Old 12-01-2010, 12:01 PM   #3901
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by tunerjetta29 View Post
Harder rear foams?
or just sauce the fronts... start with no sauce rear, 1/4 sauce front... and slowly start saucing more of the front until you get the turn-in you want...
akura2 is offline   Reply With Quote
Old 12-01-2010, 06:59 PM   #3902
akura2's Avatar
How are the Shimizu's at West Coast RC? (for those that race in SoCal)... I took my F104 to the track with the Tamiya option rubber (soft rear hard front) and the track was like glass (everyone was complaining.. even the 4WD guys) it was a practice night, so the track may not have been prepped
I'm using the stock T-bar, and no spring on my center shock... and silver can... thanks
Old 12-01-2010, 07:03 PM   #3903
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Tamiya rubber tires have no chance on the rug.
The Shimizu tires that Sean stock are what you will find most all of the F104 pilots running.
RIDE tires work fairly well too, but require a setup with a bit of an open mind and some imagination . . .
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-01-2010, 07:37 PM   #3904
akura2's Avatar
Thanks.. But West Coast RC Raceway (WCRCR) is indoor asphalt.... Not carpet
Old 12-01-2010, 07:52 PM   #3905
True
But at WCRC it seems like the same story, Tamiya rubber not so special on that surface either.
slightly off topic,but
RIDE A for the 103 is awesome at WCRC
Old 12-01-2010, 07:53 PM   #3906
stock black T-bar is too hard for rubber tires, try option high-traction T-bar(use small o-ring only), softest spring on oil damper and you will love your car much more
Marco926 is offline   Reply With Quote
Old 12-01-2010, 07:59 PM   #3907
I did the same for my new ferrari scheme, TRG wheels with the Shimizus are great looking!
which compounds you're using ??? good ???
i'm going to try the newest compound(R3-S) for the rear and the front is old soft.
Old 12-01-2010, 08:27 PM   #3908
kneedeeppow's Avatar
Originally Posted by Marco926 View Post
this is my F104 pro with shimizu tires on TRG foam wheels....perfectly fit with nil modification
did you cover the whole wheel surface with glue or run a bead of glue along each edge? looks good by the way
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 12-01-2010, 10:12 PM   #3909
seems many brothers do not know how shimizu's work on foam wheels, let me draw a picture to explain.
the outside part of the tire have a larger area in order to cover the wheel rim
black - wheel rim
green - tire
red - area to apply glue
blue - foam insert
Old 12-01-2010, 11:04 PM   #3910
lightfoot's Avatar
As strange at it sounds... Shimizu's website in Japan recommends the stock harder T plate for rubber tires... But like everything in RC, what works for some does not always work for others...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 12-02-2010, 12:01 AM   #3911
i tried the stock t-bar and the car is very unstable.......maybe i'm not good enough in such setting..................
when i changed to softer t-bar then everthing is under control
Old 12-02-2010, 08:04 AM   #3912
gsxr0311's Avatar
Trader Rating: 18 (100%+)
redbull, which compound rubber are you running on the carpet?
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 12-02-2010, 08:12 AM   #3913
gsxr0311's Avatar
redbull, also where do you order them from? thanks
Old 12-02-2010, 10:12 AM   #3914
Front
Shimizu Racing
PS-0575
Rear
Shimizu Racing
PS-0577
Sean has a lot of F1 tires and parts in stock at TQ racing
http://www.tqrcracing.com/
Old 12-02-2010, 10:13 AM   #3915
black - wheel rim
green - tire
blue - foam insert
That would explain why they look wider....they are
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
