Old 01-19-2011, 05:24 PM   #4276
GasGod's Avatar
thanks for the info--
I'll try it-I want to try to get it close to my 103's &109
40 or 45 in the shock kinda scared meI'm used to 20-25
even in my gen xl
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 01-19-2011, 05:39 PM   #4277
robk's Avatar
Trader Rating: 22 (100%+)
You have a Tamiya 3 hole piston, right? You'll need some heavy oil...No T bar or damper plates to help the ol' shock.
Old 01-19-2011, 06:12 PM   #4278
MikeR's Avatar
Trader Rating: 14 (100%+)
Very true. I run 55wt in both shocks with gold heavy side spring and Tamiya yellow center spring for high grip carpet. This slows down the chassis roll for much smoother transition on the high grip track. This is with Pit rubber tires. Foam could probably go even heavier side dampening oil on carpet.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-19-2011, 06:44 PM   #4279
robk's Avatar
There you have it
Old 01-20-2011, 12:29 AM   #4280
kneedeeppow's Avatar
Default 103-104 pressure disks
hey guys
are the 103-104 pressure disks compatible? mine have developed some slop so need to replace them.
http://cgi.ebay.com/Tamiya-F104-PRO-...ht_1387wt_1139
103 ones are easier to come by. what is the exact size of the diff balls?
cheers
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 01-20-2011, 12:08 PM   #4281
gashuffer's Avatar
Trader Rating: 48 (100%+)
Can someone recommend a good rubber tyre for high bite carpet? I have a set of the option Tamiya one's but I've read mixed reviews.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-20-2011, 02:33 PM   #4282
Trader Rating: 45 (94%+)
guys im looking for a way to unmount a set of rubbers. that have been glued any idea?
tcb22185 is offline   Reply With Quote
Old 01-20-2011, 02:41 PM   #4283
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Not if they are mounted on Tamiya rims.
They melt whether you heat them in the oven or soak em in acetone.
Others can be done by either one of these methods but not Tamiya rims.
If you choose to sacrifice the rims just to reuse the tires, acetone will get rid of the glue AND the rim eventually.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-20-2011, 04:14 PM   #4284
Thats fine i got the car used and a guy mounted soft rears on front wheels.. duh
Old 01-20-2011, 04:35 PM   #4285
robk's Avatar
Get an empty paint can (home depot and lowe's usually have them) and fill it a 1/3 of the way with acetone. Put the rims on an old coat hanger and suspend them ABOVE the acetone. Cover overnite and check. The vapors should loosen the tires without destroying the rims. No guarantees, though.
Old 01-20-2011, 05:21 PM   #4286
rc_square24's Avatar
I used to boil them in water when I had carbon reinforced plastic TC wheels that I reuse to get the rubber off. Not sure if it'll hurt the rubber or plastic rims.
rc_square24 is offline   Reply With Quote
Old 01-20-2011, 05:46 PM   #4287
F N CUDA's Avatar
Yep, that's the method but I promise you, the rims will be squishy and distorted if not thoroughly melted.
Same with baking or boiling. Funky plastic those sneaky Tamiya guys used.
Craig Hammon
Old 01-20-2011, 05:48 PM   #4288
gashuffer's Avatar
What about CA Debonder?
T-Sal
Old 01-20-2011, 05:57 PM   #4289
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey guys when running foam on carpet what do you start em at. the tamiya foams come 62mm. thanx. just tryin to get setup for tcs. usually im on rubber tires
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-20-2011, 06:06 PM   #4290
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
The way I have done it in the past takes time but works and usually saves both the tires and rims.
I use the back of a No. 11 Exacto blade and I just keep scraping the ca away between the rim and rubber tire. (you can probably do this with a good dental pick as well). It takes awhile but is very successful.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
