Old 04-20-2011, 04:18 PM   #4981
Default Does this exist? If so do you have pics?
Originally Posted by The Big Wig View Post
Fancy the same car?
I'll give you a headstart with the partslist:
F104 M.A.D. Spl.:
Tamiya: (http://www.tamiya.com/)
42131 HL Cylinder For TRF Special Dampers (2pcs.)
42137 Competition O-rings for Oil Damper
42165 TRF Damper Pistons (Blank / 4pcs.)
50395 Racing Developed Front Upright Set (1 Pair)
50509 F-1 Front Spring Set
53101 Racing Developed 0.4 Steel Pinion Gear Set (20T, 21T)
53102 Racing Developed 0.4 Steel Pinion Gear Set (22T, 23T)
53103 Racing Developed 0.4 Steel Pinion Gear Set (24T, 25T)
53117 Racing Developed 0.4 Steel Pinion Gear Set (26T, 27T)
53120 Racing Developed F-1 Aluminium Front Body Mount
53259 Formula 3.5mm Offset Upright
53262 0.4 Steel Pinion Gears (28T, 29T)
53918 Low Friction TRF Damper V-Parts
54160 F104 Titanium Coated King Pin (2pcs.)
54161 F104 Low Friction Suspension Ball Set
54165 F104 Soft T-Bar
54166 F104 Aluminium Motor Mount (Left & Right)
54202 F104 Aluminium Upper Suspention Mount
54208 5x8mm Aluminium Hex Head Ball Connctor (Fluorine Coated, 5pcs.)
54209 5x5mm Aluminium Hex Head Ball Connctor (Fluorine Coated, 5pcs.)
54222 High Traction T-Bar
54278 F104 Separated Upper Deck
54281 F104 Heavyweight Pivot Post
84013 5mm Aluminium Short Ball Nut Black (10pcs.)
84120 RC Body Set Ferrari F60 Lightweight
84170 F104 Pro Black Special with Light Weight Body
3455898 Antenna Post
14005133 F104 Lower Deck
14025071 F104 Upper Deck
Abec 35: (http://www.abec35.com/)
3.0mm C 3.0mm Ceramic Diff Balls (10pcs)
MR106(2.5)-C3 6x10x2.5mm General Ceramic Hybrid Ball Bearings, ABEC3(x2)
MR115-XCO 5x11x4mm Type X Ceramic Hybrid Ball Bearings, XCO
Associated: (http://www.teamassociated.com)
#8546 M2x6 BHCS Blue Aluminium (4)
#8547 M2x6 FHCS Blue Aluminium (4)
Atomic: (http://www.rcatomic.com/)
TS-BSM2612M M2.6x12 Titanium Button Head Hex Socket Machine (10Pcs)
Blade: (http://www.blade-racing.com/)
BL616 Friction Pad
Boca Bearings: (www.bocabearings.com)
#SW85C-OS7AF2 5x8x2.5mm Orange Seal Ceramic Bearing (4 pack)
#SW106C-OS7AF2 6x10x3mm Orange Seal Ceramic Bearing (4 pack)
#SW128C-OS7AF2 8x12x3.5mm Orange Seal Ceramic Bearing (4 pack)
HPI: (http://hpiracing.com/)
102832 Helmet Parts Set
Kawada: (http://www.kawadamodel.co.jp/)
B61M Thin-Shaped Heat Sink M
FO27 Delrin Suspension Ball For F103
Keyence: (http://hobby.keyence.co.jp)
OP-84432 Chevalier Dash
Ko Propo: (http://www.kopropo.com)
21002 KR-409S Micro Reciever
30048 PDS-951 ICS Servo
40047 VFS-1 Pro C3
45515 Ultimate Shotki Diode Single
Kose: (http://kose-rc.com/)
K-1604 3mm Shim Set
K-1633 1050 to 850 Bearing Holder
K-1636 6mm Shim Set
MRT: (www.team-mrt.com)
PTX Transponder
RC Square: (http://rc-square.com/)
SFC-20G Tamiya F103 Height Adjustable Guides
SGE-14SBK Aluminium 4mm Flanged Serrated Nut
SGE-905BK 0.5mm Spacer Black (8Pcs)
SGE-910BK 1.0mm Spacer Black (8Pcs)
SGE-915BK 1.5mm Spacer Black (8Pcs)
SGE-920BK 2.0mm Spacer Black (8Pcs)
SGE-925BK 2.5mm Spacer Black (8Pcs)
SGE-930BK 3.0mm Spacer Black (8Pcs)
STR-335 3x35mm Hex Countersunk Screw
STR-430 4x30mm Hex Countersunk Screw
FAW-306B 3x6 Hex Flanged Buttonhead Screw (4 Pcs)
Squat: (http://www.squat.co.jp/)
S786 Tamiya F103 Roll limiter
Take Off: (http://takeoff.main.jp/)
TO-365BK High Traction Tape
TS-252 Titanium M3 Locknut Thin Type (H3.3)
TS-208BK M4 Locknut Thin Type
TS-205BK M2 Locknut Aluminium
TS-201BK M3 Locknut Aluminium (H4)
TS-207BK M3 Nut
TS-332BK M3x8mm Hex Socket CSK Screw
TS-333BK M3x10mm Hex Socket CSK Screw
TS-381BK M3x6mm Hex Socket Button Head Screw
TS-382BK M3x8mm Hex Socket Button Head Screw
TS-383BK M3x10mm Hex Socket Button Head Screw
TS-384BK M3x12mm Hex Socket Button Head Screw
TS-111BK M3 Washer Aluminium 0.5mm
TS-1151 M3x6mm Magnesium Button Head Screw
TS-1152 M3x8mm Magnesium Button Head Screw
TS-1153 M3x10mm Magnesium Button Head Screw
Team Orion: (www.team-orion.com)
ORI14155 TS Rocket Pack LiPo 3500 IBS
Titanium Racing: (http://www.titaniumracing.com)
6 mm M3 Titanium Countersunk Screw
8 mm M3 Titanium Countersunk Screw
10 mm M3 Titanium Countersunk Screw
12 mm M3 Titanium Countersunk Screw
20mm M3 Titanium Countersunk Screw
TOP Racing: (http://www.top-racing.jp)
TI-CM0206 Titanium Coutersunk Machine Screws M2x6mm(10Pcs)
TQ Racing: (http://www.tqracing.com/)
#2200 Triple Black 22 Gauge Servo Extention
#13313 13 Gauge Wire Black
TRG: (http://www.rc-trg.com/)
TRG-5029 Rear Ride Height Blocks
TRG-5088 Servo Saver Horn Short
I am just finishing my Exotek Pro Black (my first F1) and thought that I was doing somthing,but if THIS CAR exists then I may have to go back to the drawing board......I would love to see it
TWILL is offline   Reply With Quote
Old 04-20-2011, 04:28 PM   #4982
CR0SS's Avatar
Look at post #4939
You know the guy that beat you at the last race? It was not because of his car, or motor, or battery, it is because he was a better driver. Now go practice so you can beat him.
Visit my Youtube channel for HD R/C videos. http://www.youtube.com/user/DHCross1
CR0SS is offline   Reply With Quote
Old 04-20-2011, 04:49 PM   #4983
Default Didnt know this was the build.
The attention and care given to this build is AWSOME! I its almost too good to put on the track and I really would never run it outside.The person that said that the build is as much fun as racing hit the nail on the head.Great Job
Old 04-20-2011, 04:58 PM   #4984
The Big Wig's Avatar
Thanks. Well the research on wich parts to get is maybe the hardest and it feels fantastic when it all comes together. These pics where taken just after I TQ'd and won the race!
The Big Wig is offline   Reply With Quote
Old 04-21-2011, 12:01 AM   #4985
hopndrop's Avatar
sweet build list, love to see the final product
hopndrop is offline   Reply With Quote
Old 04-21-2011, 12:24 AM   #4986
Trader Rating: 26 (100%+)
Originally Posted by CR0SS View Post
Look at post #4939
I think you'll find that this is the final product...
$$$... is offline   Reply With Quote
Old 04-22-2011, 05:12 AM   #4987
the new tamiya 2 piece upper chassis for the 104,would banana plug style lipos have a better shot at fitting?
any thoughts on running saddlepacks? could they be secured enough?
thanks
freakyfreakyflo is offline   Reply With Quote
Old 04-22-2011, 05:26 AM   #4988
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
thanks
There is more clearance to run the orion style connectors. I am getting ready to put the separated deck on my car, I will post pics,
Also I have both the separated decks and the heavy pivot post available for sale. PM me for more info
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 04-22-2011, 05:30 AM   #4989
more clearance is good want to run my big batterys but with the kit top plate its way to tight. have seen photos of the resulting magic show from connectors vrs top plate,doesnt look good
Old 04-23-2011, 02:55 PM   #4990
Anyone ever seen a decal sheet to match some older lesser teams? The way I'll compete in this category (like a slow backmarker) I'd like to find either Minardi, Arrows or Jordan Honda decal sheets.
Crazy request or is it something seen before?
I wonder what rocket scientists say to their co-workers when one of them doesn't get it?
cowboySiR is offline   Reply With Quote
Old 04-23-2011, 04:15 PM   #4991
Pro10noob's Avatar
How about these then??
regards Roy
http://d-drivesportsenglish.com/inde...products_id=61
http://d-drivesportsenglish.com/inde...roducts_id=599
http://d-drivesportsenglish.com/inde...roducts_id=623
http://d-drivesportsenglish.com/inde...roducts_id=220
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-23-2011, 05:30 PM   #4992
BP SHADOW's Avatar
I have a selection of these sheets available for sale, PM me for details
http://f1rclab.com
Old 04-24-2011, 02:16 AM   #4993
does anyone have a pic of the new 2 piece topdeck installed??
Old 04-24-2011, 05:52 AM   #4994
Mr P!nk's Avatar
I modified the front piece so keep that in mind. But here are some pics.
Have you ever wondered how much deeper the oceans would be without sponges?!
Mr P!nk is offline   Reply With Quote
Old 04-24-2011, 06:09 PM   #4995
MikeR's Avatar
Trader Rating: 14 (100%+)
NEW! Bolt in secure servo mounting now available. No servo tape or glue! More details here;
http://www41.instantestore.net/merch...rvo-mounts.cfm
F103 version coming soon.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
