Old 01-27-2011, 05:59 PM   #4351
Barry White's Avatar
A new bendy part and a heavyweight:
Barry White is offline   Reply With Quote
Old 01-28-2011, 12:08 AM   #4352
Oortael's Avatar
Originally Posted by olafboot View Post
Hi,
I had "slimmed down" my f104pro.
First I was driving the F104 with a 4000 Lipo (370 gr weight). Now I drive a 2s1p A123 2300mAh LiFePo with only 140 grams
The F104 is now running much better with curves. The weight advantage is fantastic.
I invite the FePO's with 10A / 4C. The cells are then fully in 7 minutes! The cells are intrinsically safe. So I invite them in the car.
Since driving stress is on ....
Have fun
Olaf
Hi,
von welcher Firma sind deine Akkus?
Grüße
Oortael
Oortael is offline   Reply With Quote
Old 01-28-2011, 03:15 AM   #4353
3rd-dan's Avatar
Please write in english.
so everybody can read your post.
otherwise send him a pm.
Gruß
Mike
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 01-28-2011, 03:40 AM   #4354
Default A123 LiFePo
Hi,
I buy my FePO'S here: ..w.modellbau-franke.de/A123-LiFePo
Olli only sells original A123 cells. The packs are made up of high-current capability. In Germany there was even "worse"cells with green Mattel. Look in the forums of the German race boat driver ...
Load diagrams can be found here: ..w.elektromodellflug.de/akku-test/26650
Have a nice greeting from the Rhineland to Munich
Olaf
olafboot is offline   Reply With Quote
Old 01-28-2011, 05:59 AM   #4355
Trader Rating: 45 (94%+)
ok guys here is one for u. I was out practicing with my new 104 i upgraded the center shock to trf yellow spring. my local track is farly bumpy. when i hit some of the bumps the whole car comes off the ground. is my center spring to hard? i played with the screw with the oring lossin it some and it made it bettter. any help is great.
tcb22185 is offline   Reply With Quote
Old 01-28-2011, 06:01 AM   #4356
abailey21's Avatar
Trader Rating: 36 (100%+)
your track is to bumpy
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-28-2011, 10:22 AM   #4357
MikeR's Avatar
Trader Rating: 14 (100%+)
Springs too hard yes, maybe the t-plate also. Probably need to raise the ride height as well.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-28-2011, 10:22 AM   #4358
MikeR's Avatar
Originally Posted by abailey21 View Post
Sizes on the 3 Racing bearing spacers are: 0, .5, 1.0, 1.5, 2.0
Thanks- was afraid of that.
Old 01-28-2011, 11:37 AM   #4359
i got the soft tplate but not the high traction tplate. im also running the stock gold springs up front. but have a 103 with black springs. should i swap them. how much ride hight should i be running..
Old 01-28-2011, 11:48 AM   #4360
robk's Avatar
Trader Rating: 22 (100%+)
4-5mm, is the car scraping all over?
If you don't run TCS, remove the tension adjusting screw from the T bar completely. You can then use a foam ring, such as from a TC5 shock rebuild or other similar neoprene foam, to keep the ride height and provide support. This works!!
http://www.youtube.com/watch?v=H_A7gDxQXno
Old 01-28-2011, 12:32 PM   #4361
Damn pics. Here we go again:
Old 01-28-2011, 12:39 PM   #4362
MikeR's Avatar
And if these don't work then it's like what AB said- track is just too bumpy
Old 01-28-2011, 12:43 PM   #4363
robk's Avatar
Separetoappadekkisetto OP.1278 F104
発売日:2月19日(土)ごろ Release Date: February 19 (Saturday) about
価格(税込み):3,150円 Price (including tax): 3,150 yen
ジャンル:RC Category: RC
ITEM No:54278 ITEM No: 54278
ヘビーウェイトピボットポストセット OP.1281 F104
価格(税込み):1,680円 Price (including tax): 1,680 yen
ITEM No:54281 ITEM No: 54281
Old 01-28-2011, 03:07 PM   #4364
gashuffer's Avatar
Trader Rating: 48 (100%+)
Do you run rubber tyre? Did you drill out air holes in the wheel. You might be bouncing because of those huge air filled tyre's. Just a thought.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-28-2011, 03:08 PM   #4365
6.5mm rear
5.5mm front thats what my current ride hight is.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
