Like Tree4Likes
Old 04-17-2011, 01:01 AM   #4936
Originally Posted by TWILL View Post
I have Venom 7.4 6400 2c, what isnt fitting in is the piece that keeps the battery from moving forward. I have cut it and think that it will be fine.
I run Speed Power 5800 lipos in my EXO104 and the way I did mine was to shim the top plate up by 1mm thus allowing the lipo to slide under the front brace snugly.
Bumpy is offline   Reply With Quote
Old 04-17-2011, 07:33 PM   #4937
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by MikeXray View Post
Can you fit F104 kit rubber tire/rims on a F103?
hey mike - in case I mis-read what you tped earlier, you can use the F104 tires on the F103...backs will fit fine, fronts will need different bearings...
in the event you meant F104 rubber on F103 rims, then see my other post
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-17-2011, 08:18 PM   #4938
MikeXray's Avatar
Trader Rating: 73 (100%+)
thanks, yes I did mean the entire rim/tire combo, but its good to know both situations anyway.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-18-2011, 12:35 PM   #4939
The Big Wig's Avatar
Here's mine:
FF in the back
Underside of body bent inwards
Carbon Fibre Look (painted of course)
Carbon Fibre Look
HPI helmet, black belt bucle and straps
Carbon steering wheel
Opened up airbox
Gurney flap and some James Hunt humor here. Official F1 should all be 180mm! A 200mm class should fall under a classic cars only rule.
Opened up exhaust and motor temp sticker
Real (plexi)glas mirrors
I hate the original blue color and the black edition wasn't out yet so it's anodized black (that's why you don't see the camber #s)
LW body lightened on the glued overlapping
Front underside left clear. lightweight aluminium and magnesium screws here
Heat sink with very small fins for bigger cooling surface and low CG
Alu M2 screws
What you don't see are the ceramic bearings inside the servo
MRT PTX transponder
2 Bad the + batterywire isn't black and I forgot to use a black spring
Did I mention I hate blue
Inboard antenna
Low profile wheel nut, 850 bearing adapter and abec7 ceramics
Shaved down motor wires
Beveled chassis
Shaved down screws
Sanded and polished chassis
The Big Wig is offline   Reply With Quote
Old 04-18-2011, 10:03 PM   #4940
Very impressive!
On a side note im thinking of getting the mclaren MP4/5 F104W. Anyone got pics of this?
kb525 is offline   Reply With Quote
Old 04-19-2011, 12:54 AM   #4941
Originally Posted by kb525 View Post
Very impressive!
That's a very nice car (Big Senna fan). It is however a wide car. This handels better (duh) but is not really a car your can compete fairly with modern looking F1's. Going parking lot, just for fun or want to run a classic F1. Go for it. Want to do real competition go for the McLaren MP4-24.
Old 04-19-2011, 04:12 AM   #4942
kmichael's Avatar
Very nice,a true F1 fan glad it's not red
kmichael is offline   Reply With Quote
Old 04-19-2011, 04:38 AM   #4943
Tru that. The first Ferrari was yellow
Old 04-19-2011, 07:25 AM   #4944
Yea itll be a just for fun car. Im getting tired of taking my nitro apart every time I want to go from drift to grip and the extra things to watch out for on a nitro.
Im thinking of runing it 3 cell lipo for fun, I have a ESC thats older than I am lying around for a dragster my dad had runing 12cell nimh back in the day.
Old 04-19-2011, 08:10 AM   #4945
With real cars 2/3 of the downforce comes from the underside of the chassis. Small model cars it is 100% from above. Model F1 cars have the smallest wings and least downforce of them all. Altough a 90s F1 has bigger wings then modern F1s it is still far to little to go for speed records. 3 cells will be overkill. RC F1 is all about agility and driving on the tip of your toes while having great looking cars.
Old 04-19-2011, 08:29 AM   #4946
orci77's Avatar
@The Big Wig:
Very nice car. AND also a very nice photo series!
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 04-19-2011, 08:30 AM   #4947
Like i said its a lot basher. The esc has control over how much full throtle range is so I can dial it down. Im mostly thinking that route since I have a bunch of these small 3 cell lipos from airplanes that almost never fly due to wind.
Old 04-19-2011, 12:40 PM   #4948
Default wow indeed
Love the photo series, a lot of detail in a relatively small car for sure!!
Most of us racers, well speaking for myself, dont spend a lot of time or energy into that much detail just to keep the amount of wincing on the driver stand to a minimum. I must say though after a full race day and a bunch of practicing the body on my f104frp is holding up very well and I got it used in a trade from here.
JoeD. is offline   Reply With Quote
Old 04-19-2011, 03:21 PM   #4949
k_bojar's Avatar
here's a (possibly) dumb question....
has any been able to notice a camber different when running the aluminum piece that tamiya makes?? i'm asking because the screw goes straight up no matter that setting you choose - and after seeing the part 3racing makes, it kinda made me go 'hmmmm'
Old 04-19-2011, 03:33 PM   #4950
robk's Avatar
Trader Rating: 22 (100%+)
What do you mean? That the camber is different to the same setting with the plastic piece, or that you are not getting different cambers at different settings? I have the aluminum part and it does add and remove camber.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
