Old 12-08-2010, 04:23 AM   #3961
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by gashuffer View Post
Adding shims under the ball connector where the arms snap into on the topdeck will increase static castor. This will raise the rear of the arm by how many mm shims you use.
Please excuse my dirty car
Thank you very much, just needed some visual confirmation.
So adding to the rear for more static castor and add the front for??
What does it do to the car?? sorry am not really understanding the previous posting...
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 12-08-2010, 04:32 AM   #3962
iknowjoe's Avatar
Trader Rating: 40 (100%+)
Send a message via AIM to iknowjoe
You know we have an air compressor at the track right?
I know... we got out way too late the other night and cleaning the car was not a priority. Gettin home was.
See you Sat. F1 Nation baby! Hell Yeah!
http://StrongmileMovers.com
iknowjoe is offline   Reply With Quote
Old 12-08-2010, 06:25 AM   #3963
MantisWorx's Avatar
Trader Rating: 28 (97%+)
if you shim the rear you will go from a negative castor number to a more positive number ie -4 castor to -3 castor which will give you more turn in, less high speed steering. shimming the front will do the opposite. BUT since the arm is in a fixed state you cannot shim too much or the arm will bind (i dont know what the limits are though). the thing is though by using the Tamiya style of camber adjustments when you add more negative camber you also decrease the castor too (see the sketch i posted earlier) so if you want to counter act what the camber adjustment does than you should shim the front to attempt to get the castor back to where it was.
MantisWorx is offline   Reply With Quote
Old 12-08-2010, 06:50 AM   #3964
MantisWorx's Avatar
ok through the wonders of autocad i have drawn out exactly what will happen if you add rear shims to the arms! as the suspension is compressed you will lose static negative camber and i think we all agree with that but what may surprise you is that according to my sketch raising the rear shims by 4mm only gives you .006" of a decrease(with 2mm of arm travel) which is not very much at all (avg human hair is about .007") . now according to Robk doing this will increase mid corning and that is true but now this is got me thinking. my main issue with the 104 frame chassis is just not enough steering in general on asphalt, i just cant seem to get enough high speed steering with the available tire at all. this weekend im going to experiement with this and see what i can come up with on the mantisworx front i can set my static castor to where i get enough turn in and then shim the front so maybe i can get more high speed steering. in theory it should work but i dont know if i can get enough shim under the front to make it effective.
Old 12-08-2010, 07:05 AM   #3965
MantisWorx's Avatar
while we are on the subject of front ends anyone want to explain how the new generation of 1:1 F1 is calculated? you cant apply the normal roll center rules to them because the arms never cross paths! i made a model with "high center" and it is very aggressive as far as what it does when weight transfers. i think that because the chassis is so long you dont get as much "roll" therefore the geometry has to be very aggressive to keep the tires flat. anyone have any insight or links that explain?
Old 12-08-2010, 07:54 AM   #3966
Arahawak's Avatar
hmmz.. ok thanks for the info.
so in layman terms, shim the rear for technical tracks and shim the front for high speed flowing track?
Old 12-08-2010, 08:06 AM   #3967
robk's Avatar
Trader Rating: 22 (100%+)
Please just shim the car and try it. It is visible to the naked eye when you work the suspension.
Old 12-08-2010, 08:25 AM   #3968
gashuffer's Avatar
Trader Rating: 48 (100%+)
You are making this way more complicated than it is. We don't need cad, or a physics lesson. Just try it, if it works then run dat sh!t.
T-Sal
gashuffer is offline   Reply With Quote
Old 12-08-2010, 08:36 AM   #3969
MantisWorx's Avatar
i agree with both of you????? i was just clarifying it for those who dont understand(arahawk). i did try it and it does work! there is no argument here at all GEEESH!
Old 12-08-2010, 08:37 AM   #3970
MantisWorx's Avatar
i would agree with that!
Old 12-08-2010, 08:49 AM   #3971
MikeXray's Avatar
Trader Rating: 72 (100%+)
I got no problems with the CAD images Its always good to back up the feel with the math.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-08-2010, 08:58 AM   #3972
MantisWorx's Avatar
thank you! it seems like i cant even agree without an argument busting out! i like to verify everything too!
Old 12-08-2010, 11:44 AM   #3973
abailey21's Avatar
Trader Rating: 36 (100%+)
Anyone else ever have issue mounting Ride tires on stock Tamiya rims? (Rubbers)
Seems like the Ride tires are smaller than the Tam rims?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-08-2010, 12:38 PM   #3974
MantisWorx's Avatar
you have to use ride wheels with ride tires, i made the same mistake!
Old 12-08-2010, 01:41 PM   #3975
gashuffer's Avatar
I'm not arguing at all, but sometimes a picture(of the car) of what needs to be done says a thousand words. Thats all. Some people just need the visual.
T-Sal
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
