Old 12-23-2010, 04:55 PM   #4096
Oortael's Avatar
Hey Guys,
I've got a Problem with my diff. I must set it very tight to prevent the spur from slipping.
First I cleaned every part of the diff. Then rebuild the diff. After that I sanded the pressure disks, checked the ball bearings and rebuild the diff again. But nothing helped. Any recommendations what could cause such a behavior?
I could realy need some help.
Good night
Oortael
Oortael is offline   Reply With Quote
Old 12-23-2010, 05:12 PM   #4097
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Diff lube is important, standard grease will not grip.
Diff balls are new in your rebuild? You may be tightening on the gear and not the diff balls if they are worn.
Originally Posted by Oortael View Post
Hey Guys,
Good night
Oortael
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 12-23-2010, 05:24 PM   #4098
gashuffer's Avatar
Trader Rating: 48 (100%+)
You might need to replace the two concave washers that apply the retension pressure in your diff. Or have you replaced those too?
T-Sal
gashuffer is offline   Reply With Quote
Old 12-23-2010, 05:24 PM   #4099
Arahawak's Avatar
Trader Rating: 32 (100%+)
Hey Guys,
Good night
Oortael
Have placed your diff plates correctly when fixing it back??
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 12-23-2010, 05:37 PM   #4100
GasGod's Avatar
Wow "retension pressure"
Wouldn't want to follow you --
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is online now   Reply With Quote
Old 12-23-2010, 05:40 PM   #4101
gashuffer's Avatar
BTW I got my 40 dollar charger!
T-Sal
Old 12-23-2010, 05:45 PM   #4102
No setups for F1 - F104 carpet???
C'mon man! lol
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 12-23-2010, 05:57 PM   #4103
F N CUDA's Avatar
Craig Hammon
Old 12-23-2010, 05:58 PM   #4104
F N CUDA's Avatar
Originally Posted by TheZoof View Post
Can someone recommend a good starting setup for carpet/foam F104?
It is a new class at my local track and would like to recommend a setup for them to start(that is easy to drive and fast enough).
I currently don't race the class.
Thanks!
Yep, start with an F103.
C'mon man! lol
If you're set on running the F104 (TCS Carpet?), get it low, get Pit Shimizu's if not TCS, if TCS then of course Option soft rears and Med or Hard fronts for what they are worth.
I've had best luck with a firmer setup for the rear, tighter T plate setting and damper plate pressure cuz too much bite and it traction rolls (it does that anyway but less this way for me).
I'm not the fastest F104 carpet guy but it goes ok I guess.
I just chimed in cuz some of the others haven't yet.
Craig Hammon
Old 12-23-2010, 06:00 PM   #4105
If you are having traction rolling issues on carpet you might want to try the 1/12th and WGT trick of coating the sidewalls of the tires with CA glue.
Old 12-23-2010, 06:00 PM   #4106
gashuffer's Avatar
C'mon man! lol
103 front end.
T-Sal
Old 12-23-2010, 09:34 PM   #4107
MikeR's Avatar
Trader Rating: 14 (100%+)
C'mon man! lol
Bottom of page
http://www.charleslightfoot.com/UF1/rules.html
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-24-2010, 03:38 AM   #4108
Oortael's Avatar
@F_N_CUDA: I replaced the diff balls, too. But the idea of the greas sound good. I used the grease which came with the kit. I might try any other. Do you have some that you prefer?
@gashuffer: You mean the washers between the ball bearing and the spacer & nut? I give it a try!
Old 12-24-2010, 05:50 AM   #4109
2-Bad's Avatar
Trader Rating: 24 (100%+)
David Jun Quote:
My personal preference is Associated Stealth Lube.
F104 Pro - By David Jun
and for these light duty diff's I would agree with him too. Just ensure you use the tube with Black writing on it (not Red) ....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-24-2010, 09:57 AM   #4110
Make sure the diff nut itself is not stripped
gordieb is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
