Like Tree1Likes
Old 02-07-2011, 06:56 AM   #4501
InZane's Avatar
Originally Posted by 3rd-dan View Post
How did you fit the Lipo?
I cant see a tape.
If i would take a tape the T-bar cant work right.
O-ring
InZane is offline   Reply With Quote
Old 02-07-2011, 08:10 AM   #4502
3rd-dan's Avatar
Ok thanks.
I think i will try that.
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 02-07-2011, 12:14 PM   #4503
robk's Avatar
Trader Rating: 22 (100%+)
Delta and Trinity used that front end setup for years. You could probably make that yourself pretty easily. As Jamie pointed out, some guys don't like the way you have to readjust everything when you make changes.
Old 02-07-2011, 12:25 PM   #4504
superspeed's Avatar
Are you referring to the reactive caster system? If yes, the setup is fairly simple but it looks different than the picture shown in previous post.
superspeed is offline   Reply With Quote
Old 02-07-2011, 12:58 PM   #4505
robk's Avatar
More like this
Old 02-07-2011, 04:32 PM   #4506
Trader Rating: 77 (100%+)
Smile quick question
anyone have any input on the f104w? any better thene the standard 104? running silver can tamiya tcs rules, foam...ive been running at the underground with my 104pro and my exotechf103..but i know with tcs its all tamiya.. input please...thanks
artoftatt2 is offline   Reply With Quote
Old 02-07-2011, 04:37 PM   #4507
Originally Posted by robk View Post
More like this
That's the old Delta front end. The current Yokomo 1/12th and the BMI Copperhead 12 are using new reinventions of that old front end.
Old 02-07-2011, 06:00 PM   #4508
Default Tamiya rubber tires - to glue or not to glue
Hi, I understand that we can use different inserts to adjust tire traction so we should not glue the rubber tires to the rim but my rear rubber tires keep coming off the rims when I play. Anybody has any suggestions or should I just glue the tires to the rim ? How can change the inserts then ?
3v1rrr is offline   Reply With Quote
Old 02-07-2011, 06:33 PM   #4509
stitchy's Avatar
Originally Posted by gsxr0311 View Post
do you have the tamiya recommended paint for the mclaren body?
If you're referring to the PS-48 which is the chrome silver, then yes we do! But yes, we do have to ship it ground.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-07-2011, 06:38 PM   #4510
Foxxrocket's Avatar
You're more worried about tire inserts then keeping the tires on the rims? It's best just to glue the tires. If you don't like the inserts, rip out the tires and clean up the rims. Then start all over again.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-07-2011, 06:39 PM   #4511
aussierevo's Avatar
Trader Rating: 14 (100%+)
will need to glue your rubber tires or you will spend more time off the track then on it.
you best bet is to speak to people at your track, see what works, then build up a supply. You can go to the hassle of unglueing the tires if you must, but you will be better placed to buy new one's as required.
never nice to have to keep buying tires, but the old ones are good for practice and mucking around.
have a read of the rubber tyre reviews done for the F104, they give you a good starting point, as well as robk blog....both are really handy source of tire info.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 02-07-2011, 07:16 PM   #4512
gsxr0311's Avatar
Trader Rating: 18 (100%+)
ok, thanks.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 02-07-2011, 07:22 PM   #4513
Trader Rating: 46 (94%+)
Take it from me read the info and ask locals what works. i had a guy sell me a set of tires to only find out he glued the rear tires on the front wheel. 16bucks and about 24 hours later i had them off wheels. woulda been cheaper to order new.
tcb22185 is offline   Reply With Quote
Old 02-07-2011, 11:02 PM   #4514
Default Foam Tires & Motor Choice For Tamiya F104W
Hi Guys
I have a Tamiya F104W (Wolf WR1).
I have a bit of a dilemma with foam tire choices. Previously I purchased some F103 foam tires. The rear foam tires have worn out very quickly. The track I run on has a rough grit.
I believe the F104 Pro wheels will fit my model as they both use a 14mm HEX.
I have been searching through RCMART for new foam tires. It appears that the only brand that has both front and rears available is Tamiya. Can someone advise if the Tamiya foam tires are a good choice?
I donít mind going for another brand if anyone has a better suggestion.
Also is the Hobbywing XERUN 17.5T (Sensored) motor a good choice for F1?
Regards
Nick
nbusetti is offline   Reply With Quote
Old 02-08-2011, 02:32 AM   #4515
aussierevo's Avatar
tamiya have ''coming soon'' some further models.....Ferrari 643 and McLaren MP4/6 along with the Mp4/5B they annouced a while ago........yippee!!!!!!
http://www.tamiyausa.com/product/cat...p?sub-id=36100
it would be great if the Williams FW14b made an appearance....hint hint
can't wait for hopefully the body kit's
Speed Passion F1.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
