Like Tree4Likes
Old 01-20-2011, 10:26 PM   #4291
Trader Rating: 48 (93%+)
Thanks guys. really dont care about the wheels. but keeping the rubber and foam would be good.
Next qustions. whats the best tire prep to use for low grip asphalt. i got soft rear tires and med fronts.. a good base setup would be nice. this is not the pro 104 but i did upgrade to a trf center shock 3hole piston with 35wt oil and a white spring. it does have soft t plate in it. the track i run at is farly bumpy in the center. running 21.5 brushless with a full size 5300mah lipo.
thanks again..
Tim
tcb22185 is offline   Reply With Quote
Old 01-20-2011, 11:26 PM   #4292
F N CUDA's Avatar
Trader Rating: 31 (100%+)
thanks again..
Tim
Are you set on running the 104 tires?
After experimenting with many (name it and I probably have it) tire additives on the Tamiya track, none seem to work as well as just cleaning them before each run with Simple Green.
I recently used tire warmers on the rear and liked that although by the time it was teched and on the track it was effort wasted but the practices were positive.
I would also go to much lighter oil, I use 20wt and a much softer spring, I use the gold one.
Let that rear pod and T bar/plate be as loose as possible with out being too sloppy. Minimum pressure on the discs, I prefer dry discs for the most rear traction.
Rear ride height lower than the front, motorboat style.
Push into the corners but be stuck coming out.
Now that our latest TCS race is done I'm gonna go with an F104W config.
That uses the F103 front end and wheels/tires.
I'll be thrashing rubber and foam setups for our UF1 series coming up.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-21-2011, 06:23 AM   #4293
2-Bad's Avatar
Trader Rating: 24 (100%+)
thanks again..
Tim
Tim,
I'm using FX-II with good success (baking in with warmers). Pop back 2 pages and review my setup on Post# 4269. If the track is that slippery, then like others said, put the softest spring you can find and lighter shock oil then 35wt. There is a "High Traction" T plate which will provide more rear grip then the Soft plate.
Hope this helps...
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-21-2011, 08:32 AM   #4294
F N CUDA's Avatar
Surprised to hear that you like the sauce on the Tamiya F1 tires.
Also, you getting away with running Medium/Kit tires front and rear?
I was dialed using Buggy Grip on B3 tires for the FF03 FWD class but had no luck with anything on the F1 option soft rears.
May be worth another try when the time comes again.
Track conditions and tire selection mean everything so just gotta test stuff out as usual.
Craig Hammon
Old 01-21-2011, 08:46 AM   #4295
2-Bad's Avatar
Tires & the correct diff tension is 85% of F1 car setup imo
I set 4 diff tensions for other ppl last race meeting cos there car had no rear grip and it was mainly because they set the tension was too tight... hence those ppl probably didn't need to run the soft option rubbers
Old 01-21-2011, 09:03 AM   #4296
F N CUDA's Avatar
True, spools only work on rear wheel drive cars in drag racing.
Slipping diffs also kill performance not to mention the diff parts tho.
Fine line there.
Craig Hammon
Old 01-21-2011, 09:40 AM   #4297
It all depends on the conditions and the driver...a very tight diff can help in some low traction conditions while a very loose diff can hurt. A tight diff will push off throttle so if you have someone who is good with the throttle finger and still needs a bit of grip tightening the diff can help. A loose diff can help with the heavy throttle finger but the car will have a tendency to diff out in the corners.
Old 01-22-2011, 06:38 AM   #4298
What happends if i rase up the front of the center shock. llike the 103
Old 01-22-2011, 07:31 AM   #4299
Guddam's Avatar
Basically it's the same effect as adjusting the shock angle on a TC...
Guddam is offline   Reply With Quote
Old 01-22-2011, 08:29 AM   #4300
F N CUDA's Avatar
guys im looking for a way to unmount a set of rubbers. that have been glued any idea?
Originally Posted by F N CUDA View Post
Not if they are mounted on Tamiya rims.
They melt whether you heat them in the oven or soak em in acetone.
Others can be done by either one of these methods but not Tamiya rims.
If you choose to sacrifice the rims just to reuse the tires, acetone will get rid of the glue AND the rim eventually.
I took a chance and did the acetone/paint can trick on a set of F103 rim/foam combo and those rims held up to the acetone.
This was one pair of black rims/tires and one pair of gold rims/tires.
So I guess I won't be buying new rims for the foam season.
Reminder tho, you will destroy the F104 rims for the rubber tires.
I don't know about the F104 rims for foams tho.
Craig Hammon
Old 01-22-2011, 12:58 PM   #4301
thanks guys got a set soaking is a can now. insteded of a paint can i used a can from baked beans.. uses a lot less asatone.
will the foams be junk too?
Old 01-23-2011, 07:09 AM   #4302
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Guys,I am looking for a tcs-rubber-carpet setup.
Paged through here but could not find much.
What is the best tire combo (tamiya) for high grip carpet?
j.d.roost is offline   Reply With Quote
Old 01-23-2011, 08:03 AM   #4303
Oortael's Avatar
I use the hard in the front and soft ones in the rear.
Oortael is offline   Reply With Quote
Old 01-23-2011, 08:12 AM   #4304
abailey21's Avatar
Trader Rating: 36 (100%+)
I run a real soft setup, 25wt oil and soft rubber f/r and soft springs in the front.
don't ask why it works for me but it does
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-23-2011, 09:54 AM   #4305
robk's Avatar
Trader Rating: 22 (100%+)
The biggest problem is the Tamiya rubber tires pick up all the carpet fuzz and crap, and then the tires loose traction. It seems like this gets better if you use tires that have been run on asphalt, but it never seems to go away 100%. Some tracks are worse than others as well.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
