Like Tree5Likes
Old 02-21-2011, 02:08 PM   #4621
gsxr0311's Avatar
Trader Rating: 19 (100%+)
Originally Posted by robk View Post
Sandwich the lexan between the motor plates and the lower pod plate. All set.
you can also cut the tamiya one, drill and screw it on to the plate. thats what i did.
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 02-21-2011, 03:20 PM   #4622
kneedeeppow's Avatar
Originally Posted by Taman View Post
54278 F104 Separate - Type Upper Deck Set
Usable with :
F104, F104W Chassis
This carbon fiber upper deck is split into front and rear sections, thereby allowing the chassis to become more flexible.
$24USD from Stellamodels
many thanks
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 02-21-2011, 08:22 PM   #4623
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by gsxr0311 View Post
i agree, foam and rubber cars dont work well together because foam will always win. wes there enough people in each class?
There were twice as many 104s than 103s, but this was more an issue of 104 vs 103, not an issue of foam vs rubber.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 02-22-2011, 04:28 AM   #4624
Trader Rating: 48 (93%+)
I love my 104. why is every one going back to the 103? i have had both and i like the 104's front end. u cant even adj camber on the stock 103 front end.
tcb22185 is offline   Reply With Quote
Old 02-22-2011, 08:06 AM   #4625
gsxr0311's Avatar
i agree, i like my 104 better also. it looks better, the front end is more adjustable, and it looks way cooler, but i think everybody is going back to the 103 because on some tracks it is faster when it comes to actual lap times. it seems easier to get a fast lap with the car. you can go fast with the 104, but its a lot more work. the 103 works right out of the box.
Old 02-22-2011, 12:10 PM   #4626
i like the challange to get the f104. all that is here is hpi im the only tamiya and it shows on lap times. 2laps faster last race i dialed down the car so i would not walk away.
Old 02-22-2011, 01:51 PM   #4627
tunerjetta29's Avatar
It really is sad that HPI has become a company that tosses out a car, comes out with a few hop ups and then completely stops developing or improving it.
A lot of people went back to F103's because they are easier to drive. You have that shorter wheelbase and wider track (20mm is a lot) that really makes the car stable. Though the F104 with a shimmed rear end and F103 front is really good too. You basically just have a long wheelbase F103 at that point. For scale appearance the F104 is great, its just not the fastest
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 02-22-2011, 09:13 PM   #4628
Arahawak's Avatar
Trader Rating: 32 (100%+)
How do you shimmed the rear of the 104 to make it wider?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 02-22-2011, 09:28 PM   #4629
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Lotus 79 anyone?[IMG][/IMG][IMG][/IMG]
[IMG][/IMG]
First $400 gets it shipped to their door looking just like this chassis and all with full bearings an all stainless steel hardware.
Going to build another when this one leaves
PM me for anything you might need
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 02-23-2011, 07:54 AM   #4630
Abu Salahuddin's Avatar
Anyone can advise how I can make the Shimizu rubber to work. Both F&R sets are medium running on low traction asphalt. Track temp 40-45 deg c. The car just spins out at corner entrance. With status quo on setup it runs perfect on stock medium Tamiya rubber tires. Shock & damper on soft setup. Ride height 4.5mm.
Yellow Mellow...
Abu Salahuddin is offline   Reply With Quote
Old 02-23-2011, 08:07 AM   #4631
John.C's Avatar
Trader Rating: 36 (100%+)
Abu - Lightfoot posted a great F104 rubber tire chart on page 231 [chart link here]. You may also be in need of some chassis and radio adjustments. Great information posted by F N Cuda and APEX can be viewed on page 239.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 02-23-2011, 09:56 AM   #4632
i know ride tires wont work on low grip asplate i tried the s1 they just spin out like crazy..
Old 02-23-2011, 10:36 AM   #4633
You can buy axle shims that are commonly used for any Pan car and put the shims between the spacer and bearing on one side and between the axle and bearing on the spur/pinion side. You may need to widen the flats on the axle to ensure the set screws hold well when everything is shimmed. I added about 4mm rear track width. My brother added about 6mm (using a different spacer instead of shims) and found it worked well to make the car more stable.
See his setup here:
Originally Posted by smracer31 View Post
Heres the base setup I ran for the last couple of races and some pics.
Exotek F104 Chassis (Rubber Tires on High Traction Carpet)
Front:
4mm ride height
Ride Type A tires (F103)
Savox low profile servo
F103 Carbon Reinforced front suspension
14 grams over the front wing
3k dampening oil on spring
Medium stiffness springs
Captured and cut down front springs (car dips less on corner entry)
Steering end links as level as possible (no bump steer)
rear servo mount screws dont go through the chassis (more front end flex)
Center
Tekin RS
Protek 5000mah
Shock- 3 hole, 40 wt oil, white f104 kit spring
crc light blue side spring
55 wt side damper oil
Ride height 4mm
Rear:
ride height 4mm
LRP x-12
Pinion 31
Spur 88
6mm rear axle spacing
Diff almost locked solid
Shimizu soft tires (F104)
Ugly clear wing
Currently Running:
Ko Propo EX-1 V3
Old 02-23-2011, 10:53 AM   #4634
Might have to try to shim it.. i dont want to add the 103 front end tho...
Old 02-23-2011, 11:24 AM   #4635
F N CUDA's Avatar
Trader Rating: 31 (100%+)
The F104 wants to spin out like crazy anyway, it's not a dialed racecar.
You need to play with ride height, T bar, shock setup, toe out etc. to make this car push when throttle is applied.
It will naturally push like a bulldozer entering corners and then go ass first as soon as you gas it to exit a corner.
Get the rear end low and the front end hi, motorboat style.
Get the softest rear tires and go from there.
Use brake to get it to turn in and expo to let it "ease" onto the power.
Craig Hammon
F N CUDA is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
