F104 Pro=foam tire graphite chassis, carpet car (foam tires give more traction but wear quicker and require more attention to optimize)
HPI F10=F104 bait
cheROK1212 is offline
Old 05-12-2011, 04:45 AM
  #5167
new photos......enjoy~~~
Attached Thumbnails Tamiya F104 Pro!-1.jpg   Tamiya F104 Pro!-2.jpg   Tamiya F104 Pro!-3.jpg   Tamiya F104 Pro!-4.jpg
Marco926 is offline
Old 05-12-2011, 07:01 AM
  #5168
squarehead's Avatar
Wow, that's really pretty. Calls for a JPS paint job, too...
Old 05-12-2011, 07:48 AM
  #5169
k_bojar's Avatar
Trader Rating: 30 (100%+)
interesting...upper and lower FRP plates...I wonder if the FRP upper split deck will be available separately??
look nice - don't get me wrong, love the tamiya blue but it don't look right showing so much with the F1 bodies
k_bojar is offline
Old 05-12-2011, 08:06 AM
  #5170
squarehead's Avatar
So I decided to completely rebuild the F104 that I have in hopes of eventually getting to race it on asphalt this summer. In rebuilding the car, though, I noticed to alignment issues that will cause potential issues, and I'm wondering how you guys are compensating for them.
One, the front end sits in slots in the chassis, and then is clamped down through the two LONG screws that go through everything. In this assembly, it is entirely possible to turn the whole front end in the chassis at least 1 or 2°—completely away from square.
I noticed the same thing in the attaching of the rear pod to the T-bar—you can cock the rear end in the car at least a couple of visible degrees from square in the chassis, even when everything is clamped down.
Short of putting everything together, and then getting wheelbase measurements and cross dimensions, how are you guys assuring that EVERYTHING is perfectly square when putting it all together? Am I missing something obvious?
Rob, are you out there?
BTW, if anyone would like a super clean brushed Novak GTX, a new silvercan and a one-run Orion Rocket Pack LiPo, I'll have them in the Classifieds shortly.
Old 05-12-2011, 09:08 AM
  #5171
MikeR's Avatar
Trader Rating: 15 (100%+)
HPI F10=F104 bait
Lol I dont know- in the UF1 series here the F10 finished 1 and 2 in the rubber class We'll see how the F104's fare this week at the UF1 round at the Tamiya HQ track.
MikeR is offline
Old 05-12-2011, 01:24 PM
  #5172
robk's Avatar
Trader Rating: 22 (100%+)
Chauncey has not seen the Exotek/HPI team in action due to the Mississippi river and the Rocky mountains being in the way....
robk is offline
Old 05-12-2011, 01:34 PM
  #5173
robk's Avatar
This is a used car right? Is the plastic ok or is worn? I really have never had a problem with this kind of stuff (dog tracking, etc.)
The other thing is I'm assuming you are using a wide front end? The F104 front end is also located by the screws that go through the servo mount, so I can't imagine there being too much problem if it's located by 4 screws. The old front end, yeah maybe.
One thing I had to do with my 3 Racing car was to pin the front end. I got it lined up straight and then drilled 4 holes in the "slot" area of the front end, and used grub screws to keep everything lined up.
PS We just need to get you down to the track so we can shake that thing down. I think you are suffering cabin knee fever. LOL
robk is offline
Old 05-12-2011, 01:43 PM
  #5174
Another thing you can do is build up a few layers of CA around the slot edges until the arm fits tight in the slot so it can't move around.
Old 05-12-2011, 02:18 PM
  #5175
squarehead's Avatar
Yeah, use car. I just put the F104 front end on it for now (the wide front end just LOOKS wrong). This car will probably be my 3rd class car, so I'm not sure how far I want to dig into it to get into "race" mode.
I think as I built it back up, a lot of the centering comes from the countersinks on the screws, for the most part. Once everything is tightened up, it seems to be relatively square.
Good grief, you aren't kidding at all! This is what I get for having the VTA and USGTA cars done and ready to race—I get to overthink the setup on a plastic-fantastic F1 pan car for a month and a half. Now, about those rubber tires...
