Old 12-09-2010, 05:20 PM   #3991
Originally Posted by Oortael View Post
And where is the video?! You "have to" give evidence ;-)
What evidence would you like...my mate driving it into a pole at speed, or one of many rollovers... or the epic, but short, burnout.lol
http://www.youtube.com/watch?v=eC7SwOW5Y7s
http://www.youtube.com/watch?v=RIkrD-6zbFE
http://www.youtube.com/watch?v=4kdOZSyb8dA
total3d is offline   Reply With Quote
Old 12-09-2010, 08:58 PM   #3992
tunerjetta29's Avatar
Better:
http://www.youtube.com/watch?v=l4n4aeswWGk&hd=1
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 12-09-2010, 10:46 PM   #3993
Mitch-e4fs's Avatar
I got my shimizu tyres today and am wondering if I have to trim the foam insert to fit the wheel or does it stay in the tyre?
Mitch-e4fs is offline   Reply With Quote
Old 12-09-2010, 11:10 PM   #3994
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Foam stays in the tire, it'll have an air gap, drill at least a couple 1/8" holes in the rims.
I just did mine too, with the help from the guys that have been running them for a while now.
Glue them carefully to keep them lined up and they'll be fine.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 12-13-2010, 12:22 AM   #3995
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Something I made...
http://www.shapeways.com/model/18324...er.html?gid=rg
akura2 is offline   Reply With Quote
Old 12-13-2010, 07:45 AM   #3996
AZBMXer's Avatar
Originally Posted by akura2 View Post
Is this for sale or are you just showcasing your handiwork?
AZBMXer is offline   Reply With Quote
Old 12-13-2010, 10:50 AM   #3997
akura2's Avatar
its for sale... just click the link....
I also make the T-Cam that's on the top of the airbox on my F60
Old 12-13-2010, 10:58 AM   #3998
AZBMXer's Avatar
There is no price listed and actually says that its "Not for sale."
Old 12-13-2010, 11:16 AM   #3999
akura2's Avatar
Fixed... thanks for letting me know
this is what I was going for
Old 12-13-2010, 05:11 PM   #4000
rc_square24's Avatar
Does anyone make a servo mount set that has threaded holes where the lower and upper decks screw together? Tamiyas aluminum servo mount is a thru hole design like the kit part, while their alum rear pivot mount changed to a threaded thru hole so you replace the top nut and single long screw with top and bottom screws.
The reason I want it is because it's difficult to tighten the ball studs /nuts while holding the chassis flat, the screw just spins around. Of course I can hold a driver/wrench on the other side but wouldn't this prevent the chassis from being tightened evenly and flat? Like how you wont tighten a TC top deck by holding the chassis on your hand? Or does this not matter on the f104?
rc_square24 is offline   Reply With Quote
Old 12-13-2010, 05:26 PM   #4001
I cut the part off of the stock plastic servo mounts and used a 1/2" stand-off that I tapped to 3mm. It works quite nicely.
Old 12-13-2010, 06:16 PM   #4002
I have a 104 and looking for the tamiya front springs or is there any other front springs that I could use? thanks in advance
quinnfrazier is offline   Reply With Quote
Old 12-13-2010, 08:05 PM   #4003
gsxr0311's Avatar
Trader Rating: 18 (100%+)
they have them at rc mart. i think a 1/12 scale front spring will work also.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 12-13-2010, 09:31 PM   #4004
2-Bad's Avatar
Trader Rating: 24 (100%+)
TAMIYA 50509 F-1 FRONT SPRING SET FOR F103 (TA-50509) = US$2.40
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-13-2010, 09:36 PM   #4005
Foxxrocket's Avatar
I've been using 1/12 scale springs from Windtunnle racing. They have a good range of spring rates to work with.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
