Like Tree4Likes
Old 01-05-2011, 06:33 AM   #4201
Oortael's Avatar
Hey,
here is my carpet setup with "tamiya cup specs". This works fine for me.
Greets
Oortael
Oortael is offline   Reply With Quote
Old 01-07-2011, 05:59 AM   #4202
abailey21's Avatar
Trader Rating: 36 (100%+)
Hey Rob, is the RCF1 Blog yours?
If so, can you show a close up pic of your servo and mount
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-07-2011, 07:08 AM   #4203
robk's Avatar
Trader Rating: 22 (100%+)
http://rcf1blog.blogspot.com/2011/01...-mounting.html
Old 01-07-2011, 08:31 AM   #4204
abailey21's Avatar
I did not dig deep enough, thanks dude!
K.C.C.O.
Old 01-08-2011, 05:25 AM   #4205
shadowracer24's Avatar
Can anyone tell me where to find some softer springs for the 104, can't seem to find any.
shadowracer24 is offline   Reply With Quote
Old 01-08-2011, 05:31 AM   #4206
abailey21's Avatar
Everywhere I shop is sold out
Or you can grab some of mine tomorrow, but remember, if you're resetting your car like Rob's in his blog we have VERY high traction, not low like he was running on. The harder springs are working well at Dennis's
K.C.C.O.
Old 01-08-2011, 08:50 AM   #4207
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
anybody got a good tarmac setup for the 104 based on Ride Medium compound Tires?
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 01-08-2011, 02:39 PM   #4208
robk's Avatar
42168 touring car short spring set (black) is the same as the mini car set.
That and a normal red will get you in the ball park for most situations.
Old 01-08-2011, 06:26 PM   #4209
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Default Carbon Fiber Decal
In case you guys don't frequent the other F1 thread, I got the first batch of my carbon fiber decal sheets on Friday.
I wrapped some 104 upper arms with it and took some shots of them as well as the sheet of material.
Check it out
[IMG][/IMG]
$12.50 a sheet or $20 for 2 shipped in the states, PM me to order
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 01-09-2011, 03:05 AM   #4210
2-Bad's Avatar
Tommi, Not for Ride tires but yes for the tamiya kit tires....
Front: (everything kit set except)
Toe - 0.5 deg out
Droop - 0.5mm
Spindle shaft - diff grease
Spring - black
Ride height - 6.5mm
Steering throw - maximum
Rear: (everything kit set except)
Droop - 2.0mm (5mm spacer in shock)
T-plate tension - 1xO-ring & loose
T-plate type - High Traction plate
Friction plate lube - 15wt shock oil
Friction plate - teflon covered
Friction plate tension - 2mm
Shock oil - 20wt
Shock spring - HPI copper (8lb)
Ride height - 6.5mm
Axle - steel
Diff grease - associated (black)
Diff tension - as loose as possible without slipping.
General
Esc - tekin rs
Motor - Speed Passion 21.5
Tires - Tamiya kit (frt & rr mediums I think they are)
Traction - FXII full frt & rr baked 60deg C, for 15min before race.
Ambient - 27 deg max
Track - asphalt, technical, sugar watered.
Hope this helps...
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-09-2011, 05:30 AM   #4211
Arahawak's Avatar
Trader Rating: 32 (100%+)
I run...
Toe - 0.5 deg in
Droop - No droop
Spindle shaft - No grease
Spring - black
Ride height - 5.5mm
Droop - No droop
T-plate tension - 1x small O-ring & loose
Friction plate lube - no oil, sometimes the Tamiya shock oil (yellow)
Shock oil - Tamiya yellow
Shock spring - Tamiya short red or normal red
Ride height - 5mm
Axle - carbon
Diff grease - stealth grease
Diff tension - i prefer slight slip..
General
Esc - LRP QC3
Motor - Formula Tuned 32T
Tires - Tamiya rear soft front hard
Traction - tire tweak only..
Ambient - humid and hot
Track - asphalt, technical, low-medium traction
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 01-09-2011, 09:51 AM   #4212
Oortael's Avatar
As this thread has made me wonder how challenging it would be to drive the F104 in the rain. Has anybody tried that?
Old 01-09-2011, 10:43 AM   #4213
No more or less challenging than a F103. When the rain first starts the track will be very slippery. Once it gets wet enough though the grip gets higher than when the track was dry.
Old 01-09-2011, 11:22 AM   #4214
wizzles29's Avatar
Send a message via AIM to wizzles29
@robk
HUGE thanks for posting those videos on how to set up the 104, they were extremely helpful.
I only wish I would have seen them BEFORE I built the kit, so I would have done it right the first time...lol
Proud "powder-puff" racer
King Hobbies/Raceway
The Track @ Harbor Hobbies
wizzles29 is offline   Reply With Quote
Old 01-10-2011, 08:37 PM   #4215
MikeR's Avatar
Trader Rating: 15 (100%+)
NEW FOAM ARBOR
http://www41.instantestore.net/merch...103-wheels.cfm
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
