Like Tree1Likes
Old 03-21-2011, 01:05 AM   #4771
2-Bad's Avatar
Trader Rating: 24 (100%+)
Ooops, my Bad... I didn't read it properly (re: carpet)
@Art_Mighty = The "High Traction" is softer then Kit... I have been told, the Kit is the stiffest, then the Soft, then the softest is the "High Traction"
I've only tried the Kit & High traction plates myself....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-21-2011, 07:51 PM   #4772
@Art_Mighty's Avatar
Awesome! Thanks for clearing that up!
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 03-22-2011, 07:26 PM   #4773
Default still spinning out
Still having issues with the back end being quite loose and I'm quite sure its the tamiya rubber tires are the issue. The rears are about as hard as the fronts. Even though they are sticky as hell the back end comes around pretty easy. Its like one of you said, I can get about 3 or 4 laps in before the tires pick up track crap and then they glaze over and its sh!t. Have to find some foams, my buddy had foams on his last friday and he drove his car up the rear of my 12 scale!! Other tuning settings are for not until I get some decent tires.
JoeD. is offline   Reply With Quote
Old 03-23-2011, 12:23 AM   #4774
Pro10noob's Avatar
If you want to drive on rubber and you have to use Tamiya then type A slicks for the rear and type B slicks at the front.
If you want to try foams the HBR soft for the rear and HBR medium at the front is a good starting point.
And yes the HBR tires are stil out there on e-bay.
Or if you can get your hands on foams with a shore indication,start with 40 shore at the front and 36 or 30 for the rear.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-23-2011, 05:45 AM   #4775
Default tire info
Thanks Roy, thats all good info I took note of and will use in my tire search.
Old 03-23-2011, 07:54 AM   #4776
Pro10noob's Avatar
Your welcome
regards Roy
l===/o\===l
Old 03-23-2011, 08:59 AM   #4777
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Gotta get the Pit Shimzu tires front and rear if you choose rubber. tqrcracing.com has em
Do all the traction adding tips for the rear end, T bar, spring, shock oil and damper plate all super lite/free.
Stiff springs up front and raise the front ride height, lower the rear.
Make it push then start to dial in more steering by lowering the front height little at a time.
Only sauce the rears at first.
regards Roy
Sounds like you are describing F103 tire compounds but he's dealing with a 104, no?
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 03-23-2011, 09:08 AM   #4778
Pro10noob's Avatar
If so me bad
Another question from my side then??
Won't the F103 tires fit(just the tires) the F104?
Or are the tires different sizes?
If they do then you could use them?
regards Roy
l===/o\===l
Old 03-23-2011, 09:26 AM   #4779
F N CUDA's Avatar
If so me bad
regards Roy
Yeh they fit but they will make the rear end wider cuz of the width of the rear tires and to balance the stance you need the wide 103 front end otherwise with the narrow front end, tires being the same width, this thing will steer even more and make everything worse.
Then again, maybe just adding fatty 103 rears will get the rear stuck?
With the 103 front end and tires, it will be converted to the new F104W configuration which is not a bad thing either but the F103 is still, arguably (or not), better.
Craig Hammon
Old 03-23-2011, 09:34 AM   #4780
Pro10noob's Avatar
And by saying this, i am glad i still drive a F103
regards Roy
l===/o\===l
Old 03-23-2011, 09:44 AM   #4781
F N CUDA's Avatar
regards Roy
Having both is cool but the 103 is surely the race car.
Our Ultimate F1 series is off and running again and we have classes for Open which is anything goes and Realistic which is current F104 specs with 21.5 motor and rubber tires.
For the Open class it is without a doubt the 103 on foam with 13.5 (or even faster ) motors settin the pace for as long as you can keep a handle on em. Braaaaaaaap
Craig Hammon
Old 03-23-2011, 10:12 AM   #4782
2-Bad's Avatar
me bad
strange, I thought I was....
Old 03-23-2011, 01:24 PM   #4783
transplantlife's Avatar
Trader Rating: 43 (98%+)
hey guys im looking at a BLACK EDITION is there anything different from the
F104 pro standard edition.
Thanks!
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 03-23-2011, 01:27 PM   #4784
robk's Avatar
Trader Rating: 22 (100%+)
Black addition had more aluminum I believe- motor mount pivot post, etc.
Old 03-23-2011, 01:28 PM   #4785
2-Bad's Avatar
Once u try Black, u never go back, hehehehe
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
