Like Tree1Likes
Old 07-17-2009, 08:14 AM   #436
dsyed1's Avatar
attached are pics directly from above... the battery fits perfectly center and i had to modify the battery holder a bit as well..
Alfie good catch i fitted those ball ends now
dsyed1 is offline   Reply With Quote
Old 07-17-2009, 09:12 AM   #437
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Ben.C View Post
I can't find anything more versatile than this....
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-17-2009, 09:25 AM   #438
JayL's Avatar
I wish that nut was set into the chassis
JayL is offline   Reply With Quote
Old 07-19-2009, 06:44 AM   #439
i ran my F104 yesterday, using tamiya sport tuned motor, front tyre seemed wear out very fast.
but the handling was good out of the box.
wondering how is the handling using hard type foam (hop up option, forgot the part number). have you guys tried it?
or maybe rubber tyre??
krat is offline   Reply With Quote
Old 07-19-2009, 07:20 AM   #440
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
what surface were you running on? concrete or asphalt? sounds as if you might have a bit of understeer...
i ran my F-104 at our local track which is an indoor asphalt track and the wear on my front tires was minimal... i only added a bit of toe in to the car plus a little bit of traction compound to hook the car up to the track...
by the way, my motor is the Tamiya lightly-tuned 25T motor. and i was using a Tamiya 1600 racing pack on its first run and an Orion 3800 Lipo on my next run...
just my 2 cents...
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 07-19-2009, 08:06 AM   #441
oh i forgot to mention that, it was on med-high grip asphalt surface, tropical country, grip was great.
i used the box setup, as i said preivously the handling was great.
it is just the wear on the front tyres.
after 4-5 lipo packs, the front tyre diameter was 5.6 mm, rear was 6.2 mm.
maybe the motor, lightly tuned is slightly slower than sport tuned motor if i'm not mistaken.
Old 07-19-2009, 08:59 AM   #442
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default Lipo packs
Does someone know if the Lipo packs from LRP fits the car?I am talking about the 5300 28C from them.
I saw that the Trakpower fitted with some little mod a few posts ago just wondering if someone have tried.
Also I am planning to go for the F104 in the next month, we are going to have the Formula category back in our club using cam motors, just wondering with this type of motor which electronics to use, I have LRP on my TC but I think to run with cam motors the really don't need something so expensive, so just wondering if you guys could give some advice also for the servo, I have a digital one on my pan car but it is the small size does it fit?
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 07-19-2009, 10:06 AM   #443
alan1467's Avatar
Ran mine today with the Tamiya brushless 12T and lipo boy is it fast!!!! to fast for our track.
Killed the front tyres in 8 runs they are very soft. only took 2mm off the rears. Anyone know if the B tyres are harder?
The track is tarmac and i would say medium grip and T/C's get 3-4 weeks out of there tyres
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 07-19-2009, 08:32 PM   #444
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
From the pictures, I think you will need to be cautious about the insulation tape that you applied onto the upper deck.
I'll see if I can squeeze the wires like yours to fit to my F104. Seems pretty tight for the plug to go under the upper deck.
Alfie
F103KŠ • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 07-19-2009, 10:18 PM   #445
Trader Rating: 26 (100%+)
Default Orion 3800
I was able to get an Orion 3800 to fit. I also changed the nut on the bottom of the Chassis to a flat one. I dremelled a notch on both sides if the top plate to accommodate bullet plugs. I am trying to get an IP5000 to fit, but I am finding that the nut on the underside of the top plate that holds the antenna mount is in the way. Any suggestions on another location to mount the antenna holder? I will post pics tomorrow.
svines1972 is offline   Reply With Quote
Old 07-19-2009, 11:24 PM   #446
try to countersunk the screw hole and use countersunk screw instead of button head to mount the antenna holder.
Old 07-20-2009, 01:03 AM   #447
Patriiick's Avatar
If you have a lot of wear in front, you might be overworking the tires
Did you consider traction compound on the front or softer compounds ?(although at this point, not much choice on f104 wheels)
Patriiick is offline   Reply With Quote
Old 07-20-2009, 01:25 AM   #448
Arahawak's Avatar
I thought that traction compound would worsen the tire wear, since it is suppose to give more grip?
or it is suppose to give more grip and have better tire wear?
now i am confused..
Old 07-20-2009, 01:29 AM   #449
Alfie's Avatar
It supposed to soften the foam so that the tires would work better for that first few minutes.
The setup is a combination of the friction plate, damper, to find the balanced setup for front and rear.
Alfie
now i am confused..
Old 07-20-2009, 02:38 AM   #450
bakaguyjean's Avatar
Tire choices?
http://d-drivesportsenglish.com/inde...ort=20a&page=1
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
