Tamiya F104 Pro!
#5042
The Tamiya soft rear tire is still very hard compared to others like Shimizu. I ran the UF1 at Corona two weeks ago and simply by changing the rear tires, my car went from sweeper-spun to super understeer. But again, this car is a lot easier to drive starting from under steer.
So I think my next step is:
1. Shimizu medium front
2. Shimizu soft rear
3. Medium spring front
4. Soft shock (red and Muchmore 400 oil
5. Softest T-bar (high traction T-bar)
I think the above setup should, in theory, makes my car more neutral. Also, I use lay-down servo (need low-profile servo) so that I don't have bump-steer and I can adijust ackerman by moving the servo forward and aftward.
What is the preferred T-Bar to use for low traction?
Thanks!
#5043
Hello, newbie to F1 and I was wondering if someone could clarify the T-bar setup for me. I see a Soft T-Bar for the F104 (I'm guessing this is the one you want for low traction) and then theres the High Traction T-Bar. I have an F104 Pro Black edition. Would the T-Bar that came with the car be the medium setting?
Thanks!
Thanks!
1. 4005131 Kit T-bar: Standard
2. 54165 Soft T-bar: Medium
3. 54222 High Traction T-bar: Soft
Low traction surface use 54222 High Traction T-bar. The name "High Traction" refers to the handling, not the surface, which is kind of misleading.
If you run foam on good grip surface, then go soft T-bar. If you have too much grip and rear of the car is too planted, go with kit T-bar. Remember you can also play with the tightness of the center screw as well.
#5044
macavant, the realism is very nice
Which do you prefer, the F103 or F104W?
#5045
Pain in the ass cuz there is only so much you can do for the rear end of this thing.
After you have done it all, split upper deck, soft feel on everything, spring, shock oil, damper plate, T bar, o ring etc... then move on to the front end.
Stiff front springs, medium to hard tires, toe out, ride height higher than the rear.
Make it push some how when exiting the corners.
Oh yeh, good luck with that.
ok so i did most of this stuff the spring shock oil split deck t bar ... but whats the trick with the damper plate and o ring can anyone explain this for me thanks
#5047
#5049
Thanks!
Thanks!
#5050
The softness is as follows:
#5051
One thing to remember is that the soft t bar and high traction t bar are close to the same thickness, but with the cutout the high traction t bar also lets the car "wrap" the corner or rotate more. I noticed the guy who won the TCS nats last year ran the soft tbar, and that makes sense as the Tamiya track is a place where you would want the car more stable. You might actually want to try both to see what works for you.
I'll be running Rubber tires on asphalt. This is my first venture into F1. Watching the UF1 series run out here in SoCal just looked waaaayyyy toooo fun. Been reading this board to learn as I much as I can to be competitive. From what I gather, rear traction or lack thereof is what most are experiencing.
#5052
Thanks for the advice. I will have all 3 options in my pit box.
Welcome to UF1!
Some are experiencing heaps and heaps of traction It's all in the tires, set up and equipment. Hope to see you at the next round- May 14th at the mighty Tamiya track!
Vid from last week (thx Charles);
Look at all them F1 tires
http://youtu.be/c4-O9-WG224
#5054
The center screw, which has to be left in for TCS racing, I would always loosen it to where it would still just barely sit in the counterrsunk hole when fully "bending" the T bar up in the rear.
I would never have been able to drive with that setup since I have never been able to get as much rear traction as I would like on this car when using Tamiya tires and I always chose the soft rear option tires with the kit medium fronts and still wanted more rear bite. I also have never looked back to anything other than the High Traction T bar since this is also the best rear grip that I have had on this car.
I also use the gold spring that seems to be hard to get but it is the softest spring that I know of that is a Tamiya part, from the Miata mini kit or something like that.
#5055
so the difference betwwen 104 and 104w is a 103 front end and 103 rear wheels? has tamiya released any 104w body sets yet or will the 103 bodys work? thanks
