Like Tree4Likes
Old 02-16-2011, 08:53 AM   #4591
John.C's Avatar
Trader Rating: 36 (100%+)
Hi guys - I'm getting ready to buy the F104 Pro. I wanted to know what the main differences are between the Pro and the Black edition. With the obvious difference out of the way (black anodized alum parts) what else is different?
Tamiya USA's site had the following items listed under Options for the Black Edition. Doesn't the regular Pro (Blue) version come with some of these option parts?
Carbon Upper & Lower Decks
Hi-Torque Servo Saver
04 Module Spur Gear
4mm Aluminum Lock Nuts (Black)
1280 Sealed Ball Bearing
1150 Sealed Ball Bearing
1060 Sealed Ball Bearing
F104 Aluminum Diff. Housing Set (Black)
F104 Aluminum Motor Mount (Black) - I think this isn't included in the PRO
F104 Carbon Rear Shaft
0.4 Steel Pinion Gear Set
5x5mm Hard Hex Head Ball Connector
Carbon Reinforced Front Upright
Carbon Friction Plate
4mm Anodized Alu. Flange Lock Nut (Black)
TRF Damper (Black)
F104 Aluminum Pivot Post (Black) - I think this isn't included in the PRO
I actually perfer the regular Pro (Blue) version, so I'm interested in what is not included so I can upgrade the PRO (BLUE) version to be comparable to the Black edition.
Thanks.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 02-18-2011, 01:42 PM   #4592
Does anybody know what difference it could give between the new seperate upper deck and the standard upper deck of the F104 PRO?
addicted2blue is offline   Reply With Quote
Old 02-18-2011, 04:26 PM   #4593
Abu Salahuddin's Avatar
The new upper deck will help the chassis to have a little bit of flex. This will aid in you having an improve traction. More suitable for low grip asphalt on rubber.
Yellow Mellow...
Abu Salahuddin is offline   Reply With Quote
Old 02-18-2011, 10:47 PM   #4594
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
edit
Dan is offline   Reply With Quote
Old 02-19-2011, 04:13 AM   #4595
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
04 Module Spur Gear
TRF Damper (Black)
Thanks.
the biggest thing i know of is that the black edition includes the aluminum parts - pivot post and the motor housing...both of those are options that had to be bought separately with the other Pro Kit...but other then that, they look the same - well othen then the stuff being in black, like the damper and diff bits, nuts
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-19-2011, 08:08 AM   #4596
Thx for the info
I guess it's not recommended for high traction carpet tracks.
Old 02-19-2011, 09:52 AM   #4597
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Originally Posted by BP SHADOW View Post
I do, but it needs to be ground shipped
BP SHADOW: do you have the mclaren body and paint in stock?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 02-19-2011, 11:07 AM   #4598
Question for yall F104 bashers. How do these run with 3 cells? I have a metric ****-ton of 3 cell and 1 4 cell lipos for airplanes, they may be able to fit. Im not serious racer and just want an F1 car to drive.
kb525 is offline   Reply With Quote
Old 02-19-2011, 12:10 PM   #4599
John.C's Avatar
Thanks K_bojar. That's what I thought/was hoping for. I went ahead and purchased the PRO and some (ok all) blue bling to go with it. I also picked up a High traction T-bar, option hard (front) and soft (rear) tires, and low friction ball set. I'll probably pickup a soft T-bar and kit front tires as well.
I'm in the process of building it now and will be testing and tuning for the TCS event #161 in Frederick, MD (high bite indoor asphalt track). I appears that these are a handful in the straight. I guess at the end of the day it'll come down to the right inserts in the rear to get the desired handling. If anyone is willing to share their winning insert combo I'm listening.
Old 02-19-2011, 04:06 PM   #4600
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Yes I do, I can ship them to you for $50
PM me if you want them
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 02-19-2011, 04:12 PM   #4601
BP SHADOW's Avatar
By the way for all the F1 guys out there I have a shipment of parts on the way, stock parts, Hop ups 103 and 104
Will post a list in the next couple of days
http://f1rclab.com
Old 02-20-2011, 12:46 AM   #4602
Originally Posted by addicted2blue View Post
Thx for the info
Yep if you already have traction you do not need the option top deck.
Yellow Mellow...
Old 02-20-2011, 02:47 AM   #4603
Arahawak's Avatar
Trader Rating: 32 (100%+)
Thx for the info
Why not?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 02-20-2011, 02:51 AM   #4604
Arahawak's Avatar
I think tamiya f1 tires only have 1 type of insert.. if you are running TCS.
Depends on the track you are running, its pretty much between the option soft rear and option hard front and the stock tires. Not much choice.
Maybe the TCS F1 gurus can share more info.. here in Asia the TAC as we called it, the track is pretty low-medium traction. We mainly run tamiya soft rear and medium (stock) front.
Old 02-20-2011, 08:10 AM   #4605
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default F104W Mystery
I don't understand what is up with the release of tree more F104W kits:
- Ferrari 643
http://www.tamiya.com/japan/products...i643/index.htm
- Mclaren
http://www.tamiya.com/japan/products...aren/index.htm
- Mclarean
http://www.tamiya.com/japan/products...n_mp/index.htm
In Japan, Tamiya has a separate TCS class for the W's but is there option tires and TCS parts? I Have not seen them? Were is this leading up too?
Sell the F104?
Bring the F103 out of the box and mix it up with the F104?
Get a F104W and mix up using F103 tires?
I ran the race before last at TQ (F1 winter series) close to 15 or more cars. Only two F104Pro (me and Mark), the rest went back to the F103.
Anyone has info on this mystery?
Cheers, Marcos
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
