Like Tree5Likes
Old 03-13-2011, 04:18 AM   #4726
Originally Posted by aussierevo View Post
I hope these pictures help.
That pictures are of the car as comes from the box, or did you added the damper and post mount?
prorace is offline   Reply With Quote
Old 03-13-2011, 04:32 AM   #4727
aussierevo's Avatar
Trader Rating: 14 (100%+)
the damper is from a ta05, but everything else is standard F103
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 03-13-2011, 05:04 AM   #4728
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I know this has been posted before, but what's the part number to that new upper deck for the F104?? the split upper deck??
I'm looked thru the last dozen or so pages, and can't find any mention of it - if I remember who posted it originally, I could have done a search
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-13-2011, 05:47 AM   #4729
3rd-dan's Avatar
Do you mean this?
54278 F104 Separate Upper Deck Set
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 03-13-2011, 05:49 AM   #4730
Arahawak's Avatar
Trader Rating: 32 (100%+)
has anyone got any feedback or done some testing on running the F60 Chassis over the F104pro. I understand that the pro graphite chassis was stiff and that people went about adjusting the top deck with cutout's etc, but what if any difference for the good would be running both the upper and rear deck from the F60.
more flex?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 03-13-2011, 05:58 AM   #4731
k_bojar's Avatar
Originally Posted by 3rd-dan View Post
Do you mean this?
that would be it - obiviously, I didn't have the right name as well
Old 03-13-2011, 09:34 PM   #4732
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Scooby Horton1 View Post
Can I see more pics?
Old 03-13-2011, 09:58 PM   #4733
Trader Rating: 69 (100%+)
Questions??
Other than the more flex, it allows the use of direct shock absorber without the friction plate.
I am new to F1 and I use direct shock absorber to reduce tuning variables. I am not sure what the friction plates do since there is already a T-bar, I can only think that the friction plate is to damp the movement of T-bar, but for front-rear, isn't the shock handling the task already?
eComet is offline   Reply With Quote
Old 03-14-2011, 06:07 AM   #4734
Trader Rating: 48 (93%+)
Any one have a a set of tamiya hard fronts for a 104 they want to part with? i got nip ride rear wheels or a tamiya alum servo saver. both new.
the med tires seam to bite to much for my driving. i got alot of f104 parts so let me know if u need any thing.
tcb22185 is offline   Reply With Quote
Old 03-14-2011, 08:03 AM   #4735
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Can someone tell me the rate of the 104 pro white spring?
It says med. in the parts diagram but when you
look up Tamiya springs all the white springs are listed as extra stiff?
Need a stiffer spring but not sure what to use..
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-14-2011, 08:29 AM   #4736
convert to tc3 springs the silver is 12# ae seems to be the only one that rates there springs.
Old 03-14-2011, 09:05 AM   #4737
k_bojar's Avatar
Hey JD - what's the color dot on the spring?? The all white springs have the colored dots that designate what firmess they are - the all white springs (or white with white dot, if you will) are the firmer of the group...
white with red dot - softest
white with yellow dot - medium
white with blue dot - firm
white with with dot - firmer
hope that helps
Old 03-14-2011, 09:32 AM   #4738
2-Bad's Avatar
Trader Rating: 24 (100%+)
If it's the Touring Car Short spring then it's;
17.25lb/in or 308.1gf/mm
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-14-2011, 10:12 AM   #4739
j.d.roost's Avatar
hope that helps
It's whatever comes with the pro kit.
Ill look for rate dot's.
Thanks guys.
F1
Roche usa
R.I.P. Jon Williams
Old 03-14-2011, 10:19 AM   #4740
k_bojar's Avatar
Thanks guys.
then you probably have the all-white ones, so you'll need to look for the dots I believe that's what my pro came with
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
